    SoapSkin&bubble time limit finished?
    15 Posts 13 Posters 24.9k Views 13 Watching
    • C
      Click Draw
      Hi all,
      Is there an update coming to download the Soap Skin Bubble ruby? My time limit ran out....sad day for me 😞
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
      J 1 Reply Last reply
      • J
        johnsenior1973
        http://www.tensile-structures.de/sb_software.html
        • C
          Click Draw
          That's great...thank you for the link. It seems much faster...Awesome
          Jeff
          • jwlyon1J
            jwlyon1
            Wow! I guess there s a lesson here to always read the fine print on the free plugins.
            I totally missed the "expires on" line there.
            Macbook Pro/ iMac
            OSX 10.7.2 Sketchup 8
            rogue-z is here!
            • Chris FullmerC
              You should probably read the fine print on everything!
              All my Plugins I've written
              • BurkhardB
                Burkhard
                Yep click here for more information
                You can't shut down your computer without spending 100$ - Make a donation now
                http://www.ia-plus.de
                • G
                  gr8fzy1
                  My soapskin bubble plugin is going to expire in about a month and a half (april 10, 2013), has anything new been done with it or is this it for the plugin?
                  • L
                    luuhanhung
                    What should I do If My Plugin Expire? Reinstall it or anything else?
                    • mitcorbM
                      mitcorb
                      Return to the site from which you downloaded, and do it again?
                      As indicated by comments and responses in this thread.
                      • M
                        monkeyplusplus
                        Oh look, the time limit is over again. Lovely.
                        • TIGT
                          The Extension-Warehouse download currently expires 10 April 2016 - so almost a year left !
                          http://extensions.sketchup.com/en/content/soap-skin-bubble
                          • H
                            hadiis Newcomers
                            what did you do to solve it?
                            • TIGT
                              The current EWH version
                              https://extensions.sketchup.com/extension/c8d49537-51db-40a7-ac0e-474a244eb525/soap-skin-bubble
                              suggests that it's compatible with v2022 ??
                              • J
                                JoMaLeFe @Click Draw
                                @Click-Draw
                                Este plugin tiene fecha de caducidad en todas sus versiones.
                                Y si actualizas solo vale para las versiones de SketchUp mas recientes.
                                Existe ste una sencilla solución. Si descargar el plugin ni una nueva versión de SketchUp.
                                Manbolded textualmente o valiéndote de un archivo bat (por bloques) por medio de el comando Date en la linea de comandos variamos la fecha hacia atrás.
                                Si lo hacemos por archivo bat podemos volver a poner la fecha a la actualidad al salir del programa
                                Yo así lo tengo en un win 10 con un SketchUp 8 de cuando Google.
                                Mike AmosM 1 Reply Last reply
                                  Mike Amos @JoMaLeFe
                                  @JoMaLeFe
                                  English please.
