    [REQ] Name Layer from a group existing
    16 Posts 3 Posters 2.6k Views 3 Watching
      Maybe this yet existing ? (don't yet refound)
      If not does it possible to have something who allow to create and name a layer with the name of a group clicked?
      Thx by Advance
      Click here for see the post below ๐Ÿ˜‰
      • TIGT Online
        Something like:
        def layer_name_from_group_name()
          model=Sketchup.active_model
          ss=model.selection
          if ss[0].class != Sketchup;;Group
            UI.messagebox("Select a Group to Name a Layer after...")
            return nil
          end#if
          name=nil
          name=ss[0].name
          if not name or name==""
            UI.messagebox("Select a NAMED Group to Name a Layer after...")
            return nil
          end#if
          layer_names=[];layers=model.layers
          layers.each{|layer|layer_names<<layer.name}
          if layer_names.include?(name)
            UI.messagebox("A Layer with that Group's Name ["+name+"] already exists...")
            return nil
          end#if
          new_layer=layers.add(name)
          UI.messagebox("Layer '"+name+"' created.")
        end#def
        (untried...)
        ๐Ÿค“
          Seems works fine inside the ruby console ๐Ÿ˜„
            Why when I replace
            by
            if ss[0].class != Sketchup;;ComponentInstance
            that does'nt work with a component? ๐Ÿ˜ฎ
            Edit ! That works! ๐Ÿ˜† It just that I confuse "Name of the Component" and "Definition name" of the component ๐Ÿ˜ณ
            So is it possible to use the "Definition's name"?
            • TIGT Online
              Why when I replace
              by
              ### if it's an instance with...
              ss[0].name ### returns the instance's 'name'.
              ss[0].definition.name  ### returns the instance's definition's 'name'.
                Many thanks! ๐Ÿ‘
                  asuming that the file is renamed toto.rb, and working with for groups
                  I add this at the end for have the right click Context
                  if( not file_loaded?("toto.rb") )
                    UI.add_context_menu_handler do |menu|
                      menu.add_separator if ss[0].class != Sketchup;;Group
                      menu.add_item("add Layer name") if ss[0].class != Sketchup;;Group
                  file_loaded "toto.rb"
                  All is always working fine in the Ruby console
                  but I have nothing as Menu Contextual on the Right Click when a group is selected โ“
                  Ps This Text editor is a little smaller for see a correct Code size's line ๐Ÿ˜’
                  • TIGT Online
                    >   end
                    > end
                    You also need to give the menu item an action {}
                    should be
                    ...class == Sketchup::Group
                    Should NOT be
                    ...class != Sketchup::Group
                    The ! negates it - i.e. "if class is NOT == Group", when you actually want "if class == Group" ! ๐Ÿค“
                      After hundred of try ๐Ÿ˜’
                      (ruby console works always fine I have no syntax error message)
                      but always nothing in the right click panel menu ๐Ÿ˜ณ
                      I don't see very well what "action" I must put inside the {} (I had tested some many ๐Ÿ˜„
                      Surely trivial but ๐Ÿ’š
                      if(not file_loaded?("toto.rb"))
                          menu.add_separator if ss[0].class == Sketchup;;Group
                         menu.add_item("Add Name Layer"){layers.add(name)}if ss[0].class == Sketchup;;Group
                        Another thing that will be cool :
                        put in the same time the object (goup/component) in the the layer created โ˜€
                        • TIGT Online
                          If you go back to my earlier example
                          def layer_name_from_group_name()...
                          is the action to put in the {}
                          So at the end of the file that loads layer_name_from_group_name add your context-menu test and run the action...
                            hum hum ๐Ÿ˜ณ
                            Seems there is something again missing ๐Ÿ˜ฎ
                            (Console is Ok)
                            right Click context menu always unseen ๐Ÿ˜ณ
                                  ss=model.selection
                                    return nil
                                  end#if
                                  name=nil
                                  name=ss[0].name
                                    return nil
                                  end#if
                                    return nil
                                  end#if
                                end#def
                            if(not file_loaded?("layer_name_from_group_name.rb"))
                                menu.add_separator if ss[0].class ==Sketchup;;Group
                               menu.add_item("Add Name Layer"){layer_name_from_group_name()}if ss[0].class==Sketchup;;Group
                            file_loaded ("layer_name_from_group_name.rb")
                            • TIGT Online
                              ss=Sketchup.active_model.selection
                              menu.add_separator if ss[0].class ==Sketchup::Group
                              menu.add_item("Add Name Layer"){layer_name_from_group_name()}if ss[0].class==Sketchup::Group
                              The red text is needed to define ss as it was only defined inside the def... ๐Ÿค“
                                Yep now that works fine! Many thx! โ˜€ ๐Ÿ‘
                                To do
                                Now second part : move in the same time the object clicked on the layer named
                                For the moment that works for a group or a component ๐Ÿ˜‰
                                Just select a group named or a component with Definition name
                                Right Click and a context menu appears : Add Name Layer from Group
                                or Add Name Layer from Component
                                (object is not moved on this version)
                                If your Right Click is broken you must enter on the ruby Console
                                layer_name_from_group_name or layer_name_from_component_name ๐Ÿ˜‰
                                layer_name_from_component_name.rb
                                • bagateloB Offline
                                  bagatelo
                                  Is possible to do the inverse of this situation, like this:
                                  Base Group (or components) Name from layer name? If yes, would be fantatisc to my workflow.
                                  • TIGT Online
                                    Pilou - nascent scripter - yours I think... ๐Ÿ˜„
                                    Iterate through model.definitions, if defn.group? then add if to a groups array and then iterate through groups and rename each group to match its group.layer.name, keep a list of all group names as you go [start by making a list of the groups' names and then remove old name and add new name as you go groups]. It a group name exists then increment it [tip: name="name#1";name=name.next if groupnames.include?(name)] - several groups could be on one layer and should them get named name#1,name#2,name#3 etc...
