    [Plugin][$] RoundCorner - v3.4a - 31 Mar 24
    1.5k Posts 477 Posters 4.1m Views 477 Watching
    • W Offline
      Wookbert
      @fredo6: Wasn't aware of the Retina check box. It helps a bit, the text however still is too small to be read and edited conveniently.
      • fredo6F Offline
        fredo6
        The logic of font size vs screen resolution is not accessible from the Ruby API.
        However, you may want to read this thread, where other Mac users are discussing potential solutions.
        Fredo
        • G Offline
          gregoiregentil
          Bonjour! I don't manage to get round corners for this design (http://imgur.com/kYQ9ITf😞
          What am I doing wrong? Here is the file: http://www.filedropper.com/casing-v1
          I'm running the latest of Fredo6 and round corners on Sketchup 8.
            In your screenshot you show the radius of the rounding (called Offset) as 0.1 mm. That's incredibly small. Try a reasonable value for the size of the object.
            • TIGT Online
              Yes, as Dave says, SketchUp itself [and by connection its Plugins] can't cope with dimensions with tiny dimensions [<=1/1000"]
              So try something a bit bigger...
              • G Offline
                gregoiregentil
                Regarding my previous post with an error while trying to create a round corner for a kind of dome, yes, I tried much bigger values for the offset but it was the same problem, nothing happened when I click generate.
                I figured out that the culprit was the arcs at the base of the geometry. If I replace the arcs by straight lines, the plugin can generate something. I understand how it could be challenging for a plugin to generate rounded corners when you have a circle or arc at the base. And if the arc is converted to successive small lines, it's even more challenging and it will push you to have a very small offset.
                So I will most likely stay with straight lines at the base. My question becomes more now: is there a way to have different offset for different lines during the same single rounded corner generation. Because you might want to have two different values for 3 lines that intersect so I don't think that you can do it sequentially.
                • W Offline
                  william0j
                  Does this plugin support SU16?
                    ronagoldberg
                    I love this tool! It saves me a lot of time and is very powerful.
                    I have one question. If I use the tool to round the edges of a cube for example and then use another tool to cut a shape out of the cube I get parts of the faces missing. If i repair them and cut another shape out of the cube the faces open up again.
                    How can I stop that from happening?
                    Thanks,
                    Ron
                      It sounds to me as if you are running into the small edges issue. How large is the object you're working on? Try working at a larger scale and then scale back down.
                        ronagoldberg
                        How large do you think I'd need to work? I generally work in a foot equals an inch scale to create the fine details I need.
                        Thanks for the help.
                          Hard to tell without seeing your model.
                          • dereiD Offline
                            derei
                            Would it be possible to optimize the rounding to work better with quads? I noticed that it splits the quad triangulation, instead of generating new quads and the resulting faces are really weird looking (with diagonals going across two faces, as a result of the former quad triangulation)
                            Cheers!
                            DESIGNER AND ARTIST DEREI.UK
                              mohtashimiqbal
                              i cannot find ANY download link for this plugin , has it been removed i m tired of searching the main post with no clue ..
                                None at all? How far down the main post did you look before you gave up? It's clearly identified.
                                • TIGT Online
                                  And... the SketchUcation PluginStore - linked off the menu above - contains virtually all of the Plugins/Extensions mentioned across many threads in these forums...
                                  So that should be your starting point whenever you are looking to download anything...
                                  Also it has excellent search functions on its page...
                                  As Fredo mentioned in his tool's first page [see the image pasted by Dave]... if you first download and install the SketchUcation PluginStore Toolset [RBZ], available in the Resources menu above, OR now as v3.0.0 in the PluginStore itself, under Author '- SketchUcation -' [first on the list], then that has a dialog which lets you browse the PluginStore [getting re-badged as the ExtensionStore³] from within SketchUp itself, and then AutoInstall selected tools...
                                  It also has lots of other goodies like Update notifiers, Bundles, Managers etc - read up on it...
                                    arkiboygmo
                                    Thank you!
                                      Ribard
                                      Can someone tells me how to download this extension ?
                                        The information is provided in the first post of this thread and again, most recently in the post the second and third posts above yours.
                                        • N Offline
                                          numerobis
                                          I have two problems with the latest version (installed on SU2015 x64)
                                          1. Round corner: The offset value is displayed but not recognized by the plugin if it is entered using the TAB-Key. I need to re-open the function to make it active. If i use the toolbar field it is working.
                                          2. Bevel edges: There is a smoothing issue with beveled geometry. After beveling i always need to fix the smoothing.
                                          • fredo6F Offline
                                            fredo6
                                            Thanks for signaling this bug. Easy to fix.
                                            @numerobis said:
                                            1. Bevel edges: There is a smoothing issue with beveled geometry. After beveling i always need to fix the smoothing.
                                            What is the problem exactly? which edges are you referring to ?
                                            Fredo
                                            • 52
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 74
                                            • 75
                                            • 54 / 75
