Shadow simulation
I need to do a shadow simlutaion.
I thought I could use TBD's time.rb and then export the animation, but it seems that time.rb won't work in SU7 pro.
Error: #<NoMethodError: undefined method `gmtime' for 0.0:Float>Is there a other way to add the current time in a animation ? is it even possible with time.rb ?
I've used that plugin with SU7 Pro to do shadow studies with no problem. Perhaps you can contact TBD for some hint as to how to make it work.
From a few minutes ago.
Hi Dave
Thanks for your response. Does the text export with the images ?
It might confligt with an other script. My version i 1.1 - there might be a newer one ?
Edit:
Oh there is a version 1.3 at http://www.smustard.com/script/Time - now I have to figure out if I can get an update. -
The image I posted was a JPG export.
I didn't have the plugin here on my computer at work so I redownloaded it and installed it a minute or two before making that image. If you get the Smustard toolbar, you should be able to update the plugin after clicking on My Smustard.
Dave
