    [Plugin] 2D Tools
    791 Posts 178 Posters 807.5k Views 177 Watching
      skirkster
      TIG- thanks for the great plugin.
      When I'm attempting to use the 2D line style, every time I click a line, it disappears, but the effect (dashes) show up underneath my model. Do the faces that the effect are on have to be deleted?
        If you have a face and you 'style' one of its edges that styled-edge appears on the front of the face.
        If you have made the face 'looking the wrong way' [i.e. down] then the styled-edge appears "below" the face !
        To check for the correct orientation of faces use View > Monochrome mode - front-faces show off-white whilst back-faces show blue/gray, depending on your Sketchup-Style settings [it's a good idea to use a Sketchup-Style with a distinctive back-face color and view your model from time to time in Monochrome to check for proper face orientation...].
        To confuse you... every face you draw on the ground is made by Sketchup looking downwards, because it assumes you will want to PushPull it upwards, for which it would be then suitably oriented; BUT if you want the face to be just a plain face, on the ground you will need to 'reverse' it - to do this Select the face and in the right-click context-menu use 'Reverse' to flip the face the right way round - this is a useful tool to ensure good modeling practices.
        Within 'plain' Sketchup face orientation is often of little consequence since materials can be applied to both fronts and backs of faces... but as soon as you start to use tools that depend on face orientation [like this one, or more critically most rendering tools that expect 'fronts' and only render 'front' materials], then it's very important that the front is the face-front and the back is the face-back !
        • micioneM
          micione
          I need help with 2D Fillet tool:
          Of a rectangle, the first curved connection between the two sides work well but the second, sends SketchUp BUG SPLAT.
          It works well, however, the option "chamfer".
          What can I do?
          thanks
            I am surprised. πŸ˜•
            Many users have never experienced this.
            I cannot reproduce it.
            What size are the lines being filleted and what radius fillet and segmentation are you trying to impose?
            Can you post a simple SKP that you know will fail for you, and details of the settings you have been trying...
            Then we can test it to see if it's something specific to that geometry or just your setup.
            It sounds unlikely that it's a clash with other scripts which might have ill-advisedly overwritten some base class in Sketchup like 'group.copy', because related tools like 'chamfer' seem unaffected...
            Have you recently installed any scripts that might clash?
            If so try temporarily disabling them and retest the fillet-tool...
            πŸ˜•
            • micioneM
              micione
              I'm looking for what may have been affected.
              I attach the file.
              thanks
              200mm.skp
                As you can see the 200mm radius fillet worked fine.
                Are you picking near the ends of the lines [but not on the vertices]?
                Do you have a list of your installed plugins?
                • micioneM
                  micione
                  I enclose a list of installed plugins.
                  He has also stopped working "Follow me rotate". (from wikii)
                  thanks
                  PlugIn.zip
                  • micioneM
                    micione
                    I uninstalled the plugin Fredo's "Additionalplugin folder".
                    There was a conflict.
                    Now run "Instant roof", by Chuck valiArchitects and "FollowMe and Rotate" by
                    Wikii.
                    I downloaded and reinstalled "2D Tools" but the problem with "fillet" is still present.
                    • L
                      lapx
                      Can 2d tools work for any plane? It would be nice if one could lock the 2d tools to any plane.Is this what surface tools tries to do? You should be able to lock your plane to draw in 2d on any surface. Then any drawing would be on the surface as 2d. i know it works on in the xy plane.
                      It would be handy if it worked on surface of any set plane.
                        Some tools do work in any plane [e.g. Fillet].
                        You can reset the z-height for many other 2dTools.
                        Fredo's 'Tools on Surface' will also draw most basic shapes on any surface too...
                        With the advent of LayOut further development of 2dTools is unlikely...
                        • micioneM
                          micione
                          I found the plugin that creates a conflict with 2D Tools / fillet: it is "Driving Dimension" by LEDAS.
                          Now everything works fine.
                          Thank you.
                          Roberto
                            Thank you.
                            Roberto
                            Sorry I didn't spot the ldd.rbs in the list. It is one of the tools implicated in a lot of clashes with legit tools because I suspect that it ill-advisedly changes some base class/methods for groups. I have previously written to the author asking them to fix it.
                            Note that some other similarly implicated scripts include SketchyPhysics, Matchbox, SunTools[?] etc
                            • micioneM
                              micione
                              TIG,
                              thanks again.
                              Maybe we should create a "black list" of all the scripts that create conflict.
                              And make it visible on the forum.
                              I also write to LEDAS for this problem.
                              I must warn FREDO6, that his tool "additionalplugin foder" creates
                              conflict with other plugins? (For example with "instant roof" and FollowMe rotate ")
                              regards,
                              Roberto
                              • micioneM
                                micione
                                TIG,
                                sorry but I can not send and receive private messages by using
                                the user control panel.
                                What should I do to activate this feature?
                                my username: micione
                                my email: robertopadulazzi @ alice.it
                                My real name: Roberto
                                  If you click on thisCapture.PNG and then this1.PNG you should get a new blank post, fill it in with title, text.attachments and recipients...
                                  If you click on the PM icon below a post's author's details/avatar2.PNG, it will open a new post, with the same title and the recipient filled in3.PNG
                                  What is your difficulty precisely ?
                                  • micioneM
                                    micione
                                    TIG,
                                    I found the problem.
                                    This is Google Chrome / instant translator of the page.
                                    By disabling this feature, it seems all right.
                                    Thank you.
                                    Roberto
                                    • micioneM
                                      micione
                                      TIG,
                                      I talked to "LEDAS" the problem of "driving dimension" that creates conflicts
                                      with other plugins (specifically with 2D Tools).
                                      I responded thus:
                                      Ilya Tatarnikov 2012-05-11 05:58 UTC
                                      Hello Roberto,
                                      We confirm the problem and trying to investigate reasons and find solution.
                                      For more efficient work I'm recommending you to contact also to 2Dtools development team.
                                      They maybe got such request earlier and find some solution.
                                      best regards,
                                      Ilya Tatarnikov
                                        It is not just my tools... but several tools made by others, that use legitimate Sketchup API class/methods [usually about 'groups'] that ought to 'return' certain values, but which LEDAS's tool overwrite ill-advisedly, thereby breaking several legit tools to enable his own !
                                        I have tried to circumvent several standard 'group' methods to avoid clashes like this [SketchyPhysics and others also do similar screw ups!], but there is a limit to what I can do. If LEDAS's code was not compiled it would be easy to find the issues, I have PM'd him about this ages ago, but I think he is just being obdurate, because his code works, 'so screw everyone else...'
                                        πŸ˜’
                                          Bah! Humbug!
                                          Overriding the base classes in SketchUp is a big no-no. Leaving it to others is just extra bad manners!
                                            Registrationware as well - don't like it when I have to give out my full details just to try a software...
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 39
                                            • 40
                                            • 22 / 40
