    [Plugin] TrueTangents v3.0
    95 Posts 34 Posters 114.9k Views 34 Watching
      Ben Ritter
      TIG, Thank you so much. Look forward to giving it a try. I appreciate your generosity in sharing this.
        Ben Ritter
        TIG,
        True tangents worked fine, couldn't get common tangents to execute.
        • BepB Offline
          Bep
          @ben ritter said:
          TIG,
          Same here
          Bep
          "History is written by the winners"
            commontangents - are you selecting two arcs / circles that are as the image ?
            The images were made from SUp 7 using the tools... Arcs/circle must be coplanar - what's the Ruby Console error message ?
              Jim
              TIG, thanks - both methods worked fine for me.
                Ben Ritter
                It now worked after closing and re-opening SU.
                  Ben Ritter
                  Is there any way to get the outside tangents, as in your overlapping example, without overlapping circles?
                    I've added the 2 'external' common-tangents to the non-overlapping version... Thanks for the feedback.
                    Find v1.1 here: http://www.sketchucation.com/forums/scf/viewtopic.php?p=160780#p160780
                      I've just found an error in certain combinations of arc radius and rotation in 3D. Sometimes the common-tangents weren't drawn right... Found a fix... here's update v1.2
                        Dan
                        Thank you, Tig!
                        I was waiting for longtime for tools like this one, helping the 2d drafting directly in SU.
                        I also claimed for years for better native SU 2d drafting tools, but it seems that AutoCAD still has some magic attraction, although buying it only to use its 2d capabilities seems to me a waste of money 😒
                        The bad news, though, is that TrueTangents makes my SU 7 to end with bugsplat on initializing 😞 It surely is a ruby conflict, because deleting it solves the issue - actually I have no more than 10 or 12 ruby installed).
                        I'll try to find out where the problem is.
                          Thank you very much for this TIG. This will come in very handy.
                          • takesh hT Offline
                            takesh h
                            Thanks a bunch TIG, now a simple thing is truely simple.
                            I confirmed it works on Macs. 😉
                              joergj
                              Thank you, TIG!
                              I missed this tool a lot of times in the past.
                              And a special thank you for making it work in SU5 and on the mac!
                              Jörg
                                putnik
                                Nice one TIG, thanks a lot!
                                http://keshas.info
                                  cyan.archnet
                                  GREAT PLUGUN!, thanks a lot!
                                  • erikBE Offline
                                    erikB
                                    very usefull !!
                                    Thanks TIG
                                    erikB
                                      Here's v1.3... http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
                                      I've added some more cpoints - at the intersections of the circumference(s) and the line from cpoint-to-centre or centre-to-centre - these can be useful if you want to redraw an arc through three points from tp to tp quickly with the same radius...
                                        Here's v1.4 http://forums.sketchucation.com/viewtopic.php?p=160780#p160780
                                        It's updated to have extra cpoints/clines on the opposite sides of the arcs' circumferences - now to aid in possible redraw in both directions of arc's curve...
                                        • H Offline
                                          HBMASA
                                          TIG,I wanted a celebration, this plug-in.
                                          The traditional skills are essential to kikujutu Japan.
                                          • BepB Offline
                                            Bep
                                            Hello Tig,
                                            Would it be possible to add "true intersections points" to the plugin.
                                            These would indicate where cirkels and arcs mathematicly intersect.
                                            as in the second picture
                                            As I understand true cirkels in Sketchup are impractical because the would couse a to many faces in a model,
                                            a true "construction cirkel" as in the first picture,(that would not be able to create a face to be push-pull't) as a build in tool or plugin however would be the best solution IMHO to overcome a lot of strugling of the ruby programmers to repair this shortcomming of Sketchup.
                                            Thanks for all your great plugins.
                                            Bep van Malde
                                            True consstruction circel
                                            True intersections
                                            • 1 / 5
