    1.5k Posts 478 Posters 4.3m Views 478 Watching
      Hard to tell without seeing your model.
      • dereiD
        derei
        Would it be possible to optimize the rounding to work better with quads? I noticed that it splits the quad triangulation, instead of generating new quads and the resulting faces are really weird looking (with diagonals going across two faces, as a result of the former quad triangulation)
        Cheers!
        DESIGNER AND ARTIST DEREI.UK
          mohtashimiqbal
          i cannot find ANY download link for this plugin , has it been removed i m tired of searching the main post with no clue ..
            None at all? How far down the main post did you look before you gave up? It's clearly identified.
              And... the SketchUcation PluginStore - linked off the menu above - contains virtually all of the Plugins/Extensions mentioned across many threads in these forums...
              So that should be your starting point whenever you are looking to download anything...
              Also it has excellent search functions on its page...
              As Fredo mentioned in his tool's first page [see the image pasted by Dave]... if you first download and install the SketchUcation PluginStore Toolset [RBZ], available in the Resources menu above, OR now as v3.0.0 in the PluginStore itself, under Author '- SketchUcation -' [first on the list], then that has a dialog which lets you browse the PluginStore [getting re-badged as the ExtensionStore³] from within SketchUp itself, and then AutoInstall selected tools...
              It also has lots of other goodies like Update notifiers, Bundles, Managers etc - read up on it...
                arkiboygmo
                Thank you!
                  Ribard
                  Can someone tells me how to download this extension ?
                    The information is provided in the first post of this thread and again, most recently in the post the second and third posts above yours.
                    • N
                      numerobis
                      I have two problems with the latest version (installed on SU2015 x64)
                      1. Round corner: The offset value is displayed but not recognized by the plugin if it is entered using the TAB-Key. I need to re-open the function to make it active. If i use the toolbar field it is working.
                      2. Bevel edges: There is a smoothing issue with beveled geometry. After beveling i always need to fix the smoothing.
                      • fredo6F
                        Thanks for signaling this bug. Easy to fix.
                        @numerobis said:
                        1. Bevel edges: There is a smoothing issue with beveled geometry. After beveling i always need to fix the smoothing.
                        What is the problem exactly? which edges are you referring to ?
                        • N
                          numerobis
                          The edges are showing up correctly (hard edges) but the shading is messed up in display and rendering.
                          I have to use the smoothing controls after the beveling and set it to hard egdes again to get this fixed.
                          • fredo6F
                            What should I do then ?
                            • N
                              numerobis
                              I don't know. I can only say that there is something different to the normal hard edges. The shading is wrong (soft). And i think this problem is new. I never noticed this in older versions.
                              • fredo6F
                                Could it be related to "cast-shadow" ?
                                • N
                                  numerobis
                                  Sorry, i don't understand. Which "cast-shadow"?
                                    johnwmcc
                                    I've just installed this plugin in SU 2016, on iMac 5K Retina running El Capitan (OS X v 10.11.3).
                                    The dialogue box is incredibly small and hard to read on this high res-screen. Is there any way of making it bigger?
                                    The overall height of your dialogue is only about 8mm, and the text less than 2mm high.
                                    The screen shot (attached) seems to make it look a bit bigger, but in reality I need a magnifying glass to read it!
                                    PS. Sorry again - I've only just seen earlier posts on this subject. Will see if the suggestions there help.
                                    PPS. Checking the Retina box in the Default Parameters dialogue helps, but only enlarges the boxes and icons, not the text
                                    Seems that there are general problems with very high res displays for SketchUp, not yet fully resolved, though there are partial workarounds.
                                      mintra
                                      This is a gem. Though I treated myself to a 5k mac and the button pallet is too small to read at 5k so I have to change the resolution of my mac to use this. Is their some setting for button pallet size?
                                      • K
                                        klarans
                                        Where do I find the download buttons for your plug-ins?
                                          Look at the first post of the thread. The link is right out in plain sight.
                                            rv1974
                                            Have anybody requested for filleting of not connected surfaces here? 😎
                                            • 52
                                            • 53
                                            • 54
                                            • 55
                                            • 56
                                            • 74
                                            • 75
                                            • 54 / 75
