πŸ€‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
How can I make a Helical dome shaped like IceCream?
11 Posts 5 Posters 1.2k Views
  • N Offline
    NOHD
    Hi there! Can anyone help me out with this one? I'm having troubles modeling irregular shapes, especially like this one.
    http://images.devr13.multiply.com/image/1/photos/50/1200x1200/1/TwirliePencilCase-1.jpg?et=0beH8mVfHF8SaZdvRnffVA&nmid=265049377
    Sir Gaieus showed me this link http://forums.sketchucation.com/viewtopic.php?f=18&t=9479 I would appreciate it if you can help me with this one πŸŽ‰ πŸŽ‰ πŸŽ‰
    NOHD
      Staatsfeind
      here @work not the possibility to try out but i could imagine
      to make use of the fredo ruby:
      http://forums.sketchucation.com/download/file.php?id=27666
      or ?
      http://www.frenchtouchstudio.com
      manager/modeler
        Tobobo
        @nohd said:
        Sir Gaieus
        Firstly, don't call him that. We know he's good but the server wouldn't be able to store his head.
        Second....
        suggest you look into soapskin and bubble and the freescale plugins.
        http://www.tensile-structures.de/sb_software.html = Soapskin
        http://forums.sketchucation.com/viewtopic.php?f=180&t=17948&st=0&sk=t&sd=a&hilit=Freescale = Freescale
        Trial and error the combination until you get what you are after.
        Toby
        Philippians 4:13
          remus
          Heres a quick go at it:
          1. Model this using standard SU tools
          2. Use the box twist tool (from fredoscale) to twist it 180.
          3. Subdivide and smooth with 2 iterations.
          You could quite easily make the ice cream a little more rounded by cutting off the corners of the starting mesh.
            sketch3d.de
            @nohd said:
            ... modeling irregular shapes ...
            for modeling freeform surfacres I would use an appropriate tool, e.g. a NURBS surface based modeler as e.g. ViaCAD/Shark , especially if you need exact and editable faces (or volumes).
            hth,
            Norbert
            • N Offline
              NOHD
                [attachment=2:2q4v33mh]<!-- ia2 -->ice cream1.jpg<!-- ia2 -->[/attachment:2q4v33mh]
                [attachment=1:2q4v33mh]<!-- ia1 -->ice cream 2.jpg<!-- ia1 -->[/attachment:2q4v33mh]
                [attachment=0:2q4v33mh]<!-- ia0 -->ice cream 3.jpg<!-- ia0 -->[/attachment:2q4v33mh]
              wow, thanks! this looks almost the same as the icecream thing i'm trying to do. uhmmm.. excuse my newbie-ness but how exactly do you 'cut off the corners of the starting mesh?' thanks remus πŸŽ‰
              • N Offline
                NOHD
                or ?
                is that fredo ruby downloadable here at sketchucation?
                • N Offline
                  NOHD
                  @tobobo said:
                  @nohd said:
                  Sir Gaieus
                  Second....
                  thanks Tobobo πŸ‘
                  • N Offline
                    NOHD
                    hth,
                    Norbert
                    too bad i only use PlugIns that are free to download. 😞 but thanks anyways. πŸ‘
                      remus
                      Like this:
                      Looks a bit like this after twisting and subdiving.
                      Attached the skp as well πŸ‘
                      ice cream mk2.skp
                        sketch3d.de
                        ah, private use.
                        btw, which plug-in?
                        N.
