    Shadow simulation
    4 Posts 2 Posters 622 Views 2 Watching
      Jorgensen
      I need to do a shadow simlutaion.
      I thought I could use TBD's time.rb and then export the animation, but it seems that time.rb won't work in SU7 pro.
      Error: #<NoMethodError: undefined method `gmtime' for 0.0:Float>
      Is there a other way to add the current time in a animation ? is it even possible with time.rb ?
        I've used that plugin with SU7 Pro to do shadow studies with no problem. Perhaps you can contact TBD for some hint as to how to make it work.
        From a few minutes ago.
          Jorgensen
          Hi Dave
          Thanks for your response. Does the text export with the images ?
          It might confligt with an other script. My version i 1.1 - there might be a newer one ?
          Edit:
          Oh there is a version 1.3 at http://www.smustard.com/script/Time - now I have to figure out if I can get an update.
            The image I posted was a JPG export.
            I didn't have the plugin here on my computer at work so I redownloaded it and installed it a minute or two before making that image. If you get the Smustard toolbar, you should be able to update the plugin after clicking on My Smustard.
            Dave
