    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    Help: Any good Array Script?
    9 Posts 6 Posters 518 Views 6 Watching
      Buildermax
      hi,
      The attached screenshot shows multiply (array) options from Archicad. Is there any ruby available to do the similar? (beside key sequence)
      thanks
      Just love SU
        remus
        SU already has basic arrays built in to the move and rotate tools:
        Move/rotate a copy of the thing you want to array, type 'x5' in to the VCB and you'll get 5 equally spaced/rotated copies. If you type '/5' the distance between the original and the copy will be filled with 5 equally spaced copies.
        I dont know of any rubys that expand on this, though.
        Could you explain what the options in the archicad dialogue let you do?
          Grow by TIG have that and many more πŸ˜‰ (scroll to post #8)
            Buildermax
            Thanks guys. that's helpful.
            I also find another array tool, called SCF power bar. it does array along path at defined spacing and array on selected nodes.
            Just love SU
              You can also use my script πŸ˜‰
              • W Offline
                watkins
                Dear Pilou,
                I note that your screenshot of the Grow dialogue box is different from mine. Is this a latter version, and if so, from where did you download the script? I am using version 2.1.
                Regards,
                Bob
                  It's the 2.1 too πŸ˜‰ (post#8 above)
                  maybe because mac or Pc version ?
                    Also see my Matrix/Proximity tools...
                      1001bit also got a selections of array functions.
