    [Plugin] ComponentReporter++ v1.2
    71 Posts 22 Posters 66.8k Views 22 Watching
      IF you want to use the nested component containing the linear info then you can readily add extra code into another column in the CSV. OR make a separate CSV report on linear info.
      Here's how to do it separately.
      The tool runs***, its code finds all components in the model with instances having a name containing 'hedge' and thereby their nested component giving the linear info drawn as a line or curve.
      It takes all edges in this nested component and totals their length.
      It writes a CSV listing the instance-name [e.g. 'c.hedge'], instance's-layer, definition-name, linear total [in meters]
      Sorted in order, with a header line and a total of the minear-meterage.
      Copy/paste this whole set of code into a new file [Notepad.exe] that you make in the Plugins folder named ' TIG-hedgelengths.rb'
      require 'sketchup.rb'
      module TIG
       unless file_loaded?(File.basename(__FILE__))
         UI.menu("Plugins").add_item("Hedges Length CSV"){self.hedgelengths()}
       file_loaded(File.basename(__FILE__))
       def self.hedgelengths()
        model=Sketchup.active_model
        if model.path.empty?
          dir=Dir.pwd
      	tit="Untitled"
        else
          dir=File.dirname(model.path)
      	tit=model.title
        rows=[]
        model.definitions.each{|d|
          next if d.group? or d.image?
      	d.instances.each{|i|
      	  txt=""
      	  if i.name=~/[Hh]edge/
      		txt << i.name+","
      		txt << i.layer.name+","
      		txt << d.name+","
      		lin=0
      		d.entities.each{|c|
      		  if c.class==Sketchup;;ComponentInstance
      		    c.definition.entities.each{|e|
      			  if e.class==Sketchup;;Edge
      			    lin+=e.length
      		txt << sprintf("%.3f", lin.to_m) ### 3d.p.
      	  rows << txt
        rows.dup.each{|e| rows.delete(e) if e.empty? }
        rows.sort!
        ## add total
        rows=["INST-NAME,INST-LAYER,DEFN,LIN.METERS"]+rows
        tot=rows.length.to_s
        rows << "\n,,TOTAL,=SUM(D2;D#{tot})"
        csv=File.join(dir, tit+"_HedgesLength.csv").tr("\\","/")
        begin
           file=File.open(csv,"w")
        rescue### trap if open
           UI.messagebox("Report;\n\n  "+csv+"\n\nCannot be written - it's probably already open.\nClose it and try making the Report again...\n\nExiting...")
      	 return nil
        rows.each{|row| file.puts(row) }
        file.close
        UI.messagebox("Report;\n"+csv+"\nWritten.")
        UI.openURL("file;///"+csv)
      ***Usage: either type TIG.hedgelengths in the Ruby Console... OR more easily use the Plugins menu item...
      • U Offline
        unearthed
        Thanks TIG, that's simply amazing Elegant and simple.
        Now thanks to your plugins I've got the basis for a complete plant counter (areas, individual plants and hedges and shelterbelts - Sketchup has just become a LOT more useful), thanks again.
        output from TIG-hedge.lengths.rb
        Growplan - People ∩ Plants ∩ Place
        windows 7 64b, 4GB RAM, SU 8.0.16846
        Gimp, QGIS, Vectorworks 12, Bricscad 11
          samyell77
          Hi Tig,
          Great plugin - thanks. Ive used this on several jobs now and wonder if you can help me to make a few tweaks. I've been trying to use this to count components in a selection. I know that the plugin exports 3 csv documents and was wondering if you can help me to tailor the script to get the count Im after - Im afraid Im a total noob to Ruby but am more than happy to have a play with it if you can offer a little advice.
          Id like to be able to generate a count for eithera whole model or for a selection within the model. I know that the script already generates a count for a selection but I'd like to be able to summarize items with the same name -giving me a total number.
          I also wonder if its possible to only display the component name and the count and none of the other information (guid, description, material etc). Im trying to reduce the amount of work I need to do to tidy up the csv files that are generated.
          Ive been playing with this whenever I get some spare time but would love a little advice.
          Any help much appreciated.
