    SCF Power Toolbar
    18 Posts 8 Posters 20.8k Views 8 Watching
    • Bob JamesB
      Bob James
      Max:
      Where did this toolbar come from?
      I have both weld.rb and pathcopy.rb and do not have the toolbar you show in your tutorial.
      • CadFatherC
        CadFather
        Hi Bob, go the website/downloads http://www.quarr-it.com - check out the video tutorials too
        • Bob JamesB
          Bob James
          I did that. That's where I saw the toolbar and wondered where it comes from.
          • G
            Griffith
            Max:
            It's in the download section with many other toolbars
            http://www.special.eclipse.co.uk/sketchup_training.html
            I've never heard of Quarr-IT looks very cool btw.
            I'll keep an eye on it.
            • Bob JamesB
              Bob James
              [/quote]
              Thank you!! Those are great toolbars. Too bad they aren't all Mac-compatible 😐
              • CadFatherC
                CadFather
                yes Bob, it's a pity but i will work something out with Rick W in the near future which should work on a mac.
                • Bob JamesB
                  Bob James
                  Max,
                  I put SCF Power Toolbar 1.0 Beta in the Library/Application Support/Google SketchUp 7/SketchUp/Plugins folder and the Power Toolbar did not load. I then tried it in /Users/robertjames/Library/Application Support/Google SketchUp 7/SketchUp/Plugins and it still did not load (I tried it here because Profile Builder only works if you put it in the users folder).
                  Do I need to do something else?
                  • CadFatherC
                    CadFather
                    Hi Bob, don't know what to suggest apart from putting the plugins into the usual folder..( i know there will be parsing problems but i cannot check/fix as i don't have a mac)
                    perhaps someone with a mac was successful and can help?
                    • Bob JamesB
                      Bob James
                      Just to be sure: I put the folder SCF Power Toolbar 1.0 Beta in the plugins folder.
                      Should I have extracted the contents of the folder into the plugins folder?
                      • Bob JamesB
                        Bob James
                        I loaded just the basic plugins and all of the contents of the SCF Power Toolbar folder.
                        (eval):6094: compile error
                        (eval):4921: parse error, unexpected ',', expecting ')'
                        if (n1.between? (n2 - interval), (n2 + interval))
                        ^Error Loading File cd_power_extension_m.rb
                        ^Error Loading File cd_power_m.rb
                        Also it requests adding progressbar.rb, but that was already in Plugins.
                        The toolbar loaded. Tried bevel tool and it locked up SU with an error messsage "Expected Array"
                        • A
                          arnoldwe
                          Does it work for sketchup 6 ?
                          • GaieusG
                            Every plugin that runs on v7 should (more or less) run on v6, too so give it a try (but of course you never know).
                            • Bob JamesB
                              Bob James
                              I just wanted to bring this post to the top of the list for a moment.
                              If you haven't tried this plug-in you are really missing something special. It combines 23 tools in nine groups from 10 authors and the Google Team.
                              If you want to see all the tools in action go to:
                              http://www.special.eclipse.co.uk/scf_quarrit/scf_pow.html
                              If you are not impressed, then I wonder what would.
                              Many, many thanks to the authors and for putting them into one tool. It's title is "SCF Power Toolbar 1.0 Beta", but don't be fooled by that: it's awesome.
                              Unfortunately, I can't get it to work on my Mac 😒
                              • Bob JamesB
                                Bob James
                                I downloaded the Mac version from QuarrIT.
                                First I put all the parts of the plugin into the standard plugin location (HD/Library/Applications Support/...
                                It did not work at all.
                                Then I put them into HD/username/Library/Applications Suppport/.....
                                I got the toolbar (see attachment), the error message upon loading (see attachment), and the following results:
                                Don't Work:
                                1 - Extrude Along Path
                                4 - Mirror 3D/2D
                                8 - Push-Pull Multiple Faces
                                9 - Push-Pull Random
                                10 - Push-Pull by Vector
                                11 - Extrude Lines by Vector
                                13 - Protrude (dialog box comes up, but nothing works)
                                14 - Sketchy Bevel (Error message: wrong argument type nil (expected array) which doesn't go away.
                                15 - Chamfer Along Edges
                                16 - FFD 3x3
                                17 - FFD nxn (dialog box comes up, but nothing works)
                                18 - FFD Edge Lock
                                19 - FFD Edge Unlock
                                20 - Component Spray
                                21 - Component Spray Default
                                22 - Balustrade
                                Work:
                                2 - Copy Along Path - Nodes
                                3 - Copy Along Path - Distance
                                5 - Mover2
                                6 - Drop at Intersection
                                7 - Drop by Distance
                                12 - Weld Edges
                                This is the toolbar
                                This is the error message upon loading
                                • R
                                  rongvuong
                                  not run on sketchup 8
                                  • Bob JamesB
                                    Bob James
                                    The comments I made on 16 Sep 2009 now apply to SU8 on 8 Sep 2010 😲
                                    • V
                                      vuhaihec2
                                      I can't download it. Could you send me a link to download the SCF powertoolbar for Sketchup pro 2017, please?
                                      • jujuJ
                                        juju
                                        I think this is the same thing:
                                        SketchUp Plugins | PluginStore | SketchUcation
                                        SketchUp Plugin and Extension Store by SketchUcation provides free downloads of hundreds of SketchUp extensions and plugins
                                        (sketchucation.com)
