    [Plugin] GhostComp - v1.4a - 31 Oct 18
    101 Posts 52 Posters 216.0k Views 52 Watching
      rv1974
      Many years I wanted to ask.. On some stage Ghostcomp puts ALL 'real' instances at file's origin point. Is it a bug or a feature?
      The problem with those instances is if you'd delete them (at origin point) and run purge plugin there's no way to swap from ghost representation to 'real'.
      • fredo6F Offline
        I'll see what I can do to force a conversion to real before a Purge.
        • fredo6F Offline
          EDIT: I am not able to reproduce your problem. Could you elaborate. Thanks
            rv1974
            Haha.. Thats exactly the problem! I can't catch the moment when this Shashlik of components
            get created @0,0,0
            but I can PM the file where it's alreadythere. Eventually I get this in every project.
              rv1974
              Fredo, would it be hard to implement an extra display mode?
              Instead of cubes- a simple short line* of 5-10cm?
              Thank you for attention
              • The line must be aligned to original component of course and placed at insertion point.
                Alignent is crucial, thats why a quide point is not good.
                ** The goal of this thing: when exported to 3ds Max, all short lines (of the same kind) get merged onto one spline, and then Multiscatter plugin
                https://rendering.ru/multiscatter.html
                parametrically puts items (varied and properly aligned) on on every short segment.
                *** Even other users would benefit because frequently those pink cubes are too bulky and obstruct the main model
              • fredo6F Offline
                I am preparing a new extension to replace GhostComp, where you can replace an object by another one. That would be simpler and can use lines or whatever you like as a proxy.
                PS: so, I won't probably update GhostComp but release this new plugin instead.
                  rv1974
                  Amazing news! Would be happy to beta test β˜€
                  • fredo6F Offline
                    Could you PM me an email address so that I can send it to you along with the doc.
                    • ArisA Offline
                      Aris
                      Hi guys,
                      Ghostcomp has become one of the most useful tools in my palette. I think its intention was to lighten the scenes for heavy objects but what I mostly use it for, is aligning non rectangular objects (make that sofa touch the wall/ arrange cushions on a sofa/ take dimensions from tubes etc etc.)
                      My only problem is that for some reason it only works for components. at times this becomes frustrating and I have found myself many times converting a group into a component just to use ghostcomp.
                      So, firstly I would want to ask (if anyone is listening) to give it the ability to create ghosts for groups and
                      secondly, is there in the meanwhile something equivalent that replaces objects with their bounding box?
                      Not a native speaker, point out my spelling (or other) mistakes, I won't be offended!!!
                        You should read Fredo6's last post in this thread. He has a newer extension called FredoGhost. It will work with groups.
                          rv1974
                          I Think I managed to catch the bug:
                          1. Staying in Scene1: Enter context, select desired component (donut) make a ghost, exit context.
                          2. Go to Scene 2. Ghost dummy plus original donut geometry created at 0,0,0.
                            The file PM'd.
                          • 5 / 6
