    Installing VRay Issue
    renderpluginsextensions
    12 Posts 4 Posters 2.4k Views 4 Watching
      JaViXP
      No se puede encontrar el módulo especificado means "Can not find the specified module."
      "Giving up is way harder than trying"
      JaViXP's Rendering
        Did you install as administrator?
          JaViXP
          Yes, I did and then I run SU as administrator. The message still being there...
          JaViXP's Rendering
            Does that provide any more help: http://forum.asgvis.com/index.php?topic=2321.0 ?
            If not - send an message to support@asgvis.com
              JaViXP
              No.. That didn't help, thanks for helping me. I'm going to send a e-mail to ASGVIS now.
              JaViXP's Rendering
                JaViXP
                No te preocupes ya lo solucioné con la ayuda de ASGvis.
                Don't worry I already solved it with help that ASGvis provided.
                And... Many people told me about to change my nick-name to JaviVISTA 😆
                JaViXP's Rendering
                  Care to share the solution? Often people search the web for solution to problems, so it might help them.
                  • I
                    inakim
                    Javi, es un error del vista que traduce automaticamente Program files a Archivos de programa, asegurate que al intalar el Vray en C:/Archivos de programa/Google/Google SketchUp 7/Plugins/ tienes la carpeta VRayForSketchUp y el fichero VRayForSketchup.rb
                    Javi, is a mistake of vista that Program files translates automatic into archivos de programa, assure yourself that when install Vray in C:/Archivos de programa/Google/Google 7/Plugins/, you have the folder VRayForSketchUp and the file VRayForSketchup.rb
                    Change your nick to jaViVista 😆
                      JaViXP
                      Ok, here we go:
                      I didn't do that much, I use SU7 and it was specific for SketchUp 6/7 but the V.7 didn't work. So ASGvis sent me a link to download a specific version for SU7 Here
                      Hope this helps! 😄
                      JaViXP's Rendering
                      • GaieusG
                        Just let me know when you decide and I can change it for you. 😉
                          JaViXP
                          That'd be cool, but I won't change it now 😆
                          JaViXP's Rendering
