    [Plugin] GhostComp - v1.4a - 31 Oct 18
    101 Posts 52 Posters 227.5k Views 52 Watching
    • ppoublanP
      ppoublan
      Things to know before calling :
      • those functions contain purge of unused component definitions and unused materials (after drawing a tree or its proxy). So to be called outside of a loop browsing each component definition, and list of definitions to be rebuild if needed after calling.
      • it contains start/commit, I do not know results of nesting multiple start/commit, so preferably call outside of start/commit.
        Needs v1.10 at least (not implemented in previous versions).
      Did not tested, but this should work :
      #To switch all trees to proxies
      if file_loaded?('3darcstudiotreemain.rb’)
      M3darcstudiotree.f3das_changealltoproxies
      #To switch all proxies to trees
      if file_loaded?(‘3darcstudiotreemain.rb’)
      M3darcstudiotree.f3das_redrawall
      • danchoD
        dancho
        Fredo6 I like your plugin but with SU2014 on windows7 I can't change
        from bounding box to wireframe mode, its always bounding box. Any suggestion?
        Sorry, I found a solution. First must to choose a type than create
        ghost and turn it on. Perfect 😆
        • fredo6F
          NEW RELEASE: GhostComp v1.2a - 20 Oct 14
          GhostComp 1.2a is required for the support of usernames with non-ascii characters in Sketchup 2014.
            salamon
            Hello is this working for sketchup 2015?
              rv1974
              I wish there was a-la multiscatter point display (maybe instead of points which can be accidentally deleted with 'Delete Guides' small tiny lines could make the same task). 😒
                @mrcitybuilder said:
                Is this plugin still functional? I downloaded it, unzipped it to the specified folder, checked my FredoLib was up to date, and SketchUp complains that there is no FredoLib to support GhostComp. I don't understand why.
                Why didn't you get the RBZ from the PluginStore, then install that ?
                Unzipping olde things and messing up with the results' installation went long ago - with v7...
                Ensure you have the latest LibFredo:
                http://sketchucation.com/pluginstore?pln=LibFredo6
                and then GhostComp:
                http://sketchucation.com/pluginstore?pln=GhostComp
                  MrCityBuilder
                  (Is this plugin still functional? I downloaded it, unzipped it to the specified folder, checked my FredoLib was up to date, and SketchUp complains that there is no FredoLib to support GhostComp. I don't understand why.)
                  SOLVED 😎
                    MrCityBuilder
                    Yeah, thanks - that did the trick. Ghostcomp now fully functional!
                    • L
                      lyvananhtoyo
                      thank very much. this help me to avoid the situation some imported component is much bigger than my model and make SU become very slow.
                        mwm5053
                        Within the last month I installed Ghost Comp from the Sketchucation Plugin Store so I believe I have the latest ver.
                        Great plugin works great but after hiding a GC I noticed it won't change back to regular comp. not sure why. Tried everything I could think of. Any help would be appreciated Thanks
                        I apologize if this has been addressed already.
                        2011 iMac
                        SU 2015 Pro, 2017 Make
                        V2 Twilight
                        macOS Sierra 10.12.5
                          mwm5053
                          I guess I should further explain what I did. I had a large component of grass that contained nested comps of grass to move and copy at one point I hide the GC while in GC visibility (cube) mode but when i unhide it, it would not return to regular comp.
                          2011 iMac
                          V2 Twilight
                          • duanekempD
                            duanekemp
                            Haven't tested yet, but... is this up-to-date with SU 2018?
                            Duane Kemp
                            Kemp Productions
                            Puidoux, Switzerland
                            Gallery:
                            https://duanekemp.artstation.com/
                            • fredo6F
                              Should work with SU2018.
                              Make some tests with it before going to large models, and always keep a safe copy somewhere.
                              • duanekempD
                                duanekemp
                                Thanks, will give it a go. As well, will share this in my FB groups to revive it. I had never heard of this before. Sounds like a practical plugin to have.
                                Duane Kemp
                                Kemp Productions
                                Gallery:
                                  rv1974
                                  Fredo, may I humbly request an extra option for 2d squares instead of cubes?
                                  • jujuJ
                                    juju
                                    Like CADup or just plain blank 2D squares / rectangles?
                                    • duanekempD
                                      duanekemp
                                      Before giving this a try, I had the delusion of grandeur that this would take a complicated geometry and make an easy, simple representation of the asset, making a component that would have a 2D+blocked or boxy proxy. Actually, it works that way for assets that are already boxy in nature. But, this sure did not like 3D people from Renderpeople... at all. Is there any hope of having the plugin pop a complicated geometry, chew it down to size and poop out a low poly boxy version?
                                      Duane Kemp
                                      Kemp Productions
                                      Gallery:
                                        rv1974
                                        simple squares. you could take them to Max, collapse to single mesh, make it non-rendable and scatter objects with special software. But it's healthy for Sketchup too- very often ghost cubes are way too large
                                          rv1974
                                          Artisan has reduce poly count functionlity
                                            rv1974
                                            Many years I wanted to ask.. On some stage Ghostcomp puts ALL 'real' instances at file's origin point. Is it a bug or a feature?
                                            The problem with those instances is if you'd delete them (at origin point) and run purge plugin there's no way to swap from ghost representation to 'real'.
                                            • 5 / 6
