    My model
    10 Posts 4 Posters 750 Views 4 Watching
    • K Offline
      kiddieboy12
      i have a super slow GPU, and i was thinking of upgrading to a raedon 3450, i got a 250watt psu
      ANYWAYS..I made a great model, but the problem is that it 32mb, and my gpu is very laggy, what makes my model 32mb?? a few minuites it was 20mb..
        remus
        The most likely culprit is large textures. Where appropriate downsize your textures as much as possible.
        Its also well worth using components for repeating geometry, this will cut down the file size a fair bit.
          Hi Noen,
          Beside what Remus says, go to your Window (menu) > Model info > Statistics and at the bottom of the dialog, press the "Purge all" (or what) button. Save and see how big your model is now.
          • K Offline
            kiddieboy12
            it takes me 5 minuites just to open and save it 😞
            • K Offline
              kiddieboy12
              also, im not done with my model so what does purge do?
              • K Offline
                kiddieboy12
                holy fak, it went from 32mb to 6 mb..
                  Purge means to "clean" (Latin "purgo"). Like the Purgatory where "kiddieboys" using nasty words (like f***ck) are being burnt while waiting for admission to Heavens. πŸ˜„
                  • massimoM Offline
                    massimo Moderator
                      Well, you dounderstand (Neo-)Latin, Massimo, I guess. πŸ˜‰
                      • massimoM Offline
                        massimo Moderator
                        Your Latin is good and Dante Alighieri never wrote such inspired verses. πŸ˜†