          Sam
          SU Pro 2016
          Dell Precision M4800
          PC Windows 10
          Intel Core i7-4900MQ @ 2.80ghz
          Nvidia Quadro K2100M
          16gb RAM
            Here's v1.2 made MAC compatible... http://sketchucation.com/forums/viewtopic.php?p=147658#p147658
              sidpickle
              Thanks TIG seems to work OK. I'll have a play with it.
              Ted Robbens
              • Q Offline
                quarch
                Unfortunately I am having errors in counts for nested components...
                example...
                3 component 1 in model
                1 component 2 inside component 1...
                Report returns 3 counts of 1 and 1 count of 2 in stead of 3 counts of 1 and 3 counts of 2
                Counts in instances report are correct.
                  example...
                  There ARE 3 instances of compo1.
                  There IS 1 instance of compo2.
                  You might 'see' 3 of compo2, but these are actually three representations on the same object.
                  The different reporting formats are a way of covering various bases...
                  If you want it to somehow report things differently, then rework the code as you wish...
                  It is 'open source' after all... 😒
                  • O Offline
                    Omarian
                    TIG,
                    This is similar to a problem I am having. I want to call up the running length of walls at base (where Y axis would be zero, and which would exclude door openings)or ceiling (which would give total lengths for molding etc). Is it possible to convert the above reporting script into a DCfunction in much the same way as you had created the DCvolume function? You may need specific functions that would take only the sum of lengths of the edges of the outer or inner faces of the wall at the base(ie excluding doors) and at the ceiling (which would include door openings).
                      It wouldn't be so easy...
                      BUT you can write any custom function you like to add to a DC...
                      So let's say you want the perimeter of all faces that have a normal==Z_AXIS.reverse [facing down - i,e, the bottom of a ceiling slab] inside a DC you do something like:
                      require('sketchup')
                      require('dynamiccomponents.rb')
                      if defined?($dc_observers)
                        # Open Dynamic Component Functions (V1) class, only if DC extension is active
                      class DCFunctionsV1
                       protected
                       # return the perimeter (in inches) of face.normal==Z_AXIS.reverse
                       if not DCFunctionsV1.method_defined?(;perimeter)
                        def perimeter(a) # Usage as DC function; =perimeter()
                      	se = @source_entity
                      	if se.is_a?(Sketchup;;Group)
                      		allfaces = se.entities.grep(Sketchup;;Face)
                      	else #component-instance
                      		allfaces = se.definition.entities.grep(Sketchup;;Face)
                      	faces=[]
                      	allfaces.each{|face| faces << face if face.normal==Z_AXIS.reverse }
                      	tr = se.transformation
                      	xs = tr.xscale #***
                      	ys = tr.yscale #***
                      	peri = 0.0
                      	faces.each{|face|
                      		tlen = 0.0
                      		face.outer_loop.edges.each{|e|
                      			elen = e.length # this is an unscaled length
                      			slen = elen*(1) #*** adjust for any X/Y scaling in (1) if needed ?
                      			tlen += slen
                      		peri += tlen
                          return peri
                      end#class
                      end#if
                      This takes no notice of any scaling applied to the DC object, reporting the original perimeter...
                      • O Offline
                        Omarian
                        Thanks a million, it worked like a charm.
                        • bagateloB Offline
                          bagatelo
                          @TIG
                          I only need The only modification I would like this plugin would measure diagonal objects properly, instead of bounding box ... and to work with groups also...
                          Please take a look to another request made by me:
                          http://sketchucation.com/forums/viewtopic.php?f=323&t=54080&p=490233#p490163
                          • nanolinN Offline
                            nanolin
                            @tig said:
                            Here's a version that might do what you want or be adapted easily...[attachment=0:28vg1yda]<!-- ia0 -->TIG-exportDCs2csv.rb<!-- ia0 -->/attachment:28vg1yda TIG 2011
                            Script:
                            Type:
                            TIG.exportDCs2csv
                            in the Ruby Console to run it.
                            Exports all DCs is the model with a Name,LenX,LenY,LenZ,Layer[s]...
                            'CSV' file - in the model's folder and named after the model thus:
                            ModelName.skp >>> ModelNameDCs.csv
                            If a new model is unsaved the current directory receives the new file.
