    [Plugin] TrueTangents v3.0
    95 Posts 34 Posters 108.2k Views 34 Watching
    • TIGT Online
      This Ruby Script now provides 5 new functions - 'truetangents', 'commontangents', 'trueintersections', 'tangentialarcs' and 'filletarc' - it has plugin sub-menu item 'Tangent-Tools...' or you can type the names to run it from the Ruby Console. It's written to work on a selection BUT could be reconstructed as a cline/arc method if thought useful...
      True Tangents = truetangents
      Select an arc/circle and a cpoint (aka guide-point)
      Run truetangents
      On errors - e.g. no arc selected or the cpoint is inside the circumference - there is a console message.
      It then draws cpoints at the arc-centre, circumference and the 2 tps, and clines on the two radii and tangents - it draws to the true tps - these might not be on the arc itself if it's lightly segmented - now you can rotate, entity-info increase segments or reconstruct the arc as desired so it passes through a tp...
      Common Tangents = commontangents
      Select a second arc/circle
      Run commontangents
      On errors - e.g. 2 arcs not selected or a circle within another circle can have no common tangents - there is a console message.
      It then draws cpoints at the arc-centres, circumferences and tps, and clines on the four radii and two/four tangents - it draws to the true tps - these might not be on the arc itself if it's lightly segmented - now you can rotate, entity-info increase segments or reconstruct the arc as desired so it passes through a tp... Different forms of common tangent are produced if the arcs are separated by clear space or intersect (4 or 2 nr)...
      True Intersections = trueintersections
      Select a cline OR a second arc/circle
      Run trueintersections
      On errors - e.g. non-intersecting arcs/clines - there is a console message.
      It then draws 2 cpoints at the true intersections of the arc and the cline [OR the 2 arcs]; it also adds further centre-points, clines etc and additional true mid-points on the circumference to aid with later arc recreation if desired: special cases produce other drawn results - e.g. cline is a diameter, arcs just kiss or touch at one point...
      Tangential Arcs = tangentialarcs
      Select a Line and an Arc or Circle
      Run tangentialarcs
      It then draws cpoints at the centers of the two tangential-arcs [or one tangential-arc and another looped tangential-arc] and at their tangent-points etc, [messages in console], it also adds clines on the radii to the tangent points-etc. If the line is tangential to the arc or if the tangential arc's radius would be > the arc_radiusx100 or smaller than 1/100th then no cpoint is drawn at the center because it might be many miles away and effect the model's extents - instead a cline is drawn between the line end and tangent-point and a console message suggests you might like to draw a straight line instead... The tangential arc cpoints etc are added at the end of the line nearest to the arc, unless that end is on the circumference, then the other end is used. Internal lines also have tangential-arcs and are created similarly at the end nearest the circumference unless it's touching it...
      Fillet Arc = filletarc
      Select an arc/circle and a cline/line (aka guide-line)
      Run filletarc
      On errors - e.g. no arc selected - there is a console message.
      Enter the required fillet radius in the dialog that appears. If the line doesn't intersect the arc and the fillet radius won't work then you are told and the dialog reopens giving the minimum radius that will work... Assuming the radius is valid then it draws cpoints at the arc-centre, the new fillet arcs' centers and all of the the true tps, with clines on the each of the two radii and the chord linking the pairs of tps - note how these might not be on the arc itself if it's lightly segmented - there are 4 or 8 possible fillet arcs depending on whether or not the line intersects the selected arc, draw over the one(s) you want using the 2D Arc / Circle Tool etc...
      EDITS:
      v1.1 now adds all 4 common-tangents for non-overlapping circles
      v1.2 glitch on some external common-tangents permutations fixed
      v1.3 additional cpoints added at circumference intersections to aid arc redraw though 3 points if needed
      v1.4 extra cpoints/clines added to opposite circumference intersections to aid arc redraw in other direction
      v1.5 true intersections added for arc+cline OR arc+arc
      v1.6 tangential arcs added for line+arc
      v1.7 fillet arc added for arc/circle + line/cline, dialog to enter fillet radius
      v1.8 missing 5th menu item fixed
      v1.9 sub-menu 'Tangent-Tools...' added
      v2.0 tolerance added on the coplanar check for arcs
      v3.0 Float 'n1=~n2' replaced with 'eq(n1,n2)' avoiding potential clashes.
      More info here http://sketchucation.com/plugin/771-truetangents
      Please get the latest version from the PluginStore...
      http://sketchucation.com/pluginstore?pln=TrueTangents
        Ben Ritter
        TIG, Thank you so much. Look forward to giving it a try. I appreciate your generosity in sharing this.
          Ben Ritter
          TIG,
          True tangents worked fine, couldn't get common tangents to execute.
          • BepB Offline
            Bep
            @ben ritter said:
            TIG,
            Same here
            Bep
            "History is written by the winners"
            • TIGT Online
              commontangents - are you selecting two arcs / circles that are as the image ?
              The images were made from SUp 7 using the tools... Arcs/circle must be coplanar - what's the Ruby Console error message ?
                Jim
                TIG, thanks - both methods worked fine for me.
                  Ben Ritter
                  It now worked after closing and re-opening SU.
                    Ben Ritter
                    Is there any way to get the outside tangents, as in your overlapping example, without overlapping circles?
                    • TIGT Online
                      I've added the 2 'external' common-tangents to the non-overlapping version... Thanks for the feedback.
                      Find v1.1 here: http://www.sketchucation.com/forums/scf/viewtopic.php?p=160780#p160780
                      • TIGT Online
                        I've just found an error in certain combinations of arc radius and rotation in 3D. Sometimes the common-tangents weren't drawn right... Found a fix... here's update v1.2
                          Dan
                          Thank you, Tig!
                          I was waiting for longtime for tools like this one, helping the 2d drafting directly in SU.
                          I also claimed for years for better native SU 2d drafting tools, but it seems that AutoCAD still has some magic attraction, although buying it only to use its 2d capabilities seems to me a waste of money 😒
                          The bad news, though, is that TrueTangents makes my SU 7 to end with bugsplat on initializing 😞 It surely is a ruby conflict, because deleting it solves the issue - actually I have no more than 10 or 12 ruby installed).
                          I'll try to find out where the problem is.
                            Thank you very much for this TIG. This will come in very handy.
                            • takesh hT Offline
                              takesh h
                              Thanks a bunch TIG, now a simple thing is truely simple.
                              I confirmed it works on Macs. 😉
                                joergj
                                Thank you, TIG!
                                I missed this tool a lot of times in the past.
                                And a special thank you for making it work in SU5 and on the mac!
                                Jörg
                                • P Offline
                                  putnik
                                  Nice one TIG, thanks a lot!
                                  http://keshas.info
                                    cyan.archnet
                                    GREAT PLUGUN!, thanks a lot!
                                    • erikBE Offline
                                      erikB
                                      very usefull !!
                                      Thanks TIG
                                      erikB
                                      • TIGT Online
                                        Here's v1.3... http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
                                        I've added some more cpoints - at the intersections of the circumference(s) and the line from cpoint-to-centre or centre-to-centre - these can be useful if you want to redraw an arc through three points from tp to tp quickly with the same radius...
                                        • TIGT Online
                                          Here's v1.4 http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
                                          It's updated to have extra cpoints/clines on the opposite sides of the arcs' circumferences - now to aid in possible redraw in both directions of arc's curve...
                                          • H Offline
                                            HBMASA
                                            TIG,I wanted a celebration, this plug-in.
                                            The traditional skills are essential to kikujutu Japan.
                                            • 1 / 5
