    Sketchup Window too Small at Startup
    5 Posts 4 Posters 914 Views 4 Watching
    • J
      jteselle
      This is an old problem -- just wondering if anyone has a solution.
      I am using SketchUp 7 on a Windows PC, with XP. I've been using SketchUp for a long time (since version 2) and have noticed this problem from time to time.
      I set up my window size maximized on my screen, with toolbars where I want them. When I exit and then restart, sometimes the application window opens correctly (full size) and sometimes it opens up small. I can't see any logic to it. When it opens small, I have to reposition all the toolbars, because they have been moved around to fit on the small window.
      Any ideas as to how to fix this? I am using a template file when I start up.
      • R
        remus
        If you resize the 'small' version of the SU window to near full screen (by dragging a corner, not maximising it) SU should remember this size and so not mess up your plugins when it decides to open in small mode.
        Ive never been able to work out what makes SU open in small mode though, as you say it seems pretty random.
        • J
          jteselle
          I think I may have figured it out -- after years of dealing with it, making the post here motivated me to start thinking...
          My template that I use was created some time ago. Since then I have added a couple of plug-ins that add toolbars. By replacing the template with a new version that has all the new toolbars where I want them, the problem seems to go away (at least for now).
          Perhaps the extra toolbars were messing things up?
          Anyway, I hope this works from now on.
          • GaieusG
            There must be something else. The template is just a good, old, plain skp file and has (or at least should have πŸ˜’ ) nothing to do with the SU window.
            • C
              Charlie__V
              Have you tried right clicking on the shortcut and selecting run Maximized?
              Or is that what you are explaining you have done.
              Best,
              C
              Rt.click shortcut
