    Shadow simulation
    4 Posts 2 Posters 631 Views 2 Watching
    • J
      Jorgensen
      I need to do a shadow simlutaion.
      I thought I could use TBD's time.rb and then export the animation, but it seems that time.rb won't work in SU7 pro.
      Error: #<NoMethodError: undefined method `gmtime' for 0.0:Float>
      Is there a other way to add the current time in a animation ? is it even possible with time.rb ?
      sketchup pro 2016 16.1.1449 64 bit | windows 10 pro | i7-3770k @3.5 GHz | 16gb ram | gtx 780 ti / gtx 980 ti | nvidia driver 368.39
        I've used that plugin with SU7 Pro to do shadow studies with no problem. Perhaps you can contact TBD for some hint as to how to make it work.
        From a few minutes ago.
        • J
          Jorgensen
          Hi Dave
          Thanks for your response. Does the text export with the images ?
          It might confligt with an other script. My version i 1.1 - there might be a newer one ?
          Edit:
          Oh there is a version 1.3 at http://www.smustard.com/script/Time - now I have to figure out if I can get an update.
            The image I posted was a JPG export.
            I didn't have the plugin here on my computer at work so I redownloaded it and installed it a minute or two before making that image. If you get the Smustard toolbar, you should be able to update the plugin after clicking on My Smustard.
            Dave
