    [Plugin] Control points ver. 1.6.
    115 Posts 42 Posters 74.8k Views 42 Watching
    • jason_marantoJ
      jason_maranto
      😲 Whoah --you are definately way too good at this... can't wait to play with that.
      best,
      Jason.
      • EarthMoverE
        EarthMover
        Great Idea with the boxes Kirill! The point painting is also really cool and I expect lots of colorful posts from Pilou using it! Also good to hear you are working on an outer edge lock. 👍
        Content Creator at Skapeup
          malakon
          I'm having problems with this plugin and it seems that is not only me, here is a link to a user in the forum with the same problem
          404 Not Found
          (forums.sketchucation.com)
          Control Points causing SU 7 to crash
          Postby aswiger on Tue Feb 02, 2010 4:20 am
          I am using the Control Points plugin, and there seems to be at least a couple issues when following along in some of the youtube videos posted by the plugin's creator. First, whenever I add control points then use the move tool to move one of the points, SU will give me an odd error message: "most probably geometry group was erased", then crash.
          Also, when I draw to circles and select both, the blend option is not visible on a right click. I've restarted my machine, re-installed the plugin, tried using both 1.6 and 1.7 to no avail. I'm using SU 7.1 pro on Windows 7. Any advice? Thanks!
          Aaron
            apple85
            @kirill2008 said:
            @wind-borne said:
            i am having a strange problem, plugin only shows up on initial opening drawing. If I open a new one without closing Sketchup completely, no plugin.
            As I can see on attached picture the whole face is selected, but current version of the script (ver. 1.1.) actually processes only curves. So try select only boundary curve without face itself (you may deselect face by pressing shift and single-clicking on face). Make sure that only boundary is selected. Of course script processing does not depend on opened file (old or new). It depends on what entity is the first one selected: if it occures that curve edge is the 1-st item of selected entities collection, then everything works, if the 1-st item is face, then the command does not appear within context menu.
            So I'll try to make the script more tolerant to the selection in future versions 😄 .
            Speaking of copy-paste behaviour, I'll try to find out why it processes so strange (don't know why yet).
            I got a similar problem to the above - i try selecting the lines around a simple 2d shape like a circle, triangle (like in the original first video at the beginning of this thread) - just the lines and not the 2d face but when i right/control click i do not get the 'Add control points to the curve' option to start off the whole process with this plugin. I think my sketchup knows that it exists as as another user on this forum pointed out to me, in the 'plugin' menu there are 4 modify options to do with this plugin, i just can't use them until i have figured out how to add the control points. i've tried selecting the both 2d and 3d shapes and right clicking but there is still no control point option.
            if someone could point out where i'm going wrong or give me a brief step to step on how to add the control points to both 2d and 3d shapes, it would be a massive help!
            curve control points.pdf
            • X
              xrok1
              well this deserves a bump anyway but also i have a problem. if i draw a cirle, right click add cpoints every 3rd, now when i go to move a point up iget this message followed by a bug splat everytime. 😞
                August
                I'm having no luck getting started with this. I suspect that I'm missing some changes in the directions for how to get started, but I'm pretty sure that I at least skimmed the whole thread.
                1. Download and install the v1.6 script from the first post.
                2. Open SU, create a test object (3D text my favorite for testing this kind of thing).
                3. Plugin Menu has four new items, but they all appear to need c-points already added.
                4. Right click (context click) on the group --
                  No new menu items, nothing mentioning c-points, the options suggested at various points in the thread (I don't know for sure that I've found the most recent) are not there.
                Any pointers to what steps I'm missing?
                Thanks,
                August
                P.S. Windows 7, SU 7.1.6860
                “An idea, like a ghost, must be spoken to a little before it will explain itself.”
                [floatr:v1mcbde2]-- Charles Dickens[/floatr:v1mcbde2]
                • X
                  xrok1
                  right click on a group (has to be a group)
                    August
                    @xrok1 said:
                    (has to be a group)
                    Thanks. I "thought" it was, but 3D text gets created as a component, not a group. Explode and regroup and the menu options are are there!
                    Thanks,
                    August
                    • X
                      xrok1
                      got me the first time i tried this plug on 3dtext to solve your insane problem too. 😲
                      (yes i'm still thinking about it. 👿 )
                        August
                        As I said, don't hurt yourself. I have a workaround.
                        For me it's now at the level of how to make these amazing tools even more insanely flexible while still keeping them intuitively useful. Maybe one of the extension ideas I throw out will stick to one of the developers the way this question seems to have stuck with you.
