    [Plugin] [CityGen] - Street Generator [WIP] (0.5.2a)
    124 Posts 37 Posters 121.3k Views 37 Watching
      @chris fullmer said:
      Some of think of it more like "Google made a platform that has 1 million differet users a week using it, and maybe there is a way we can somehow make money off them eventually". So far all my scripts are free, and this is will be opensource, but eventually I'll get good enought to write something and sell it. eventually.
      Most of favourite applications are applications that allows users to develop plugins and extend it as they see fit. Firefox for instance... πŸ˜‰
        spider74
        interesting,i haven't downloaded it yet but from the pics it looks good.It would suit me for my push/pull cities.Also
        i will recommend it on the skyscraperpage forum-google sketchup section as a lot of people there do cities.Usually
        they do street plans to show the layout etc.
        push/pull city 1-sampadoria
        http://img11.imageshack.us/img11/3277/bigcitya.jpg
        in the above pics there are no road plans,if i had the plugin and put the roads in a different colour
        it would have been way cooler.Iwill try street gen and plus make a new push/pull city ...it all so may
        be great for faces of skyscrapers....
        co.clare ireland
        • halroachH Offline
          halroach
          Very nice stuff you guys have going on here!
          Just a short question:
          How did you color the lines in the posted model? Coloring lines is a very useful tool in itself!
          Is it something specific to the model? cause I wasn't able to copy and paste the colored lines into another model.
          Thank You!
          FlexTools - Super Quick Windows, Doors, Slats...
            Jim
            Hi Halroach (Hal?)
            You need to set the Color By Material option for the Sytles. Then you can paint them using the tool.
            But I think you make a good point - it isn't particularly easy (for me, anyway) to paint lines. It is sort of hit-and-miss.
              Yea, I was thinking of maybe adding a brush painting tool. Where you can sweep. Or maybe have a large hit-radius.
              • Chris FullmerC Offline
                I think that would be a welcome addition to the plugin. I was having frustration issues when I tried to paint lines earlier for my demo too.... They are tricky little things to pin down with the bulky paintbucket.
                Chris
                All my Plugins I've written
                  Yea, I often find that it's easer to select the lines I want to colour and use the Entity info to apply materials. Lines just have too small hit-area.
                  But I don't see any better way to pre-visualize the road construction. Or any other means of defining road width without it quickly becoming too complicated and bulky.
                    We could also offer a way for users to select all boulevards and then pop up a dialog for "assign road widths" and then the plugin does the coloring for the user also.
                    Chris
                      But how do you define a road as boulevards?
                      Applying materials to the lines was what I meant to be the method of defining what the road was. The Material name contained the road type name and width, and the colour was the means of providing visual feedback to the user.
                        Right, I just meant that they could have all their default black road cenerlines set up. Then they selec the ones they want to be a certain type - lets say they choose all the ones they want to 40m wide. Then they have the option of painting them, or they can pop up a road width assigning window that allows them to enter the width and the color, and the plugin does the width association and the coloring for them.
                        Its just another method of associating the color and the width to the centerlines. Its not necessary, but I think some might like it?
                        Chris
                          I'm working on some webdialogs to provide a UI for the read widths.
                          There would be one that would list the road widths and their associated colour. The default setting would be at the top. You could then select the items on the list to make changes to them. Or create new definition. So when you generate the streets you won't be promted every time. It just uses what you've set up. And if nothing is set up, it uses the defaults. (Defaults would be a setting that's stored between sessions.)
                            Jim
                            I have been adding webdialog support to my inputbox class. Same dialog using UI or WebDialog, persistent storage, array and hash-like access to the values.
                            I could add it to the repository, if you like it. The plugin page is here.
                              Thanks Jim, but I'm making some illustrations and extra description to go along with the UI elements. So I need to do this by hand. And the Road Type list will require some special UI elements.
                              But good to know that that plugin class exists. I hadn't noticed it before.
                              • EdsonE Offline
                                Edson
                                thomas,
                                what if a boulevard had its lanes divided by median strips? how would SG deal with it? and how would one have to introduce the lines before running SG?
                                http://www.mahfuz.arq.br
                                  At the moment you'd have to create the lanes as separate streets. Though I'd expect there'd be issues with the rounding as I've yet not made it handle radius' that doesn't fit the space.
                                  I think that median strips would be an advanced feature to add. So when you define custom street types you can specify median strips - I expect that an offset from centre would be useful here in case the lanes are not symmetric. (though asymmetric lines would complicate things...)
                                    Test comment.
                                      Pushed my work on SG 0.5.1 into the repository. Added a base for webdialogs. I added the jQuery Javascript framework to the project.
                                      I'll make the Street Property editor before I publish the 0.5.x version here. I also want to test it against Mac before 0.5.x goes gold.
                                      0.5.1 - New Webdialog UI
                                        Looking great Thom! I guess I am going to have to learn me some Javascript now so I can keep up πŸ˜„
                                        Chris
                                          If you use the jQuery framework you save yourself allot of work. Does much of the nitty gritty boring stuff for you.
                                          I'm also planning to better organize the CSS files. What I'm doing now is that the ui.css in the citygen folder defines the looks of the core UI widgets. For each webdialog I make it's mostly a matter of just defining the correct class to the HTML elements and position them within the window.
                                            Btw, does the descriptive text and illustration of the Angle Threshold property make sense? You can understand how it works from that?
                                            • 6
                                            • 7
                                            • 3 / 7
