    [Plugin] JS Align - Update
    16 Posts 10 Posters 18.3k Views 10 Watching
    • PixeroP Offline
      Pixero
      I've updated the script so it will work better.
      Now works correct inside groups.
      Get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=jsAlign
      • Bob JamesB Offline
        Bob James
        Tried your JS Align: neat tool.
        Tried your JS MoveTool: entered a value in the "Measurement" window, pressed enter, then tried all the arrow keys but nothing happened.
          Bob James
          @pixero said:
          Just to be sure. You have something selected, right?
          Are you on Mac or PC? I dont have a Mac so I cant test if it works.
          Yes, I had a simple rectangle (grouped) πŸ˜„
          I tried it on my iMac at home and on my MacPro here at work.
          • PixeroP Offline
            Pixero
            There might be something wrong with this part of the script:
            elsif RUBY_PLATFORM == "powerpc-darwin" then            # Mac OSX
                $leftArrow = 63234       # Arrow Left Key
                $upArrow  = 63232        # Arrow Up Key
                $rightArrow  = 63235     # Arrow Right Key
                $downArrow = 63233       # Arrow Down Key
                $altKey  = 524288        # Alt/Option Key
                $shiftKey = 131072		# Shift Key
                $controlKey = 1048576	# Command (Apple) Key
            end #if
            Anyone with a Mac that can test if it's correct?
            • PixeroP Offline
              Pixero
              • Chris FullmerC Offline
                Bob do you use Sketchyphysics? I have had Mac users not be able to use their arrow keys if they have SketchyPhysics installed. And I can't remember if Chris fixed that issue.....?
                Also, to test Jan's snippet there, you might open the Ruby Console and type in:
                RUBY_PLATFORM
                and see what it prints to the console. Copy and paste that back here.
                All my Plugins I've written
                • utilerU Offline
                  utiler
                  Thanks Jan, great little tool....! πŸŽ‰
                  Just Curious...
                    Bob James
                    No, I don't have Sketchyphysics installed on either machine.
                    RUBY_PLATFORM
                    See attachment.
                    After entering RUBY_PLATFORM in the Ruby Console
                    • PixeroP Offline
                      Pixero
                      Bob, check your PM.
                      • H Offline
                        hkgiordano
                        Thak You, a very useful tool
                          > end #if
                          The SU API Docs suggest this code to detect Mac or PC: http://code.google.com/apis/sketchup/docs/faq.html
                          PLATFORM = (Object::RUBY_PLATFORM =~ /mswin/i) ? :windows : ((Object::RUBY_PLATFORM =~ /darwin/i) ? :mac : :open_mouth:ther)
                          It simply looks for the existance of "darwin" in the PLATFORM constant string.
                          • K Offline
                            krmccurdy
                            Great tool! This will save LOADS of time with site files.
                            Thanks!
                              rv1974
                              One thing is needed to make this tool perfect:
                              Respect current UCS.
                                There is an update available in the PluginStore to suit SketchUp v2014
                                • PixeroP Offline
                                  Pixero
                                  The one on my site is now also v1.6.
                                  Thanks to TIG. πŸ‘
                                  • pep75P Offline
                                    pep75
                                    Great plug-in! But would it be possible not the change an object's position when you lock it? This would make the plug-in perfect.... πŸ˜›
