    SCF Power Toolbar
    18 Posts 8 Posters 20.6k Views 8 Watching
    • Bob JamesB Offline
      Bob James
      Max,
      I put SCF Power Toolbar 1.0 Beta in the Library/Application Support/Google SketchUp 7/SketchUp/Plugins folder and the Power Toolbar did not load. I then tried it in /Users/robertjames/Library/Application Support/Google SketchUp 7/SketchUp/Plugins and it still did not load (I tried it here because Profile Builder only works if you put it in the users folder).
      Do I need to do something else?
      • CadFatherC Offline
        CadFather
        Hi Bob, don't know what to suggest apart from putting the plugins into the usual folder..( i know there will be parsing problems but i cannot check/fix as i don't have a mac)
        perhaps someone with a mac was successful and can help?
          Bob James
          Just to be sure: I put the folder SCF Power Toolbar 1.0 Beta in the plugins folder.
          Should I have extracted the contents of the folder into the plugins folder?
            Bob James
            I loaded just the basic plugins and all of the contents of the SCF Power Toolbar folder.
            (eval):6094: compile error
            (eval):4921: parse error, unexpected ',', expecting ')'
            if (n1.between? (n2 - interval), (n2 + interval))
            ^Error Loading File cd_power_extension_m.rb
            ^Error Loading File cd_power_m.rb
            Also it requests adding progressbar.rb, but that was already in Plugins.
            The toolbar loaded. Tried bevel tool and it locked up SU with an error messsage "Expected Array"
              arnoldwe
              Does it work for sketchup 6 ?
                Every plugin that runs on v7 should (more or less) run on v6, too so give it a try (but of course you never know).
                  Bob James
                  I just wanted to bring this post to the top of the list for a moment.
                  If you haven't tried this plug-in you are really missing something special. It combines 23 tools in nine groups from 10 authors and the Google Team.
                  If you want to see all the tools in action go to:
                  http://www.special.eclipse.co.uk/scf_quarrit/scf_pow.html
                  If you are not impressed, then I wonder what would.
                  Many, many thanks to the authors and for putting them into one tool. It's title is "SCF Power Toolbar 1.0 Beta", but don't be fooled by that: it's awesome.
                  Unfortunately, I can't get it to work on my Mac 😒
                    Bob James
                    I downloaded the Mac version from QuarrIT.
                    First I put all the parts of the plugin into the standard plugin location (HD/Library/Applications Support/...
                    It did not work at all.
                    Then I put them into HD/username/Library/Applications Suppport/.....
                    I got the toolbar (see attachment), the error message upon loading (see attachment), and the following results:
                    Don't Work:
                    1 - Extrude Along Path
                    4 - Mirror 3D/2D
                    8 - Push-Pull Multiple Faces
                    9 - Push-Pull Random
                    10 - Push-Pull by Vector
                    11 - Extrude Lines by Vector
                    13 - Protrude (dialog box comes up, but nothing works)
                    14 - Sketchy Bevel (Error message: wrong argument type nil (expected array) which doesn't go away.
                    15 - Chamfer Along Edges
                    16 - FFD 3x3
                    17 - FFD nxn (dialog box comes up, but nothing works)
                    18 - FFD Edge Lock
                    19 - FFD Edge Unlock
                    20 - Component Spray
                    21 - Component Spray Default
                    22 - Balustrade
                    Work:
                    2 - Copy Along Path - Nodes
                    3 - Copy Along Path - Distance
                    5 - Mover2
                    6 - Drop at Intersection
                    7 - Drop by Distance
                    12 - Weld Edges
                    This is the toolbar
                    This is the error message upon loading
                      rongvuong
                      not run on sketchup 8
                        Bob James
                        The comments I made on 16 Sep 2009 now apply to SU8 on 8 Sep 2010 😲
                        • V Offline
                          vuhaihec2
                          I can't download it. Could you send me a link to download the SCF powertoolbar for Sketchup pro 2017, please?
                          • jujuJ Offline
                            juju
                            I think this is the same thing:
                            https://sketchucation.com/pluginstore?pln=JHS_PowerBar_2015
