    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 236.1k Views 61 Watching
      boostabeats
      Hi All,
      Sorry if this has been mentioned before, I just skimmed through the pages.
      The accompanying literature states that for a mac to install the plugin in the user library not the main library.
      Since I didn't have a plugin folder in my user library, I tried it in the normal location and everything seems to be working fine. Just thought I'd mention.
      OSX 10.6.8 and SU8
      Fantastic plugin by the way, I've only played a few minutes and it seems really useful!
      Cheers.
        You are correct. 😲
        The tool's documents contain an error.
        You should install all Plugins into the root [hd] Library path Plugins folder... NEVER the 'user' one !
        Hopefully Didier will read this and update his tool's docs - it is quite an old toolset...
          De Marco
          I have an qestion if someone could create connect this plugin with shortcuts it was only one demage of this fantastic plugin
            You can make you own Shortcut πŸ˜‰
            See Menu Window / Preferences / Shortcuts / View / Toolbars / Projections πŸ˜‰
            • unclebimU Offline
              unclebim
              @voxdei_999 said:
              hi, i think it's only me (i've seen the forum & ruby depot), but the only thing i can do is insert guide points, the another 16 options does'nt work, what i'm doing wrong? thanks fou your suggest.
              Unfortunately it is me too and I also wonder what is the problem?
              • E Offline
                ephi
                cool!thanks a lot.
                • jo-keJ Offline
                  jo-ke
                  can't find this one in the pluginstore...
                  is it possible to install it on SU2013?
                  http://www.zz7.de
                  • jo-keJ Offline
                    jo-ke
                    solved!
                    http://www.zz7.de
                      JPC2j3
                      I'm cluless how to use this extension. I'm trying the most simple thin I can imagine: to draw parallel and perpendicular lines. This seems to be the only plugin/extensiopn I can find that might do these opoerations.
                      1. Is the right plugin?
                      2. Is there a usaers manual?
                      John
                      • BoxB Offline
                        John
                        Seriously! Have you not read the other thread you started?
                        • E Offline
                          expresso405
                          GREAT plugin! many thanks for it. Just wish it was easier to find in the "new" system!
                            PluginStore Search...PluginStore_Search.PNGResult...Capture.PNG How much easier do you want it ?
                            There's a Download button in the first post in this thread to take you to the PluginStore entry directly...Download.PNG
                            • H Offline
                              HirokaMatsuiko
                              is it possible to add shortcut tried pilous method but seems cant figure it out how
                              it doesnt appear in shortcut
                              this is much powerful than SU default divide tool and i use this tool often .. because the knife tool artisan + dbur projection is much easier to use in parallel projection it snap easily
                              • H Offline
                                Hastalasnarices
                                I've installed the Plugin Store and downloaded this plugin through it in Sketchup 2013. However, I'm not getting the toolbar and so I can't use it. I've tried manually installing the plugin but still no results. The plugin appears correctly installed under the Plugin Store's plugin manager. When I right-click on Sketchup and select "Toolbars", there's one named "Projections", but checking it or un-cheking it doesn't produce any results. No toolbars appear or disappear. Help, please!
                                  Logically you might look in Preferences > Extensions and check that this tool is 'ticked'...
                                  Then OK and the Toolbar etc should become available...
                                  BUT it is NOT an extension!
                                  If the plugin is correctly installed via the RBZ the tool bar 'Projections' should be available ?
                                  Do you have FULL security permissions to add files to the v2013 Plugins folder ??
                                  There's a tutorial in the menu above...
                                    De Etta
                                    I did not see an Instruction pdf available either with my download or on this page. maybe you can point me in the right direction?
                                    D
                                    • sumasterS Offline
                                      sumaster
                                      Any update for Sketchup 2014. . . . .
                                      It's not working. . . . . .
                                      Thanks,
                                      Thank you,
                                      SUmaster
                                        Didier, this toolset's author, had made it an encrypted, so simple fixes are not easy...
                                        Didier seems preoccupied with other new things right now...
                                        But after some effort, I got/posted an updated version [v2a] now in the PluginStore, which is v2014 compatible [with one single simple typo fixed, which earler versions forgave but Ruby2 chokes on !]
                                        http://sketchucation.com/pluginstore?pln=projections
                                          Pherim
                                          With Sketchup 2015 64 bit, some of these tools don't work as they used to in 2013, Extrude lines and Faces along vector both only work when I enter values, but not by just clicking the start and end points.
                                            Any messages in Ruby Console ?
                                            I only updated the code for Didier to allow it to load into Ruby 2 ?
                                            • 6 / 8
