    [Plugin] extrudeEdgesByLathe
    104 Posts 43 Posters 79.1k Views 43 Watching
      Here's v2.1, with the ES lingvo file updated by Defisto.
      http://forums.sketchucation.com/viewtopic.php?p=184477#p184477
        Here's v2.2 - a typo preventing the Plugins Menu item working has been corrected. 😳
          Here's v2.3 - FR lingvo file updated by Pilou...
          • mitcorbM Offline
            mitcorb
            Feedback:
            The Plugins Dropdown Menu commands for the extrusion suite appear to be operational with your latest revisions.
            Thank you, again.
            • ArcA Offline
              Arc
              Here is Chinese lingvo file by me from http://www.SuBlog.net
              δΈ­ζ–‡ζ±‰εŒ–εŒ…
                Arc
                Thank you.
                I shall include it in the next update - meanwhile any Chinese users can download it now and unzip it into their ../Plugins/TIGtools/ folder.
                I note you have called it 'extrudeEdgesByLatheCN.lingvo' BUT I think it should be 'extrudeEdgesByLatheZH-CN.lingvo' ?
                I think locale for a Chinese PC is ZH-CN ?
                If it is then the file needs renaming to suit that: otherwise the locale test won't find it and the text will default to English[US]...
                To check this please type [or copy/paste] in the Ruby Console Sketchup.get_locale.upcase, for you it should return ZH-CN ? For me it'd be EN-US. Whatever it returns is what the 'suffix' on the file name should be...
                Thanks for the help πŸ€“
                  Request
                  "A zoom extents" before the first dialog box for have all the object on the screen for an more easy answer πŸ˜„
                  (or a zoom wkindow of the generated object)
                  Maybe the same for the other EEb...
                  • ArcA Offline
                    Arc
                    @tig said:
                    Arc
                    Thank you.
                    It's not auto use extrudeEdgesByLatheZH-CN.lingvo file. I usually change the filename and overwhite extrudeEdgesByRailsEN-US.lingvo file.
                      Aha ! πŸ’­
                      That way you can even have a EN-US locale but with Chinese text...
                      I know Pilou does that with the FR version...
                      However if you have your locale set to something other than EN-US then any lingvo file in your desired language needs to be named ScriptNameLOCALE.lingvo where LOCALE= your-locale code obtained from using Sketchup.get_locale.upcase in the Ruby Console.
                      This way you can have an EN-US locale but map your desired language lingvo files using that suffix... then you can use SUp even in Esperanto [EO] if you have a translation !
                      πŸ€“
                        Request
                        I thought of that but as you can orbit whilst picking the curves you CAN ensure you can see everything before committing to it...
                        One of my longer term plans is/was to add a combined web-dialog to the end so you could still orbit/pan/zoom to view the mesh and change the settings and when satisfied press OK... πŸ€“
                          Here's v2.4 - FR lingvo file update by Pilou.
                          • U Offline
                            unclex
                            wonderful
                            • jeff hammondJ Offline
                              jeff hammond
                              hey Tig,
                              here's a request for the lathe tool to tuck away for those rainy days πŸ˜„
                              your extrusion suite has radically changed the way i model in SU as i very rarely use the followme tool anymore.. lathe pretty much fixes the multiple problems i encounter with
                              anyway, the only problem i have with lathe.rb is when i'm trying to rotate to an approximate degree (ie - **~**74Β° etc.).. would it be possible to incorporate a protractor of sorts that can measure the actual angle instead of typing it in?
                              (see attached skp for example situation)
                              thanks!
                              latheQ.skp
                              dotdotdot
                                As you know [sssh πŸ˜‰ ] I'm looking at some other related extrusion tools and these will involve a protractor to rotate stuff with before making the shapes - so when that's working perhaps I can bolt it on to EEbyLathe πŸ˜„
                                  jeff hammond
                                  sweet!
                                  i do have a decent workaround for now that still gives me the accuracy i'm after so i'll just wait patiently (with fingers crossed πŸ˜„ )
                                  dotdotdot
                                    balloon
                                    Thank you Tig! Much appreciated!!!
                                      New version added http://forums.sketchucation.com/viewtopic.php?p=184477#p184477
                                        DIEGO-RODRIGUEZ
                                        Hi Tig. excellent update.
                                        I attach the file to Spanish translation.
                                        add the missing lines.
                                        Two suggestions:
                                        • Please delete the sound it makes when we choose the tool. is very annoying.
                                        • The command Ctrl + z does not work properly.
                                        • Would be more practical angle by reference to generate 0 to 360. instead of 0 to 180 and 180 to 360
                                        extrudeEdgesByLatheES.rar
                                          http://forums.sketchucation.com/viewtopic.php?p=184477#p184477 is the latest version with new lingvos.
                                            Two suggestions:
                                            I posted the new ES lingvo file before I read this - can you please read it and [re]advise...
                                            The 'beep' sound it makes is a UI.beep - edit the file and find that line in the code and add a # at the start of the line to stop it loading.
                                            It is not Ctrl+Z for the angle-direction 'toggle' - it's < Ctrl> alone...
                                            I know it would be better to have 0 to 360 degrees... BUT its coding has missed me so far - hence the 0-180 & 180-360, with a toggle <Alt>...
                                            • 6
                                            • 4 / 6
