    [Plugin] 2D Tools
    791 Posts 178 Posters 725.8k Views 177 Watching
    • TIGT Online
      The 2dHatching tool is intended to be used specifically as part of the 2dTools set.
      It's not really intended for use as a general 3d hatching tool...
      I recommend you forget trying to use it for something it wasn't intended for...
      Instead think about making some new materials that do what you want...
      The PATT.. image files this tool uses [found inside the ../Plugins/2dTools/Hatching subfolder etc] can be used quite separately as a new texture for any material you may want to make yourself, and you can also 'scale' that material's texture in the material editor to suit your needs.
      You can now have several materials using the same image at different 'scales', if desired.
      Then you can just 'paint' faces etc with the appropriate material as needed.
      Once they are made you can save these materials as external SKM files, which, when placed in folder within the Materials folder, can be accessed from within any SKP for reuse...
      Each image is duplicated within each exported SKM and it is also scaled in use as specified in your editing.
      • TIGT Online
        To save one material externally right-click its icon in the Materials Browser and use the appropriate item...
        OR to export ALL of the Model's materials en mass use the pop-out menu to save as a collection...
        To add a new material that will be initially based on an existing one, select the material to base it on, then click the '+' button to make a new material - rename it as needed, adjust colors, texture size etc...
        • brookefoxB Offline
          brookefox
          Thank you much.
          ~ Brooke
            brookefox
            but your instructions say
            ....It will also use an existing Face at the picked-point...with the ‘PATTern’ material applied.
            Thank you, TIG. In spite of what you advise, I have found the tool to be useful for my purposes and I am grateful for that. This may be due to my ignorance of and lack of experience with the native texturing processes, though I hope not.
            I need to learn how to do this.
            ~ Brooke
            • G Offline
              Galvax
              Does the "Custom Style" feature work on the line style editor? Nothing happens when I select that option and hit okay. Your instructions say that another window is supposed to open, but I don't see it.
              • TIGT Online
                Please explain your steps exactly...
                The explanation in the Help file is correct.
                If in the first dialog you choose '< Custom Style >' you should get a second dialog in which name your own style and to design its 'pattern'.
                On OK the first dialog reopens and now you must scroll the list of styles to select your new 'MyStyle' [or whatever you've called it].
                That's now the active style.
                If you run it with the Ruby Console open do you get errors ?
                  skirkster
                  TIG- thanks for the great plugin.
                  When I'm attempting to use the 2D line style, every time I click a line, it disappears, but the effect (dashes) show up underneath my model. Do the faces that the effect are on have to be deleted?
                  • TIGT Online
                    If you have a face and you 'style' one of its edges that styled-edge appears on the front of the face.
                    If you have made the face 'looking the wrong way' [i.e. down] then the styled-edge appears "below" the face !
                    To check for the correct orientation of faces use View > Monochrome mode - front-faces show off-white whilst back-faces show blue/gray, depending on your Sketchup-Style settings [it's a good idea to use a Sketchup-Style with a distinctive back-face color and view your model from time to time in Monochrome to check for proper face orientation...].
                    To confuse you... every face you draw on the ground is made by Sketchup looking downwards, because it assumes you will want to PushPull it upwards, for which it would be then suitably oriented; BUT if you want the face to be just a plain face, on the ground you will need to 'reverse' it - to do this Select the face and in the right-click context-menu use 'Reverse' to flip the face the right way round - this is a useful tool to ensure good modeling practices.
                    Within 'plain' Sketchup face orientation is often of little consequence since materials can be applied to both fronts and backs of faces... but as soon as you start to use tools that depend on face orientation [like this one, or more critically most rendering tools that expect 'fronts' and only render 'front' materials], then it's very important that the front is the face-front and the back is the face-back !
                    • micioneM Offline
                      micione
                      I need help with 2D Fillet tool:
                      Of a rectangle, the first curved connection between the two sides work well but the second, sends SketchUp BUG SPLAT.
                      It works well, however, the option "chamfer".
                      What can I do?
                      thanks
                      • TIGT Online
                        I am surprised. 😕
                        Many users have never experienced this.
                        I cannot reproduce it.
                        What size are the lines being filleted and what radius fillet and segmentation are you trying to impose?
                        Can you post a simple SKP that you know will fail for you, and details of the settings you have been trying...
                        Then we can test it to see if it's something specific to that geometry or just your setup.
                        It sounds unlikely that it's a clash with other scripts which might have ill-advisedly overwritten some base class in Sketchup like 'group.copy', because related tools like 'chamfer' seem unaffected...
                        Have you recently installed any scripts that might clash?
                        If so try temporarily disabling them and retest the fillet-tool...
                        • micioneM Offline
                          micione
                          I'm looking for what may have been affected.
                          I attach the file.
                          thanks
                          200mm.skp
                          • TIGT Online
                            As you can see the 200mm radius fillet worked fine.
                            Are you picking near the ends of the lines [but not on the vertices]?
                            Do you have a list of your installed plugins?
                            • micioneM Offline
                              micione
                              I enclose a list of installed plugins.
                              He has also stopped working "Follow me rotate". (from wikii)
                              thanks
                              PlugIn.zip
                              • micioneM Offline
                                micione
                                I uninstalled the plugin Fredo's "Additionalplugin folder".
                                There was a conflict.
                                Now run "Instant roof", by Chuck valiArchitects and "FollowMe and Rotate" by
                                Wikii.
                                I downloaded and reinstalled "2D Tools" but the problem with "fillet" is still present.
                                  lapx
                                  Can 2d tools work for any plane? It would be nice if one could lock the 2d tools to any plane.Is this what surface tools tries to do? You should be able to lock your plane to draw in 2d on any surface. Then any drawing would be on the surface as 2d. i know it works on in the xy plane.
                                  It would be handy if it worked on surface of any set plane.
                                  • TIGT Online
                                    Some tools do work in any plane [e.g. Fillet].
                                    You can reset the z-height for many other 2dTools.
                                    Fredo's 'Tools on Surface' will also draw most basic shapes on any surface too...
                                    With the advent of LayOut further development of 2dTools is unlikely...
                                    • micioneM Offline
                                      micione
                                      I found the plugin that creates a conflict with 2D Tools / fillet: it is "Driving Dimension" by LEDAS.
                                      Now everything works fine.
                                      Thank you.
                                      Roberto
                                      • TIGT Online
                                        Thank you.
                                        Roberto
                                        Sorry I didn't spot the ldd.rbs in the list. It is one of the tools implicated in a lot of clashes with legit tools because I suspect that it ill-advisedly changes some base class/methods for groups. I have previously written to the author asking them to fix it.
                                        Note that some other similarly implicated scripts include SketchyPhysics, Matchbox, SunTools[?] etc
                                        • micioneM Offline
                                          micione
                                          TIG,
                                          thanks again.
                                          Maybe we should create a "black list" of all the scripts that create conflict.
                                          And make it visible on the forum.
                                          I also write to LEDAS for this problem.
                                          I must warn FREDO6, that his tool "additionalplugin foder" creates
                                          conflict with other plugins? (For example with "instant roof" and FollowMe rotate ")
                                          regards,
                                          Roberto
                                          • micioneM Offline
                                            micione
                                            TIG,
                                            sorry but I can not send and receive private messages by using
                                            the user control panel.
                                            What should I do to activate this feature?
                                            my username: micione
                                            my email: robertopadulazzi @ alice.it
                                            My real name: Roberto
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 39
                                            • 40
                                            • 22 / 40
