    [REQ] Name Layer from a group existing
    16 Posts 3 Posters 2.6k Views 3 Watching
      Many thanks! ๐Ÿ‘
        asuming that the file is renamed toto.rb, and working with for groups
        I add this at the end for have the right click Context
        if( not file_loaded?("toto.rb") )
          UI.add_context_menu_handler do |menu|
            menu.add_separator if ss[0].class != Sketchup;;Group
            menu.add_item("add Layer name") if ss[0].class != Sketchup;;Group
        file_loaded "toto.rb"
        All is always working fine in the Ruby console
        but I have nothing as Menu Contextual on the Right Click when a group is selected โ“
        Ps This Text editor is a little smaller for see a correct Code size's line ๐Ÿ˜’
          >   end
          > end
          You also need to give the menu item an action {}
          should be
          ...class == Sketchup::Group
          Should NOT be
          ...class != Sketchup::Group
          The ! negates it - i.e. "if class is NOT == Group", when you actually want "if class == Group" ! ๐Ÿค“
            After hundred of try ๐Ÿ˜’
            (ruby console works always fine I have no syntax error message)
            but always nothing in the right click panel menu ๐Ÿ˜ณ
            I don't see very well what "action" I must put inside the {} (I had tested some many ๐Ÿ˜„
            Surely trivial but ๐Ÿ’š
            if(not file_loaded?("toto.rb"))
                menu.add_separator if ss[0].class == Sketchup;;Group
               menu.add_item("Add Name Layer"){layers.add(name)}if ss[0].class == Sketchup;;Group
              Another thing that will be cool :
              put in the same time the object (goup/component) in the the layer created โ˜€
                If you go back to my earlier example
                def layer_name_from_group_name()...
                is the action to put in the {}
                So at the end of the file that loads layer_name_from_group_name add your context-menu test and run the action...
                  hum hum ๐Ÿ˜ณ
                  Seems there is something again missing ๐Ÿ˜ฎ
                  (Console is Ok)
                  right Click context menu always unseen ๐Ÿ˜ณ
                        model=Sketchup.active_model
                        ss=model.selection
                          UI.messagebox("Select a Group to Name a Layer after...")
                          return nil
                        end#if
                        name=nil
                        name=ss[0].name
                        if not name or name==""
                          UI.messagebox("Select a NAMED Group to Name a Layer after...")
                          return nil
                        end#if
                        layer_names=[];layers=model.layers
                        layers.each{|layer|layer_names<<layer.name}
                        if layer_names.include?(name)
                          UI.messagebox("A Layer with that Group's Name ["+name+"] already exists...")
                          return nil
                        end#if
                        new_layer=layers.add(name)
                        UI.messagebox("Layer '"+name+"' created.")
                      end#def
                  if(not file_loaded?("layer_name_from_group_name.rb"))
                      menu.add_separator if ss[0].class ==Sketchup;;Group
                     menu.add_item("Add Name Layer"){layer_name_from_group_name()}if ss[0].class==Sketchup;;Group
                  file_loaded ("layer_name_from_group_name.rb")
                    ss=Sketchup.active_model.selection
                    menu.add_separator if ss[0].class ==Sketchup::Group
                    menu.add_item("Add Name Layer"){layer_name_from_group_name()}if ss[0].class==Sketchup::Group
                    The red text is needed to define ss as it was only defined inside the def... ๐Ÿค“
                      Yep now that works fine! Many thx! โ˜€ ๐Ÿ‘
                      To do
                      Now second part : move in the same time the object clicked on the layer named
                      For the moment that works for a group or a component ๐Ÿ˜‰
                      Just select a group named or a component with Definition name
                      Right Click and a context menu appears : Add Name Layer from Group
                      or Add Name Layer from Component
                      (object is not moved on this version)
                      If your Right Click is broken you must enter on the ruby Console
                      layer_name_from_group_name or layer_name_from_component_name ๐Ÿ˜‰
                      layer_name_from_component_name.rb
                      • bagateloB Offline
                        bagatelo
                        Is possible to do the inverse of this situation, like this:
                        Base Group (or components) Name from layer name? If yes, would be fantatisc to my workflow.
                          Pilou - nascent scripter - yours I think... ๐Ÿ˜„
                          Iterate through model.definitions, if defn.group? then add if to a groups array and then iterate through groups and rename each group to match its group.layer.name, keep a list of all group names as you go [start by making a list of the groups' names and then remove old name and add new name as you go groups]. It a group name exists then increment it [tip: name="name#1";name=name.next if groupnames.include?(name)] - several groups could be on one layer and should them get named name#1,name#2,name#3 etc...
