    [Plugin] 2D Tools
    791 Posts 178 Posters 770.8k Views 177 Watching
      I am surprised. πŸ˜•
      Many users have never experienced this.
      I cannot reproduce it.
      What size are the lines being filleted and what radius fillet and segmentation are you trying to impose?
      Can you post a simple SKP that you know will fail for you, and details of the settings you have been trying...
      Then we can test it to see if it's something specific to that geometry or just your setup.
      It sounds unlikely that it's a clash with other scripts which might have ill-advisedly overwritten some base class in Sketchup like 'group.copy', because related tools like 'chamfer' seem unaffected...
      Have you recently installed any scripts that might clash?
      If so try temporarily disabling them and retest the fillet-tool...
      πŸ˜•
      • micioneM
        micione
        I'm looking for what may have been affected.
        I attach the file.
        thanks
        200mm.skp
          As you can see the 200mm radius fillet worked fine.
          Are you picking near the ends of the lines [but not on the vertices]?
          Do you have a list of your installed plugins?
          • micioneM
            micione
            I enclose a list of installed plugins.
            He has also stopped working "Follow me rotate". (from wikii)
            thanks
            PlugIn.zip
            • micioneM
              micione
              I uninstalled the plugin Fredo's "Additionalplugin folder".
              There was a conflict.
              Now run "Instant roof", by Chuck valiArchitects and "FollowMe and Rotate" by
              Wikii.
              I downloaded and reinstalled "2D Tools" but the problem with "fillet" is still present.
              • L
                lapx
                Can 2d tools work for any plane? It would be nice if one could lock the 2d tools to any plane.Is this what surface tools tries to do? You should be able to lock your plane to draw in 2d on any surface. Then any drawing would be on the surface as 2d. i know it works on in the xy plane.
                It would be handy if it worked on surface of any set plane.
                  Some tools do work in any plane [e.g. Fillet].
                  You can reset the z-height for many other 2dTools.
                  Fredo's 'Tools on Surface' will also draw most basic shapes on any surface too...
                  With the advent of LayOut further development of 2dTools is unlikely...
                  • micioneM
                    micione
                    I found the plugin that creates a conflict with 2D Tools / fillet: it is "Driving Dimension" by LEDAS.
                    Now everything works fine.
                    Thank you.
                    Roberto
                      Thank you.
                      Roberto
                      Sorry I didn't spot the ldd.rbs in the list. It is one of the tools implicated in a lot of clashes with legit tools because I suspect that it ill-advisedly changes some base class/methods for groups. I have previously written to the author asking them to fix it.
                      Note that some other similarly implicated scripts include SketchyPhysics, Matchbox, SunTools[?] etc
                      • micioneM
                        micione
                        TIG,
                        thanks again.
                        Maybe we should create a "black list" of all the scripts that create conflict.
                        And make it visible on the forum.
                        I also write to LEDAS for this problem.
                        I must warn FREDO6, that his tool "additionalplugin foder" creates
                        conflict with other plugins? (For example with "instant roof" and FollowMe rotate ")
                        regards,
                        Roberto
                        • micioneM
                          micione
                          TIG,
                          sorry but I can not send and receive private messages by using
                          the user control panel.
                          What should I do to activate this feature?
                          my username: micione
                          my email: robertopadulazzi @ alice.it
                          My real name: Roberto
                            If you click on thisCapture.PNG and then this1.PNG you should get a new blank post, fill it in with title, text.attachments and recipients...
                            If you click on the PM icon below a post's author's details/avatar2.PNG, it will open a new post, with the same title and the recipient filled in3.PNG
                            What is your difficulty precisely ?
                            • micioneM
                              micione
                              TIG,
                              I found the problem.
                              This is Google Chrome / instant translator of the page.
                              By disabling this feature, it seems all right.
                              Thank you.
                              Roberto
                              • micioneM
                                micione
                                TIG,
                                I talked to "LEDAS" the problem of "driving dimension" that creates conflicts
                                with other plugins (specifically with 2D Tools).
                                I responded thus:
                                Ilya Tatarnikov 2012-05-11 05:58 UTC
                                Hello Roberto,
                                We confirm the problem and trying to investigate reasons and find solution.
                                For more efficient work I'm recommending you to contact also to 2Dtools development team.
                                They maybe got such request earlier and find some solution.
                                best regards,
                                Ilya Tatarnikov
                                  It is not just my tools... but several tools made by others, that use legitimate Sketchup API class/methods [usually about 'groups'] that ought to 'return' certain values, but which LEDAS's tool overwrite ill-advisedly, thereby breaking several legit tools to enable his own !
