    [Info] Ambient Occlusion -> Simple Rays
    66 Posts 22 Posters 80.7k Views 22 Watching
    • Q Offline
      qpik
      But I would have to export geometry for that one external routine.
      Is there other way?
      @thomthom said:
      What I meant was that the .raytest is probably written in C already.
      I've got that, I just wonder what makes it slow then and how to write a faster one.
      I guess I have to prepare myself for switching to C. Even for my simple use, which is lately sunlight exposure analysis, it's simply too slow, when run on part of the city centre model.
      Kuba
      ps. Many thanks for all the help so far.
      • W Offline
        Wacov
        @thomthom said:
        The .raytest method is running in SU's C. Not calculated using Ruby. Ruby just calls the C method.
        Ok.
        I guess I don't know what I'm talking about, but doesn't SU's raytest method extract more information than you need for your plugin? Maybe that's why it's so (comparatively) slow.
          Possibly. I guess it depends on what you need it for.
          • Q Offline
            qpik
            I thought exactly the same, as it returns "the first thing that the ray hits". I suppose it means "the closest thing". For my purpose it's enough to get first-on-the-list hit end exit.
            That might do the trick.
            • Q Offline
              qpik
              I quickly wrote this, but it worked MUCH slower than original method.
              def raytest2 ray
               hit = false
               entities = self.entities
               entities.each { |face|
                 if face.kind_of?(Sketchup;;Face) and face.classify_point(ray[0]) > 4
                  plane = [face.vertices[0].position, face.normal]
                  intersection = Geom.intersect_line_plane(ray, plane)
                  if intersection and face.classify_point(intersection) < 8
                   hit = true
                   break
               return hit
              This could be optimized by passing pre-sorted face array (based on results from previous tests) instead of browsing entities array, but I doubt it would speed it up much.
              What do you think?
                You can use face.plane instead
                What do you think?
                hmm... If you only iterate the entities collection once then it won't help to pre-process to filter out only faces. Infact, that would mean more iterations. But if you need to iterate the face multiple times, then you will save time on pre-filtering.
                Isn't that the same thing?
                You're writing a ruby method to be faster than a C method - that C method must be doing a lot of extra processing in order to be able to out-perform it in Ruby.
                • Q Offline
                  qpik
                  Somehow I didn't notice that one in the API πŸ˜„
                  I meant to sort the collection before proceeding to the next testing point. The faces that got hit before might as well be the first to get hit by rays cast from adjacent point.
                  I suppose model.raytest doesn't break after first positive ray hit, but returns the closest one from an array of all.
                  That is certainly true. That is why I managed to connect with a DLL using Win32api.call (BTW thanks to TBD for his SUDLL example).
                  Now I'm on my way to moving everything to C. I hope this will finally give a speed boost.
                  I'm looking into Ruby-OpenGL as well for another approach.
                  Here is an example - http://forums.sketchucation.com/viewtopic.php?f=180&t=20893&p=209966#p209966
                    that would be very odd. if it did produce a full array before returning I think it should return the full array.
                    • Q Offline
                      qpik
                      But then how would it find out the closest intersection?
                      ps. I write all this out of my head, I'm not familiar with 3d algorithms.
                        tomasz
                        I think it does break after first positive hit. Make sure you check if the object is not hidden or on a hidden layer, otherwise your rays will stop too early when hidden layer present in a model.
                        Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                        • Q Offline
                          qpik
                          Yeah, but how would the method know if the first hit is the closest?
                          It could be for example some distant face that got hit first, because it was first in the collection.
                            Did you ever find any improvements that could be made?
                            • Q Offline
                              qpik
                              I planned writing new method in C and calling it via Win32api... but I never find time and enough determination to do it. I wish somebody else did it instead πŸ˜„, someone who knows C, unlike me.
                                I'm also an C ignorant... 😞
                                • K Offline
                                  KiraNL
                                  Any chance this ever might come out which works for round shapes?
                                  Love to use this as subtile shadows over the textures, sort of lighting baking.
                                    seikun
                                    how can i download the plug-in
                                      It's attached to the first post of the topic. But it is not yet tested on SU version 9 - so it may not work for you (unless you made a typo when registering in which case, could you correct it, please?).
                                      πŸ˜‰
                                        tomasz
                                        Hi Kuba,
                                        Nice to see another Polish architect in action as a programmer. πŸ˜„
                                        I am getting more and more comfortable with C++, but I do not expect to be able to help you within next few months.
                                        I won't forget you effort and if I will find time, I will see whether I can help you with the raytest issue.
                                        • Dan RathbunD Offline
                                          Dan Rathbun
                                          This "plugin" (using the term liberally,) has been NOMINATED for QUARANTINE.
                                          see: [Candidate] Quarantine: Ambient Occlusion by qpik
                                          I'm not here much anymore.
                                            Dan Rathbun
                                            NOTICE: Preliminary Overhaul of the SimpleRays plugin !
                                            Developers' forum: [Plugin] Qpik::SimpleRays OVERHAUL
                                            I did this overhaul so we can remove SimpleRays from the Quarantine List
                                            Jakub, where are you ?
                                            • 3 / 4
