    Creating HDRIs with Terragen and VRAY
    renderpluginsextensions
    14 Posts 4 Posters 3.4k Views 4 Watching
      AcesHigh
      Gosh, I ask too many questions... but here is one more... Ive tried producing HDRIs with Terragen. The end result, imagewise, is awesome... perfect to use as background image (360º hor and vert pano)... the problem comes with the HDRI part itself!
      while on HDRI programs, the image seems to behave perfectly as for exposure, but when I use it as GI in VRAY, not only it barely illuminates anything, as it creates some very weird ULTRA BRIGHT PIXELATED SPOTS all over the place! Does anyone has any idea why this happens?
        Screenshots?
          Often you want to sample down and blur the HDR you use for GI lighting to avoid artefacts.
            AcesHigh
            @thomthom said:
            Screenshots?
            01
            from the ground
            http://img13.imageshack.us/img13/7648/teste01.jpg
            02
            from above, but close
            http://img9.imageshack.us/img9/5069/teste02.jpg
            03
            from above, very far away (cant even see the ball anymore. Notice the artifacts pattern REMAIN THE SAME, its constant, no matter the distance!!!!
            http://img9.imageshack.us/img9/7662/teste03.jpg
              Odd. Try blurring the GI HDR you use? Don't have to do anything to the Background HDR though.
                AcesHigh
                blurred it to 50. Nothing changed.
                I was mistaken. Setting the bitmap multiplier at 50 brightened up the image, but the artifacts persisted.
                  Might be that Terragen has generated some extra bright pixels...
                    remus
                    You could try the HDR in another app to see if its an issue with vray or with the HDR itself 👍
                      AcesHigh
                      I wonder why they dont show up in the image when viewing it at HDRShop or Photoshop. It only happens in VRAY. I followed some tutorials on the net to make the HDRs... neither mentioned it, but neither mentioned VRAY either 😄
                        AcesHigh
                        do you have any suggestion of app for me to try it?
                          Would be that it's just a single pixel. And Photoshop should only display certain colour range, but V-Ray uses the whole range to calculate the light.
                            remus
                            Kerkythea is the first one that springs to mind. Indigo might be able to do it, but youd have to convert to .exr first, which might do weird things.
                              sepo
                              Also try in LightUp...
                                AcesHigh
                                tried in Lightup... no artifact appeared, but I suppose Lightup dont really uses HDRI images... I mean... it works the same for .HDR or .JPG images!