                                  I have tried to circumvent several standard 'group' methods to avoid clashes like this [SketchyPhysics and others also do similar screw ups!], but there is a limit to what I can do. If LEDAS's code was not compiled it would be easy to find the issues, I have PM'd him about this ages ago, but I think he is just being obdurate, because his code works, 'so screw everyone else...'
                                  πŸ˜’
                                    Bah! Humbug!
                                    Overriding the base classes in SketchUp is a big no-no. Leaving it to others is just extra bad manners!
                                      Registrationware as well - don't like it when I have to give out my full details just to try a software...
                                        This subject of the problems Sketchy Physics, Driving Dimensions and others cause comes up frequently. The authors have been approached more than once with requests to fix them but have never done so. It would appear to me that they have no interest in doing so. Perhaps there should be a sticky listing these plugins that are written so they cause plugins that are properly written to fail. A comment could be included to the effect of, "Understand that if you choose to use these plugins, they may cause other plugins to fail. Use these plugins at your own risk."
                                          I've been looking into LDD - When it's installed pretty much all the base classes is flooded with LDD methods. Even the root Object!!
                                          Object.ancestors [Object, LDD, Kernel]
                                          An LDD module is added to the Object class.
                                          And just the constants that LDD adds:
                                          LDD.constants ["SKETCH_TOOL", "PI", "GENERAL_CASE_LINES", "LDDEntitiesObserver", "EQUAL_LINES", "PUTS_IN_RUBY_CONSOLE", "CONSTRAINTS_LIMIT", "ENTITY_OBSERVERS", "LDDFaceFaceAngleConstraint", "LDDOptions", "LDD_return_values", "SKETCHUP_VERSION", "LDDVertexVertexDistanceConstraint", "ROTATE_TOOL", "Driving_Dimension", "LDD_constraints_types", "LDDVertexFaceDistanceConstraint", "CAMERA_ZOOM_TOOL", "ARC_TOOL", "LDDModelConstraints", "LDD_constraints_typesVersion_0_2", "Driving_Dimensions_Tool", "LDDFaceInformationForInferredConstraints", "LDDAppObserver", "LDDEdgeEdgeDistanceConstraint", "LDDLabelsObserverForVertex", "LEDAS_DRIVING_DIMENSIONS_BUILD", "INTERSECTING_LINES", "LDDFixationConstraint", "LDDEdgeFaceAngleConstraint", "CAMERA_ORBIT_TOOL", "DRIVING_DIMENSIONS_FIXATION_TOOL_CURSOR", "VERTEX_OBSERVERS", "LDDEdgeLengthConstraint", "LDDModelObserver", "RECTANGLE_TOOL", "LDDPreConstraint", "FULL_LOG", "LDDDrDiTextObserver", "LDDSet", "LDDEmptyConstraint", "DRIVING_DIMENSIONS_CALCULATING_CURSOR", "LDDEdgeEdgePlanarAngleConstraint", "PUSH_PULL_TOOL", "PARALLEL_LINES", "LDDDrDiEntityObserver", "LDDFaceFaceDistanceConstraint", "LDDToolsObserver", "LDD_PRO", "LDDVertexEdgeDistanceConstraint", "MOVE_TOOL", "LEDAS_DRIVING_DIMENSIONS_VERSION", "LDD_DIR", "LDDDataForSketchupModel", "LDDSelectionObserver", "DEG_SIGN", "LDDConstraint", "LDDEdgeFaceDistanceConstraint", "CAMERA_DOLLY_TOOL", "DRIVING_DIMENSIONS_TOOL_CURSOR", "LDDArcCurveRadiusConstraint", "CIRCLE_TOOL", "INTERSECTING_LINES_WITH_COMMON_FACE", "LDDDrDiGroupObserver", "LDDEdgeEdgeAngleConstraint", "LDDObserversHash", "LDDKEY", "OFFSET_TOOL", "Driving_Dimensions_Fixation_Tool"]
                                          Notice that even a PI constant is added - so now it's available to all classes instead of Math::PI. What a mess...
                                          LDD really do not play nicely with the shared SketchUp plugin environment at all! 😑 😑
                                          • C
                                            chickbiker
                                            TIG - how does one go about acquiring a copy of your 2D tools? Looks like just the fix I need. Assuming it works with the free version... http://forums.sketchucation.com/posting.php?mode=reply&f=323&t=22091#
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 24
                                            • 39
                                            • 40
                                            • 22 / 40
