    πŸ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 213.7k Views 61 Watching
    • unclebimU Offline
      unclebim
      @voxdei_999 said:
      hi, i think it's only me (i've seen the forum & ruby depot), but the only thing i can do is insert guide points, the another 16 options does'nt work, what i'm doing wrong? thanks fou your suggest.
      Unfortunately it is me too and I also wonder what is the problem?
      • E Offline
        ephi
        cool!thanks a lot.
        • jo-keJ Offline
          jo-ke
          can't find this one in the pluginstore...
          is it possible to install it on SU2013?
          http://www.zz7.de
          • jo-keJ Offline
            jo-ke
            solved!
            http://www.zz7.de
              JPC2j3
              I'm cluless how to use this extension. I'm trying the most simple thin I can imagine: to draw parallel and perpendicular lines. This seems to be the only plugin/extensiopn I can find that might do these opoerations.
              1. Is the right plugin?
              2. Is there a usaers manual?
              John
              • BoxB Offline
                John
                Seriously! Have you not read the other thread you started?
                • E Offline
                  expresso405
                  GREAT plugin! many thanks for it. Just wish it was easier to find in the "new" system!
                  • TIGT Online
                    PluginStore Search...PluginStore_Search.PNGResult...Capture.PNG How much easier do you want it ?
                    There's a Download button in the first post in this thread to take you to the PluginStore entry directly...Download.PNG
                    • H Offline
                      HirokaMatsuiko
                      is it possible to add shortcut tried pilous method but seems cant figure it out how
                      it doesnt appear in shortcut
                      this is much powerful than SU default divide tool and i use this tool often .. because the knife tool artisan + dbur projection is much easier to use in parallel projection it snap easily
                      • H Offline
                        Hastalasnarices
                        I've installed the Plugin Store and downloaded this plugin through it in Sketchup 2013. However, I'm not getting the toolbar and so I can't use it. I've tried manually installing the plugin but still no results. The plugin appears correctly installed under the Plugin Store's plugin manager. When I right-click on Sketchup and select "Toolbars", there's one named "Projections", but checking it or un-cheking it doesn't produce any results. No toolbars appear or disappear. Help, please!
                        • TIGT Online
                          Logically you might look in Preferences > Extensions and check that this tool is 'ticked'...
                          Then OK and the Toolbar etc should become available...
                          BUT it is NOT an extension!
                          If the plugin is correctly installed via the RBZ the tool bar 'Projections' should be available ?
                          Do you have FULL security permissions to add files to the v2013 Plugins folder ??
                          There's a tutorial in the menu above...
                            De Etta
                            I did not see an Instruction pdf available either with my download or on this page. maybe you can point me in the right direction?
                            D
                            • sumasterS Offline
                              sumaster
                              Any update for Sketchup 2014. . . . .
                              It's not working. . . . . .
                              Thanks,
                              Thank you,
                              SUmaster
                              • TIGT Online
                                Didier, this toolset's author, had made it an encrypted, so simple fixes are not easy...
                                Didier seems preoccupied with other new things right now...
                                But after some effort, I got/posted an updated version [v2a] now in the PluginStore, which is v2014 compatible [with one single simple typo fixed, which earler versions forgave but Ruby2 chokes on !]
                                http://sketchucation.com/pluginstore?pln=projections
                                • P Offline
                                  Pherim
                                  With Sketchup 2015 64 bit, some of these tools don't work as they used to in 2013, Extrude lines and Faces along vector both only work when I enter values, but not by just clicking the start and end points.
                                  • TIGT Online
                                    Any messages in Ruby Console ?
                                    I only updated the code for Didier to allow it to load into Ruby 2 ?
                                    • P Offline
                                      Pherim
                                      Push/Pull Faces along Vector:
                                      Error: #<NoMethodError: undefined methodisEqual' for 4067.422773715575:Length>
                                      c:/users/USERNAME/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/projection/projection.rbs:2679:in onLButtonDown'
                                      Extrude Lines along Vector:
                                      Error: #<NoMethodError: undefined methodisEqual' for 3512.4586235163288:Length>
                                      c:/users/USERNAME/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/projection/projection.rbs:2869:in onLButtonDown'
                                      Both errors appear the moment the left mouse button is clicked to set the end point of the vector, but nothing else happens.
                                      • TIGT Online
                                        Thanks, that's very helpful.
                                        Didier's code [ill-advisedly] messes with Float, adding an 'isEqual' method.
                                        In v2015 the Length class is changed, so the Float messing on is not reflected as it was !
                                        I'll look at a fix...
                                        • TIGT Online
                                          I corrected the issue between Didier's handling of Float & Length in v2015
                                          The update is in the PluginStore http://sketchucation.com/pluginstore?pln=projections
                                          • P Offline
                                            Pherim
                                            That was fast! Thanks, now it works again.
                                            • 6
                                            • 7
                                            • 8
                                            • 6 / 8
