    Select All Visible Dimensions
    9 Posts 5 Posters 5.7k Views 5 Watching
    • D
      DaveS
      Does anyone know if there is a way (perhaps a plugin) that will allow all visible dimensions to be selected? Thanks for any info.
      Dave
      • thomthomT
        Copy and Paste this into the Console
        Sketchup.active_model.active_entities.each { |e| Sketchup.active_model.selection.add(e) if e.visible? && e.layer.visible? && e.class == Sketchup::Drawingelement && (e.typename == 'DimensionLinear' || e.typename == 'DimensionRadial') }
          Couldn't you just go to Model Info>Dimensions and click on the button?
          • D
            DaveS
            thomthom,
            Thanks for the code. Works great. I'm a novice when it comes to Ruby scripts, so could you tell me if it would be very difficult to turn this into a plugin that could be accesssed from a menu button?
            Thanks again.
            Dave
            • D
              DaveS
              Dave R,
              Thanks for the reply. I hadn't thought of that approach. It will work, but I think I'd like to have a toolbar button to click to select all the dimensions.
              Again, thanks.
              Dave
              • Didier BurD
                Didier Bur
                My "quick selection" script does it (and more)
                Find it here: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_sel_page.htm
                DB
                • thomthomT
                  @didier bur said:
                  I doesn't select entities inside groups/components. Only the active entities.
                  • D
                    DaveS
                    Didier Bur and thomthom,
                    Thanks for the info on the plugin and the clarification.
                    Dave
                    • P
                      pibuz
                      Hi Thom! Is there a way you can update this thingy to work on SU2022?
                      Seems it currently doesn't.... MANY THANKS IN ADVANCE!
                      WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
