    [Plugin] GhostComp - v1.4a - 31 Oct 18
    101 Posts 52 Posters 217.4k Views 52 Watching
      mwm5053
      Within the last month I installed Ghost Comp from the Sketchucation Plugin Store so I believe I have the latest ver.
      Great plugin works great but after hiding a GC I noticed it won't change back to regular comp. not sure why. Tried everything I could think of. Any help would be appreciated Thanks
      I apologize if this has been addressed already.
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        mwm5053
        I guess I should further explain what I did. I had a large component of grass that contained nested comps of grass to move and copy at one point I hide the GC while in GC visibility (cube) mode but when i unhide it, it would not return to regular comp.
        2011 iMac
        V2 Twilight
        • duanekempD Offline
          duanekemp
          Haven't tested yet, but... is this up-to-date with SU 2018?
          Duane Kemp
          Kemp Productions
          Puidoux, Switzerland
          Gallery:
          https://duanekemp.artstation.com/
          • fredo6F Offline
            fredo6
            Should work with SU2018.
            Make some tests with it before going to large models, and always keep a safe copy somewhere.
            Fredo
              duanekemp
              Thanks, will give it a go. As well, will share this in my FB groups to revive it. I had never heard of this before. Sounds like a practical plugin to have.
              Duane Kemp
              Kemp Productions
              Gallery:
                rv1974
                Fredo, may I humbly request an extra option for 2d squares instead of cubes?
                • jujuJ Offline
                  juju
                  Like CADup or just plain blank 2D squares / rectangles?
                    duanekemp
                    Before giving this a try, I had the delusion of grandeur that this would take a complicated geometry and make an easy, simple representation of the asset, making a component that would have a 2D+blocked or boxy proxy. Actually, it works that way for assets that are already boxy in nature. But, this sure did not like 3D people from Renderpeople... at all. Is there any hope of having the plugin pop a complicated geometry, chew it down to size and poop out a low poly boxy version?
                    Duane Kemp
                    Kemp Productions
                    Gallery:
                      rv1974
                      simple squares. you could take them to Max, collapse to single mesh, make it non-rendable and scatter objects with special software. But it's healthy for Sketchup too- very often ghost cubes are way too large
                        rv1974
                        Artisan has reduce poly count functionlity
                          rv1974
                          Many years I wanted to ask.. On some stage Ghostcomp puts ALL 'real' instances at file's origin point. Is it a bug or a feature?
                          The problem with those instances is if you'd delete them (at origin point) and run purge plugin there's no way to swap from ghost representation to 'real'.
                          • fredo6F Offline
                            fredo6
                            I'll see what I can do to force a conversion to real before a Purge.
                            • fredo6F Offline
                              fredo6
                              EDIT: I am not able to reproduce your problem. Could you elaborate. Thanks
                                rv1974
                                Haha.. Thats exactly the problem! I can't catch the moment when this Shashlik of components
                                get created @0,0,0
                                but I can PM the file where it's alreadythere. Eventually I get this in every project.
                                  rv1974
                                  Fredo, would it be hard to implement an extra display mode?
                                  Instead of cubes- a simple short line* of 5-10cm?
                                  Thank you for attention
                                  • The line must be aligned to original component of course and placed at insertion point.
                                    Alignent is crucial, thats why a quide point is not good.
                                    ** The goal of this thing: when exported to 3ds Max, all short lines (of the same kind) get merged onto one spline, and then Multiscatter plugin
                                    https://rendering.ru/multiscatter.html
                                    parametrically puts items (varied and properly aligned) on on every short segment.
                                    *** Even other users would benefit because frequently those pink cubes are too bulky and obstruct the main model
                                  • fredo6F Offline
                                    fredo6
                                    I am preparing a new extension to replace GhostComp, where you can replace an object by another one. That would be simpler and can use lines or whatever you like as a proxy.
                                    Fredo
                                    PS: so, I won't probably update GhostComp but release this new plugin instead.
                                      rv1974
                                      Amazing news! Would be happy to beta test ☀
                                      • fredo6F Offline
                                        fredo6
                                        Could you PM me an email address so that I can send it to you along with the doc.
                                        • ArisA Offline
                                          Aris
                                          Hi guys,
                                          Ghostcomp has become one of the most useful tools in my palette. I think its intention was to lighten the scenes for heavy objects but what I mostly use it for, is aligning non rectangular objects (make that sofa touch the wall/ arrange cushions on a sofa/ take dimensions from tubes etc etc.)
                                          My only problem is that for some reason it only works for components. at times this becomes frustrating and I have found myself many times converting a group into a component just to use ghostcomp.
                                          So, firstly I would want to ask (if anyone is listening) to give it the ability to create ghosts for groups and
                                          secondly, is there in the meanwhile something equivalent that replaces objects with their bounding box?
                                          Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
                                            You should read Fredo6's last post in this thread. He has a newer extension called FredoGhost. It will work with groups.
                                            • 6
                                            • 5 / 6