                        August
                        • N
                          notareal
                          What happened to videos? 😕
                          • K
                            kirill2008
                            If someone still interested in this plugin, then, I guess, this video will be interesting too:
                            [flash=560,315:38wj9eza]http://www.youtube.com/v/dXHJSEXn86Y?version=3&hl=ru_RU[/flash:38wj9eza]
                            • mitcorbM
                              mitcorb
                              Yep, the video is interesting. I may have to watch it another couple of hundred times until my little brain can fully grasp what all you did here.
                              • K
                                kirill2008
                                @mitcorb said:
                                I may have to watch it another couple of hundred times...
                                200 views per one viewer, that's how I'll finally become popular on YouTube 😆
                                in 'science/technology' category I mean 😄
                                Actually I was trying to keep things simple, but it looks like I have to try more efficiently... Because it is still not obvious for end user, how everything works 😕 . The final goal is to make tool processing so intuitive that one would not need to watch tutorial 200+ times 😄
                                • mitcorbM
                                  mitcorb
                                  Well, you know I was joking. Actually, on a second viewing, and with more time to watch it through, the concept was clear enough. The details- commands, tool selections, sequence and so forth will take a little longer for me.
                                  However, on one viewing, it is clear that this is a significant development. Congratulations. 👍 👍
                                  • P
                                    poru
                                    Wow, amazing
                                    Thank you 🙂
                                      rumcajs
                                      Great plugin. I look forward to create some terrain with it. But I have to confess I have some problems when I try to move the control power ... it is hard to me to focus the control point and it costs a lot of waiting till the red frame appears there. Sometimes I click, but it is too late, and the red frame disappeared so I have to remove the point. It looks slow for my computer even that my comp is not so bad on performance. I cannot to do it so fast as you do in demo video. Some key to remove node, for example backspace, would be very practical. I do it with context menu, which is slow. One more idea. It would be great if I could enter the power immediately whey I click on the terrain. I think that if I write the number in Measurement box, it does nothing... Also confider that that maps are done in different numbers. You have some terrain, for example altitude 700 and above. But if you add the power number to nodes like 700 or 725 and so on, so it will be too much for the terrain. To save the calculation for human, you could make one extra box, where user will write his base altitude like 700. Then he could write the number from a map and you would subtract the 700 from his number to get the correct number. So for example. I need to get these altitudes from the map to the terrain model: 712, 745, 765, 815, 922. I will enter value 700 as the base value. Then I create control points and I write to the Measurements box: 712 for first node, 745 for second node, 765 for 3rd node and so on. In the meantime the program will count: 712-700=12, 745-700=45, 765-700=65, 815-700=115, 922-700=222... And here are the correct sizes for my model... This is practical issue. Never mind if you would keep both values in the node...
                                      • V
                                        vojo
                                        Can somebody actually explain how to use this tool
                                        • Move appears to be some fraction of the movement of the actual control point
                                        • scale is not obvious but once you play around you get the idea, I see the intent although it too is a fraction of the actual scaling so again not sure the value
                                        • etc
                                        I tried playing with the power setting 0, 1, 3, 10....doesnt seem to make a difference
                                        What I would have assumed this does is:
                                        • Add some control points
                                        • If I move / scale the control points, movement / scaling based on power
                                          (ie if power = 1.0...then a 1:1 movement or scaling....power = 10...then 10:1...etc)
                                        ya know, it would be good if a given plugin does what it says it will do
                                        Some guys write solid plugins with good doc (Freddo)... others (to remain nameless) have
                                        some plugins as advertised while others dont deliver even the basics (with some of them
                                        appearing to be an exercise in ruby programming vs providing some actual useful function).
                                        Given this store idea....maybe somebody should have a clearing house on plugins to ensure
                                        quality. Require good doc or (video would be fine but since the videos for this plugin dont load....pointless), ensure the plugin actually does its stated function, etc
                                        I guess its me....who knew that "affecting geometry" did not mean some sort of 1:1 relationship 😉
                                        • V
                                          vojo
                                          One more thing. Since so many of these plugins are garbage and dont know that until have installed, the store (or a plugin) should have a feature that tracks how often a plugin is used. That way a user can clean up the garbage once a quarter or once a year
                                            You might want to consider that people who spent their time on these plugins offered them for free. They might not be perfect, they might not be doing what you had hoped what they do - but please show some respect.
                                            • 5 / 6
