    VCB box in SketchUp 7 toolbar
    13 Posts 7 Posters 4.1k Views 7 Watching
    • J
      jeff jacobs
      Alright, I've had enough.
      This is the problem. Google finally wised up and put the (VCB) measurement or data entry in the the toolbar instead of the bottom right corner of the window where it was always getting covered up. Problem is, it has never worked there for me in version 7. What the heck am I missing?
      In the golden days of yore (version 6), if I wanted to to the change my camera FOV, I can type in the number in the box and in Version 6, my camera FOV changes accordingly. In version 7 IT HAS NEVER WORKED . . . EVER. I have to pick the "zoom" icon and drag while holding down the shift key to get the value to change. There is absolutely no way I can enter a number or get an exact value.
      Well, I've lived with this condition and the lousy obj export of version 7 without complaining until today when I tried to create a terrain with the sandbox tool. I cannot change the grid size. Same problem with Smoove etc. The VCB does not respond. I can type all the numbers I want in the VCB and NOTHING will change.
      I'm on a 10.5.7 Quad-Core mac, version SketchUp 7 (7.0.10248) Pro.
      I cannot possible be the only person that has this problem with version 7.
      • J
        jeff jacobs
        James at PPB2 said his VCB works fine on his PC in the default position, the bottom right corner. SO I deleted the VCB in my toolbar and the VCB defaulted to the bottom right corner. Everything works fine there. I put it back in the toolbar and it doesn't work.
        How does go unnoticed for so long?
        • R
          remus
          mines working fine wherever it goes, so id guess this is a mac bug? can anyone confirm?
          • Chris FullmerC
            Yeah, thts odd. it works fine for me on Vista and XP in the default and anywhere I put it.
            Chris
            All my Plugins I've written
            • D
              dylan
              I am working on the same version of OS X Jeff and things are working ok.
              I have attached a screenshot of where mine sits.
              Measurement Box
              http://dmdarchitecture.co.uk/
              • thomthomT
                Does it work when you detach it?
                • D
                  dylan
                  I can move it to the top Toolbar and it works, but I cannot have it floating in the main window.
                  • GaieusG
                    On the PC you have to check "Measurements" in the View > Toolbars menu to detach it to float.
                    • J
                      jeff jacobs
                      I cannot detach it on my Mac. How would you do that?
                      I also tried SketchUp 7 on my MacBookPro 17". Same results. VCB does not work in toolbar, but does in bottom right.
                      • jeff hammondJ
                        jeff hammond
                        i have the same basic set up (quad mac, 10.5.7, su7) and i don't have the problems you're experiencing.
                        i always keep my VCB in the lower right corner of the window but when i put it in the toolbar, it works exactly the same.
                        when trying to change the grid size, you select the 'from scratch' tool then before doing anything else, type the spacing then return.. then mouse click where you'd like the grid to be anchored and the spacing will be correct.. is that how you're doing it?
                        dotdotdot
                        • J
                          jeff jacobs
                          Yes sir. Same way I've been doing for years. FOV doesn't work, sandbox tools don't work. Nuttin'. Everything works fine on the bottom right corner.
                          • Chris FullmerC
                            Any way you could make a video of it? If its a bug, a video might help verify and track it.
                            Chris
                            • J
                              jeff jacobs
                              Chris
                              Here you go.
                              VCB.mov.zip
