    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 233.5k Views 61 Watching
      @expresso405 said:
      GREAT plugin! many thanks for it. Just wish it was easier to find in the "new" system!
      PluginStore Search...PluginStore_Search.PNGResult...Capture.PNG How much easier do you want it ?
      There's a Download button in the first post in this thread to take you to the PluginStore entry directly...Download.PNG
      • H Offline
        HirokaMatsuiko
        is it possible to add shortcut tried pilous method but seems cant figure it out how
        it doesnt appear in shortcut
        this is much powerful than SU default divide tool and i use this tool often .. because the knife tool artisan + dbur projection is much easier to use in parallel projection it snap easily
        • H Offline
          Hastalasnarices
          I've installed the Plugin Store and downloaded this plugin through it in Sketchup 2013. However, I'm not getting the toolbar and so I can't use it. I've tried manually installing the plugin but still no results. The plugin appears correctly installed under the Plugin Store's plugin manager. When I right-click on Sketchup and select "Toolbars", there's one named "Projections", but checking it or un-cheking it doesn't produce any results. No toolbars appear or disappear. Help, please!
            Logically you might look in Preferences > Extensions and check that this tool is 'ticked'...
            Then OK and the Toolbar etc should become available...
            BUT it is NOT an extension!
            If the plugin is correctly installed via the RBZ the tool bar 'Projections' should be available ?
            Do you have FULL security permissions to add files to the v2013 Plugins folder ??
            There's a tutorial in the menu above...
              De Etta
              I did not see an Instruction pdf available either with my download or on this page. maybe you can point me in the right direction?
              D
              • sumasterS Offline
                sumaster
                Any update for Sketchup 2014. . . . .
                It's not working. . . . . .
                Thanks,
                Thank you,
                SUmaster
                  Didier, this toolset's author, had made it an encrypted, so simple fixes are not easy...
                  Didier seems preoccupied with other new things right now...
                  But after some effort, I got/posted an updated version [v2a] now in the PluginStore, which is v2014 compatible [with one single simple typo fixed, which earler versions forgave but Ruby2 chokes on !]
                  http://sketchucation.com/pluginstore?pln=projections
                    Pherim
                    With Sketchup 2015 64 bit, some of these tools don't work as they used to in 2013, Extrude lines and Faces along vector both only work when I enter values, but not by just clicking the start and end points.
                      Any messages in Ruby Console ?
                      I only updated the code for Didier to allow it to load into Ruby 2 ?
                        Pherim
                        Push/Pull Faces along Vector:
                        Error: #<NoMethodError: undefined methodisEqual' for 4067.422773715575:Length>
                        c:/users/USERNAME/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/projection/projection.rbs:2679:in onLButtonDown'
                        Extrude Lines along Vector:
                        Error: #<NoMethodError: undefined methodisEqual' for 3512.4586235163288:Length>
                        c:/users/USERNAME/appdata/roaming/sketchup/sketchup 2015/sketchup/plugins/projection/projection.rbs:2869:in onLButtonDown'
                        Both errors appear the moment the left mouse button is clicked to set the end point of the vector, but nothing else happens.
                          Thanks, that's very helpful.
                          Didier's code [ill-advisedly] messes with Float, adding an 'isEqual' method.
                          In v2015 the Length class is changed, so the Float messing on is not reflected as it was !
                          I'll look at a fix...
                            I corrected the issue between Didier's handling of Float & Length in v2015
                            The update is in the PluginStore http://sketchucation.com/pluginstore?pln=projections
                              Pherim
                              That was fast! Thanks, now it works again.
                                You report was just the kind I like - you explained the problem clearly - so a cause and a fix was pretty obvious...
                                Much better than the, "It doesn't work..." reports 😄
                                • sumasterS Offline
                                  sumaster
                                  THanks TIG sir . . . . .
                                  waiting for 2014 and 2015 update . . . . 😄 😄
                                  Thank you,
                                  SUmaster
                                  • BoxB Offline
                                    He did update it for that.
                                    http://sketchucation.com/forums/viewtopic.php?f=323%26amp;t=20140%26amp;start=90#p543502
                                    404 Not Found
                                    (sketchucation.com)
                                    • andybotA Offline
                                      andybot
                                      Is it just me, or the tool menu does not show up in 2015? I'm trying to add a shortcut to one of the tools, but I can't find the plugin in the list of commands.
                                        There was never a 'Projections' submenu in the Tool menu 😕
                                        Only a 'Projections' Toolbar.
                                        However, please replace this .rb in the Plugins folder, and tell me if it does what you desire.
                                        After a SketchUp restart you should now get a Tools 'Projections' submenu, which is equivalent to its Toolbar items...
                                        If so, and it's good, AND there is more user support, I'll update the RBZ with it...
                                        projection_extension.rb
                                        • andybotA Offline
                                          andybot
                                          Yep, that works. Thanks!!
                                          • zooenZ Offline
                                            zooen
                                            No longer works with Sketchup Pro 2018, it's unfortunate.
                                            • 6 / 8
