    Parts of Model Disappearing
    4 Posts 3 Posters 430 Views 3 Watching
    • R
      Rudbeckia
      Hello All again,
       the current model i am working on is big, its currently at 18mb, when I toggle around
      parts of it disappear, is this a memory problem?
      i checked the current memory usage and its at 60%, so why would part of the model be disappearing when I toggle around, any ideas?
      • TIGT
        There are limits to what OpenGL can handle... If you model is VERY big or it's a long way from the origin the you can get clipping of the nearest parts. Try toggling perspective and parallel camera settings on/off and also trying zooming extents between to fix it. If there's lots of stuff you aren't needing all of the time then try putting that onto 'switched-off' layers so there are fewer things to process...
        • R
          Rudbeckia
          great, thanks yes thats exatly what it is doing "clipping" parts of the model, i will try what you suggested
          • GaieusG
            This is where clipping (and possible troubleshooting) is described more detailed:
            http://sketchup.google.com/support/bin/answer.py?hl=en&answer=36261
