    [Plugin] GhostComp - v1.4a - 31 Oct 18
    101 Posts 52 Posters 230.5k Views 52 Watching
      @mrcitybuilder said:
      Is this plugin still functional? I downloaded it, unzipped it to the specified folder, checked my FredoLib was up to date, and SketchUp complains that there is no FredoLib to support GhostComp. I don't understand why.
      Why didn't you get the RBZ from the PluginStore, then install that ?
      Unzipping olde things and messing up with the results' installation went long ago - with v7...
      Ensure you have the latest LibFredo:
      http://sketchucation.com/pluginstore?pln=LibFredo6
      and then GhostComp:
      http://sketchucation.com/pluginstore?pln=GhostComp
        MrCityBuilder
        (Is this plugin still functional? I downloaded it, unzipped it to the specified folder, checked my FredoLib was up to date, and SketchUp complains that there is no FredoLib to support GhostComp. I don't understand why.)
        SOLVED 😎
          MrCityBuilder
          Yeah, thanks - that did the trick. Ghostcomp now fully functional!
          • L
            lyvananhtoyo
            thank very much. this help me to avoid the situation some imported component is much bigger than my model and make SU become very slow.
              mwm5053
              Within the last month I installed Ghost Comp from the Sketchucation Plugin Store so I believe I have the latest ver.
              Great plugin works great but after hiding a GC I noticed it won't change back to regular comp. not sure why. Tried everything I could think of. Any help would be appreciated Thanks
              I apologize if this has been addressed already.
              2011 iMac
              SU 2015 Pro, 2017 Make
              V2 Twilight
              macOS Sierra 10.12.5
                mwm5053
                I guess I should further explain what I did. I had a large component of grass that contained nested comps of grass to move and copy at one point I hide the GC while in GC visibility (cube) mode but when i unhide it, it would not return to regular comp.
                2011 iMac
                V2 Twilight
                • duanekempD
                  duanekemp
                  Haven't tested yet, but... is this up-to-date with SU 2018?
                  Duane Kemp
                  Kemp Productions
                  Puidoux, Switzerland
                  Gallery:
                  https://duanekemp.artstation.com/
                  • fredo6F
                    Should work with SU2018.
                    Make some tests with it before going to large models, and always keep a safe copy somewhere.
                    • duanekempD
                      duanekemp
                      Thanks, will give it a go. As well, will share this in my FB groups to revive it. I had never heard of this before. Sounds like a practical plugin to have.
                      Duane Kemp
                      Kemp Productions
                      Gallery:
                        rv1974
                        Fredo, may I humbly request an extra option for 2d squares instead of cubes?
                        • jujuJ
                          juju
                          Like CADup or just plain blank 2D squares / rectangles?
                          • duanekempD
                            duanekemp
                            Before giving this a try, I had the delusion of grandeur that this would take a complicated geometry and make an easy, simple representation of the asset, making a component that would have a 2D+blocked or boxy proxy. Actually, it works that way for assets that are already boxy in nature. But, this sure did not like 3D people from Renderpeople... at all. Is there any hope of having the plugin pop a complicated geometry, chew it down to size and poop out a low poly boxy version?
                            Duane Kemp
                            Kemp Productions
                            Gallery:
                              rv1974
                              simple squares. you could take them to Max, collapse to single mesh, make it non-rendable and scatter objects with special software. But it's healthy for Sketchup too- very often ghost cubes are way too large
                                rv1974
                                Artisan has reduce poly count functionlity
                                  rv1974
                                  Many years I wanted to ask.. On some stage Ghostcomp puts ALL 'real' instances at file's origin point. Is it a bug or a feature?
                                  The problem with those instances is if you'd delete them (at origin point) and run purge plugin there's no way to swap from ghost representation to 'real'.
                                  • fredo6F
                                    I'll see what I can do to force a conversion to real before a Purge.
                                    • fredo6F
                                      EDIT: I am not able to reproduce your problem. Could you elaborate. Thanks
                                        rv1974
                                        Haha.. Thats exactly the problem! I can't catch the moment when this Shashlik of components
                                        get created @0,0,0
                                        but I can PM the file where it's alreadythere. Eventually I get this in every project.
                                          rv1974
                                          Fredo, would it be hard to implement an extra display mode?
                                          Instead of cubes- a simple short line* of 5-10cm?
                                          Thank you for attention
                                          • The line must be aligned to original component of course and placed at insertion point.
                                            Alignent is crucial, thats why a quide point is not good.
                                            ** The goal of this thing: when exported to 3ds Max, all short lines (of the same kind) get merged onto one spline, and then Multiscatter plugin
                                            https://rendering.ru/multiscatter.html
                                            parametrically puts items (varied and properly aligned) on on every short segment.
                                            *** Even other users would benefit because frequently those pink cubes are too bulky and obstruct the main model
                                          • fredo6F
                                            I am preparing a new extension to replace GhostComp, where you can replace an object by another one. That would be simpler and can use lines or whatever you like as a proxy.
                                            PS: so, I won't probably update GhostComp but release this new plugin instead.
                                            • 5 / 6
