    Nubs on end of lines and intersections
    5 Posts 3 Posters 445 Views 3 Watching
    • M
      mcjalison
      I just got Pro 7 and all the lines and intersections have a little rectangle box thing that I hate. How do I turn that off? Thanks, Jason
      • EscapeArtistE
        EscapeArtist
        Not sure what you are referring to as I haven't seen that before, but you could check under Window > Styles > "Select" tab > Drop down menu select "Default" and see what happens.
        • massimoM
          massimo Moderator
          Window>styles>edit and uncheck endpoints.
          • M
            mcjalison
            they just look like tootsie rolls at the ends of lines and at intersections. I've attached a jpeg. notice when geometry is selected, it disappears.sketch.jpg
            • M
              mcjalison
              FIXED! thanks guys.
