    [Plugin] VisMap Pro Beta Available, Free
    14 Posts 4 Posters 10.2k Views 4 Watching
      MartinRinehart
      http://www.MartinRinehart.com/models/rubies/vismap_p_doc.html
      VisMap Pro, beta test, is available. Its primary goal is to handle many more layers and scenes. The scene list is in a separate window; the windows support frames so you can eliminate banner and button frames and you can expand and shrink the map and the scene list.
      Post beta test there will be a send-me-money feature added, but it's not there yet.
      Author, Edges to Rubies - The Complete SketchUp Tutorial at http://www.MartinRinehart.com/models/tutorial.
      • JClementsJ Offline
        JClements
        Martin, looks like you've been doing fine tuning of the UI.
        Will this work with SU6?
          MartinRinehart
          I foolishly let SU7 replace my SU6. Try it and tell me.
            JClements
            Martin, it doesn't work in SU6 or SU7.0.
            It can send data but in can NOT GET DATA.
            Simple Test file attached.
            Vismap test.skp
              MartinRinehart
              Odd. It was developed in 7.0. I haven't upgraded yet.
              Thanks for the test model, but it got and sent fine on my machine. What problem was I supposed to see?
                JClements
                Get Data From Model doesn't update after using it the first time.
                So,
                open file.
                Open VisPro
                Get Data from Model
                Make changes via the Layers Window
                Get Data From Model ... changes are not picked up.
                Likewise, close model and reopen, make visibility changes, open VisPro, Get Data From Model doesn't change anything.
                  MartinRinehart
                  I bet you didn't Update. Scene changes aren't part of the model until you Update the scene.
                    JClements
                    But I didn't change any scenes. I merely opened the file, made layer visibility changes, and tried to update VisPro.
                      MartinRinehart
                      VisMap can't "see" any changes until you update a scene. Internally, it marches through your scenes one at a time asking "who's visible here?" So, until you change a scene it can't see what you've done. This is in the "Gotchas" in the VisMap doc. Maybe I should repeat that in the VisMap Pro doc.
                      If it will make you feel any better, you are not the first person bitten by this "bug." You are corresponding with the man who has that honor.
                      • EdsonE Offline
                        Edson
                        martin,
                        i have tried it on a simple model and it worked but on larger files i get the old message and no layers appear.
                        http://www.mahfuz.arq.br
                          JClements
                          Can't you just add a ruby snippet which performs a Scene update to a scene called "VisPro Updater Proxy".
                          It would just be a proxy with no attributes associated with it so the rest of the VisPro script could get around the "bug".
                          If no scene named "VisProUpdater Proxy" existed it would be created and if it does exist then an update function would be performed and the rest of your existing script would be executed
                            MartinRinehart
                            A Scene0, roughly analogous to Layer0? What you're looking at? Hmmm.
                            • chrisglasierC Offline
                              chrisglasier
                              So,
                              open file.
                              Open VisPro
                              Get Data from Model
                              Seems Martin hasn't got to the bit about observers just yet.
                              With TBA interfaces we can analyse what is to be achieved so that IT can help with automation to achieve it.
                                JClements
                                Yup. I used the name VisPro with a detailed description so the user would know its origin.
                                I guess you could delete the Proxy Scene at the tail end of the script. Not sure creating and deleting would slow things down tho.
