    Why is this text invisible?
    10 Posts 5 Posters 851 Views 5 Watching
      Jim
      Here's a model with some screen text. Any idea why I can't make it visible?
      123.skp
        Jim
        Oh, it shows up when I have any other geometry in the model.
        It just seems like it shouldn't be dependent on what else is in the model.
        • Wo3DanW Offline
          Wo3Dan
          Jim,
          There was a bug report for this last month and 7 months ago. (....0031)
          Since a model without any geometry is of no use (not my words but it sounds logic) it must have had no priority to fix.
          Once there is geometry all screen text will reappear.
          Wo3Dan
            Jim
            Ok, thanks Wo3Dan. I think I'll call it a bug - inconsequential as it is.
            • Jean LemireJ Offline
              Jean Lemire
              Hi folks.
              Yes, I signaled this bug but, as Wo3Dan wrote, it is without much consequence.
              However, since SU 6 did not present this bug, I reported it for SU 7.
              Just ideas.
                This bug WAS in v6, but it was never addressed... However when might you want 'screen-text' without geometry ?
                  Jean Lemire
                  Hi Tig, hi folks.
                  In my version of SU 6 for PC (6.4.112) if I select the Text Tool and add a screen text (text not attached to any geometry), it shows even if there are no geometry in the model. In SU 7, it do not show. This difference in behavior between 6 and 7 is what prompted me to signal (or resignal) this bug (or glitch) since, as you wrote, it is not really usefull to have text without geometry unless you want a template with some specific message showing when starting SU.
                  Just ideas.
                    Jim
                    I want a blank template with screen text, so this is exactly how I found this out.
                    • Chris FullmerC Offline
                      I agee, my template in 6 had text on the screen, but no more in 7.
                      All my Plugins I've written
                        Jean Lemire
                        HI folks.
                        While waiting for a fix in SU 7, I tried this workaround:
                        1 - I draw a circle centered on the origin.
                        2 - I add a "Point at center".
                        3 - I delete the circle.
                        4 - I hide the point.
                        5 - I add the required Screen Text.
                        This gives me a minimalist file that can be used as a template, if required.
                        Just ideas.
