    Add a new plugin column
    7 Posts 5 Posters 1.9k Views 5 Watching
    • MALAISEM
      MALAISE
      Hi SU team
      A small suggestion, why not add a second "plugin" menu in the header ?
      : see picture
      MALAISE
      • GaieusG
        Wow! Where do you have space for modelling!? 😮
        • R
          remus
          I hate to think whatd happen if your toolbars got messed up, as well.
          Back on topic, I see where you are coming from, but i think a better solution for managing plugins is needed than simply adding another menu. Perhaps an 'official' version of rick's organiser plugin that would allow you to categorise your plugins.
          • MALAISEM
            MALAISE
            Thanks for playing attention.
            @Gaius : 😆 no problems, I draw on a 22'screen, (but of course not all the plugins are used on the same time...)
            @Remus : I found that the right lower corner could be use as an anchor. I was a little bit afraid using such a tool, I'm studying your idea 👍
            MALAISE
              I believe that the inside system of SU is "closed" for this sot of thing!
              It's a pitty because I have 3 "screen" plenty of plugs! 😒
              So i will need menu Plug II, and Plug III ! 😒
              • TIGT
                It's easy enough to add as many sub-menus into 'Plugins' (like RickW's) as you want... then you let the uneditable [compiled] scripts load into the menu at base level and the others as you choose into 1, 2, 3 etc - you just need to set up the sub-menus in an 'early loading' script - mine is called #.rb (which makes $submenu1, $submenu2 etc) and then you edit each script's menu call to load into $submenuX instead of the base level 'Plugins' - I keep mine sorted by...
                ConstructionLine Tools [or 'Guides' to Noobies] e.g. 'Grid'
                2D Tools e.g. '3-pointRectangle'
                3D Tools [Basic] e.g. 'Cylinder', 'Dome'
                3D Tools [Complex] e.g. 'StairMaker'
                2D Manipulation Tools e.g. 'Weld'
                3D Manipulation Tools e.g 'ExtrudePipeAlongLine'
                Camera/Image Tools e.g. 'BatchSceneExporter'
                Text Tools e.g 'IncrementingNumberText'
                Sandbox Tools e.g 'SimplifyContours'
                Other Tools e.g. 'Purge', 'ReGlue'
                Any compiled ones or other ones I have just downloaded or that I am testing appear in the base-level 'Plugins' menu...
                • MALAISEM
                  MALAISE
                  I like the idea you suggested TIG. It just takes a while before arranging all the plugins. In order not to misunderstanding, could you post just a "coded" example?
                  MALAISE
