    [Plugin] 2D Tools
    791 Posts 178 Posters 807.4k Views 177 Watching
      It makes sense to me that way, TIG. Thanks for the explanation.
      • R
        Roach
        exсuse me, where can I find a link to download?
        • massimoM
          massimo Moderator
          404 Not Found
          (sketchucation.com)
          • R
            Roach
            @massimo said:
            404 Not Found
            (sketchucation.com)
            thank you very much!
            • cwmunroC
              cwmunro
              I have tried to install this RBZ file several times and cannot seem to find it anywhere (once it has been installed). Am I doing something wrong here? I download the file and then install it into my plugins folder - then I restart SU and it's not there. I have also tried to install it directly from the Extension Warehouse but, cannot locate or there. I am very excited about the Dashed Lines aspect of the plugin but, cannot get it to install. FYI: I use SU 8
              C W Munro
              Professional Building Designer
              http://www.thealaddincompany.com
                Did you try Install Extension from Window>Preferences>Extensions? Click that button and navigate to where you saved the RBZ file. Select it and choose 'Open".
                Why don't you install the Sketchucation Plugin Store tool and use it for auto-installing plugins from now on?
                • cwmunroC
                  cwmunro
                  I tried both of those methods. I just tried to install it using the SketUcation Store Plugin and it seems to work fine until I try to locate it. It's not in my Plugins folder or my Tools pallet.
                  C W Munro
                    If you are using the Sketchucation Plugin Store, just set the Author field to TIG and find it in the list there. Click on AutoInstall.
                    It won't show up in the Plugins menu. It shows up in Draw. And there is a toolbar you can display under the View>Toolbars menu. You may need to shut SketchUp down and restart it after installing it.
                    • cwmunroC
                      cwmunro
                      I just tried it again and it tells me that the file extension has been installed successfully and is now available for use. I cannot find it anywhere one the screen and when I look into the Window>Preferences>Extension Folder it is not listed at all.
                      C W Munro
                      • cwmunroC
                        cwmunro
                        Thanks Dave R!
                        I just found it and I feel thoroughly like an idiot now.
                        Thanks so much for you assistance!
                        C W Munro
                        • cwmunroC
                          cwmunro
                          Okay, the plugin works VERY well. Just one question though - How do I set a custom line style? I have tried the dashed lines and when I set the line width to .05 (which is the same line weight of the SU default line) the dashes get so small they appear to be one "thin" line. I need to make a custom dashed line with dashes that are about 4" long with 4" spaces (@ 1/4" scale). Any help would be appreciated.
                          C W Munro
                          • TIGT
                            Try various pattern permutations of dots, dashes and spaces ...
                            etc...
                            • G
                              ghostanywhere
                              Hello, I can't find the zip version for download, pls help
                              • cottyC
                                cotty
                                In the first post you will find a link to the plugin store where you can download the rbz-file. If you need a zip-file, you can rename it to zip-ending, but it is recommended to use the extension installation button or even better the sketchucation tools for installation.
                                my SketchUp gallery
                                • P
                                  pohlovec
                                  about 2D Fillet Tool
                                  I would like to change the default count of segment from 18 to 6.
                                  Can I somehow modify the file 2DfilletTool.rb?
                                  I tried it, but without result.
                                  Is there any option???
                                  Thx
                                  • TIGT
                                    You change the setting when activating the tool - by typing 6s [+<enter>] - as well as then say 100 [+<enter>] for the radius... then both of those settings are remembered with the model on a save, and reused across sessions.
                                    IF you want to change the script's coding...
                                    Use a plain-text editor - say Notepad/Notepad++ or TextWrangler[for MAC] - never a wordprocessor!
                                    Edit the file: ../Plugins/2DTools/2DfilletTool.rb
                                    Then find the following two lines: #70
                                    @segs=**18** if not @segs
                                    which becomes: @segs=**6** if not @segs
                                    and then #89
                                    @segs=Sketchup.active_model.get_attribute("2Dtools","fillet_segments",**18**)
                                    which becomes: @segs=Sketchup.active_model.get_attribute("2Dtools","fillet_segments",**6**)
                                    [TIP: If your text-editor has no line-numbering then you can search/find for the two occurrences of " @segs="...]
                                    Now when opening a brand new model the default 2DfilletTool's segmentation is always 6s - although of course you can reset it to say 18s or whatever you desire on a per model basis. by typing the new value into the VCB, such settings are remembered with each model on save - here as the attribute 2Dtools : fillet_segments...
                                    • robertWanR
                                      robertWan
                                      How to avoid this error? After the fillet lines are not parallel.
                                      2D Fillet
                                      Robert
                                      2DFillet.skp
                                      • TIGT
                                        @RobertWan
                                        I think this is down to tiny geometry again.
                                        SketchUp tolerance is ~1/1000"
                                        3mm is approaching that for the tiny facet sizes and their end points being considered equivalent...
                                        When the fillet tool rounds a corner like that there should be no residual lines anyway!
                                        The faceted arc has a first/last section at such a shallow angle to the side that the point is confused.
                                        If you delete the two edges and redraw them, being sure to snap to the ends of the fillet-arc, then they will be 3mm long and dimension correctly.
                                        See the zoomed view attached...
                                        • J
                                          jzar_kobi
                                          Having trouble with the textures....just don't fill. I've picked the texture from the scene and used the bucket tool....worked that way but not from the 2d hatching tool. The 2d line tool....love it. It did jump it's xyz position when it when over a 3D object. Moved in the positive z direction to float above the cube. I'll post some of my experiments if you'd like them.
                                          • T
                                            trackbuilder
                                            I am new to installing Plugins for SU, so I downloaded the Plugin from SketchUcation and it installed correctly. I downloaded the 2D Tools plugin from TIG and it appeared to load properly. However, once it was installed, this message came up...
                                            Permission denied - C:/Program Files/SketchUp/SketchUp 2013/Plugins/2Dtools/2Dtidied.txt
                                            Error Loading File 2D#.rb
                                            Is this a setting conflict with my PC or what? Please help...
                                            I've installed SU Pro v 2013, on OS Windows 7
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 31
                                            • 39
                                            • 40
                                            • 29 / 40
