    [Plugin] SU2KT 3.18 - Kerkythea exporter
    35 Posts 13 Posters 33.1k Views 13 Watching
      taufikohidayat
      @massimo said:
      There is SU2KT 3.17 now.
      About your issue have a look here.
      I also have tried that, and it doesn't work -__-
        Although you say, "copied the file into the exact folder," if it doesn't work, it is likely you didn't install it correctly. To make it easier to install the plugin correctly after you've downloaded the ZIP file, change the extension to .rbz. Then use Install Extension from Preferences>Extensions to install it correctly. Before doing that, however, go to the Plugins folder and remove any thing related to Kerkyhtea there.
          taufikohidayat
          this is what happened after i tried installing it from the extensions
          http://imagizer.imageshack.us/v2/150x100q90/841/eu9y.png
          i'm sure there is some parts of installing that I did wrong, but I can't figure out which steps that i did wrong
            That's a worthless screen shot. It's way too small. πŸ˜’ Make a larger screen shot.
              taufikohidayat
              sorry, I didn't realise the size of the screen shot when I uploaded it
              http://res.cloudinary.com/dsafcphpe/image/upload/v1405265665/Screen_Shot_2014-07-13_at_13_32_45_oeagck.png
              hope this time will be much better
                Did you make sure you have Read & Write permissions set for the Plugins folder?
                  taufikohidayat
                  yes, I have
                    You must be missing something. I just installed it on my Mac using the ZIP file converted to .rbz as I described, above. It worked just fine. There's nothing wrong with the plugin itself.
                      taufikohidayat
                      [attachment=0:2incryk5]<!-- ia0 -->2014-07-13_11-34-43.png<!-- ia0 -->[/attachment:2incryk5]
                      yeah i know, but I can't figure out what i am missing -__-
                        This is with SU8? Are there any strange characters in your user name on the computer?
                          taufikohidayat
                          yes, it is su8, I guess not... I haven't seen any strange character on my user name
                            Could you make and post a screen shot of the Info window (Get info) for your Plugins folder?
                              taufikohidayat
                              http://res.cloudinary.com/dsafcphpe/image/upload/v1405276467/Screen_Shot_2014-07-13_at_19_33_51_suox6i.png
                                Hmmmm....
                                  taufikohidayat
                                  @dave r said:
                                  Hmmmm....
                                  I found its annoying -__- I have no idea what did i do wrong when installing the plugin
                                  • 2 / 2
