    How can I make a Helical dome shaped like IceCream?
    11 Posts 5 Posters 1.8k Views 5 Watching
    • N
      NOHD
      Hi there! Can anyone help me out with this one? I'm having troubles modeling irregular shapes, especially like this one.
      http://images.devr13.multiply.com/image/1/photos/50/1200x1200/1/TwirliePencilCase-1.jpg?et=0beH8mVfHF8SaZdvRnffVA&nmid=265049377
      Sir Gaieus showed me this link http://forums.sketchucation.com/viewtopic.php?f=18&t=9479 I would appreciate it if you can help me with this one πŸŽ‰ πŸŽ‰ πŸŽ‰
      NOHD
      • S
        Staatsfeind
        here @work not the possibility to try out but i could imagine
        to make use of the fredo ruby:
        http://forums.sketchucation.com/download/file.php?id=27666
        or ?
        http://www.frenchtouchstudio.com
        manager/modeler
        • ToboboT
          Tobobo
          @nohd said:
          Sir Gaieus
          Firstly, don't call him that. We know he's good but the server wouldn't be able to store his head.
          Second....
          suggest you look into soapskin and bubble and the freescale plugins.
          http://www.tensile-structures.de/sb_software.html = Soapskin
          http://forums.sketchucation.com/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a&hilit=Freescale = Freescale
          Trial and error the combination until you get what you are after.
          Toby
          Philippians 4:13
          • R
            remus
            Heres a quick go at it:
            1. Model this using standard SU tools
            2. Use the box twist tool (from fredoscale) to twist it 180.
            3. Subdivide and smooth with 2 iterations.
            You could quite easily make the ice cream a little more rounded by cutting off the corners of the starting mesh.
            • sketch3d.deS
              sketch3d.de
              @nohd said:
              ... modeling irregular shapes ...
              for modeling freeform surfacres I would use an appropriate tool, e.g. a NURBS surface based modeler as e.g. ViaCAD/Shark, especially if you need exact and editable faces (or volumes).
              hth,
              Norbert
              • N
                NOHD
                  [attachment=2:2q4v33mh]<!-- ia2 -->ice cream1.jpg<!-- ia2 -->[/attachment:2q4v33mh]
                  [attachment=1:2q4v33mh]<!-- ia1 -->ice cream 2.jpg<!-- ia1 -->[/attachment:2q4v33mh]
                  [attachment=0:2q4v33mh]<!-- ia0 -->ice cream 3.jpg<!-- ia0 -->[/attachment:2q4v33mh]
                wow, thanks! this looks almost the same as the icecream thing i'm trying to do. uhmmm.. excuse my newbie-ness but how exactly do you 'cut off the corners of the starting mesh?' thanks remus πŸŽ‰
                • N
                  NOHD
                  or ?
                  is that fredo ruby downloadable here at sketchucation?
                  • N
                    NOHD
                    @tobobo said:
                    @nohd said:
                    Sir Gaieus
                    Second....
                    thanks Tobobo πŸ‘
                    • N
                      NOHD
                      hth,
                      Norbert
                      too bad i only use PlugIns that are free to download. 😞 but thanks anyways. πŸ‘
                      • R
                        remus
                        Like this:
                        Looks a bit like this after twisting and subdiving.
                        Attached the skp as well πŸ‘
                        ice cream mk2.skp
                        • sketch3d.deS
                          sketch3d.de
                          ah, private use.
                          btw, which plug-in?
                          N.
