    Installing VRay Issue
    renderpluginsextensions
    12 Posts 4 Posters 2.2k Views 4 Watching
      JaViXP
      I have downloaded a 30 Days-Trial Version of VRay for SketchUp.
      I installed it like in guide but it displays the message below.
      What could be the problem?
      VRay Issue
      "Giving up is way harder than trying"
      JaViXP's Rendering
        JaViXP
        No se puede encontrar el módulo especificado means "Can not find the specified module."
        JaViXP's Rendering
          Did you install as administrator?
            JaViXP
            Yes, I did and then I run SU as administrator. The message still being there...
            JaViXP's Rendering
              Does that provide any more help: http://forum.asgvis.com/index.php?topic=2321.0 ?
              If not - send an message to support@asgvis.com
                JaViXP
                No.. That didn't help, thanks for helping me. I'm going to send a e-mail to ASGVIS now.
                JaViXP's Rendering
                  JaViXP
                  No te preocupes ya lo solucioné con la ayuda de ASGvis.
                  Don't worry I already solved it with help that ASGvis provided.
                  And... Many people told me about to change my nick-name to JaviVISTA 😆
                  JaViXP's Rendering
                    Care to share the solution? Often people search the web for solution to problems, so it might help them.
                    • I Offline
                      inakim
                      Javi, es un error del vista que traduce automaticamente Program files a Archivos de programa, asegurate que al intalar el Vray en C:/Archivos de programa/Google/Google SketchUp 7/Plugins/ tienes la carpeta VRayForSketchUp y el fichero VRayForSketchup.rb
                      Javi, is a mistake of vista that Program files translates automatic into archivos de programa, assure yourself that when install Vray in C:/Archivos de programa/Google/Google 7/Plugins/, you have the folder VRayForSketchUp and the file VRayForSketchup.rb
                      Change your nick to jaViVista 😆
                        JaViXP
                        Ok, here we go:
                        I didn't do that much, I use SU7 and it was specific for SketchUp 6/7 but the V.7 didn't work. So ASGvis sent me a link to download a specific version for SU7 Here
                        Hope this helps! 😄
                        JaViXP's Rendering
                          Just let me know when you decide and I can change it for you. 😉
                            JaViXP
                            That'd be cool, but I won't change it now 😆
                            JaViXP's Rendering