                            All Layers used in the DC are listed by name and visible ones marked
                            thus >>LayerName<<
                            Edit sep="," if something other than separating comma is desired e.g. ';'
                            Make sep="\t" if a TSV file is desired and change ext="csv" to ext="tsv".
                            It uses the current Model Units.
                            Version:
                            1.0 20111104 First issue.
                            I was unable to generate the report. My model is in decimal> millimeters.
                            The dynamic component is in cm. Can you tell me what the problem is.
                            (This returns ruby console)
                            TIG.exportDCs2csv
                            Error: #<ArgumentError: C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TIG-exportDCs2csv.rb:48:in to_l': Cannot convert "23.425196850393703" to Length> C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TIG-exportDCs2csv.rb:48 C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TIG-exportDCs2csv.rb:48:in exportDCs2csv'
                            C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TIG-exportDCs2csv.rb:45:in each' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TIG-exportDCs2csv.rb:45:in exportDCs2csv'
                            (eval):48
                            thanks
                              Do you have ',' set as your decimal-separator, instead of '.' ?
                              This might cause issues ??
                              • nanolinN Offline
                                nanolin
                                I did 2 tests
                                1. drawing from scratch, I think the componet, add option LenX leny, lenz, the report is generated normally.
                                2. If this same component attributes modify a component value (eg 10 cm to 20 cm lenz), then display the error of failing to convert ...
                                thanks
                                pd. I have a component I created and I'm doubling, changing their values ​​to create furniture.
                                This report would be a solution to export cuts grain orientation panel
                                • nanolinN Offline
                                  nanolin
                                  With separator "," error occurs.
                                  With separator "." export the file, but does not make mm
                                  As coidgo would have to call from the menu?
                                  It would be so?
                                  UI.menu("PlugIns").add_item("Tig Export") {
                                  exportDCs2csv
                                    The units are probably arriving in SketchUp base units == inches.
                                    So either multiply your columns in Excel by 25.4 to make mm OR when you a 'length' in inches do something like
                                    sprintf("%.1f", length.to_mm)
                                    so 1.0" >> 25.4 ?
                                    • nanolinN Offline
                                      nanolin
                                      so 1.0" >> 25.4 ?
                                      Thanks for your help.
                                      the ComponentReporter + + plugins I reported in mm but axes x, y, z
                                      You could modify this plugin to me that report LenX leny, lenz,(dynamic attributes)+ material, definition, of what is selected?
                                      in one csv.
                                      Thanks again, my knowledge of programming are very beginner
                                        This original http://sketchucation.com/forums/viewtopic.php?p=373590#p373590
                                        does some DC attribute data things...
                                        This is a NEWER version...
                                        (c) TIG 2013
                                        Script:
                                        TIG-exportDCs2csv[2].rb
                                        Type into the Ruby Console:
                                        TIG.exportDCs2csv2
                                        OR use
                                        Plugins menu > TIG.exportDCs2csv2
                                        It Exports all Selected DCs' data into a file, as:
                                        Name,LenX,LenY,LenZ,Material,Layer
                                        It uses 'mm' for the XYZ units.
                                        It is a 'CSV' [COMMA separated variable] file - made in the model's folder and named after the model thus:
                                        ModelName.skp >> ModelNameDCs.csv
                                        If a new model is unsaved the current directory receives this new file.
                                        Edit sep="," if something other than separating comma is desired.
                                        Make sep="\t" if a 'TSV' [TAB separated variable] file is desired and change ext="csv" to ext="tsv".
                                        Put into the Plugins folder and restart SketchUp...
                                        • nanolinN Offline
                                          nanolin
                                          (c) TIG 2013
                                          Script:
                                          TIG.exportDCs2csv2
                                          OR use
                                          Tig
                                          thank you very much, works perfect.
                                          Just an observation. If doubled within skp component and modify its dimensions (eg. LenX) reports all copies with the same value
                                          Deputy model
                                          Sin título.skp
                                          • nanolinN Offline
                                            nanolin
                                            (c) TIG 2013
                                            Script:
                                            TIG.exportDCs2csv2
                                            OR use
                                            ud can have the report grouped plugin components, adding the name of the group in a new column?
                                            thanks post your feedback
                                            • 2 / 4
