    Error while importing
    6 Posts 3 Posters 671 Views 3 Watching
    • R
      raduteo
      http://i31.tinypic.com/tao2vq.jpg
      Anyone know what may cause this?
      • R
        remus
        At a guess, SU might be running out of memory. How many faces is the model your trying to import?
        • R
          raduteo
          I don't know exactly, Zbrush says it has 48.000 quads, how do I increase memory?
          • R
            remus
            Not a huge model, then, so i doubt it is running out of memory.
            Do you get this with all models from zbrush or just this one?
            • R
              raduteo
              If i decrease the polycount of the model it imports it fine, when I crank up the polycount (not by much) it keeps giving me this error, in other programs the mesh gets imported just fine, it's not a huge number of faces so I don't know why SU is doing this, it always stops at face 34600 like in the above picture.
              • D
                dacad
                Hi raduteo
                The sketchup importers on large meshes, models with unwarped materials, and sometimes for no reason aparent, can be almost useless. If you really want to import a high poly model into sketchup and avoid that error try dividing the model in 2 or 3 parts if possible in other software and import one at a time (preferably each part in a new file to avoid more errors. hope it helps
                David
