    [Plugin] ComponentReporter++ v1.2
    71 Posts 22 Posters 70.3k Views 22 Watching
    • O Offline
      Omarian
      Thanks a million, it worked like a charm.
      • bagateloB Offline
        bagatelo
        @TIG
        I only need The only modification I would like this plugin would measure diagonal objects properly, instead of bounding box ... and to work with groups also...
        Please take a look to another request made by me:
        http://sketchucation.com/forums/viewtopic.php?f=323&t=54080&p=490233#p490163
        • nanolinN Offline
          nanolin
          @tig said:
          Here's a version that might do what you want or be adapted easily...[attachment=0:28vg1yda]<!-- ia0 -->TIG-exportDCs2csv.rb<!-- ia0 -->/attachment:28vg1yda TIG 2011
          Script:
          Type:
          TIG.exportDCs2csv
          in the Ruby Console to run it.
          Exports all DCs is the model with a Name,LenX,LenY,LenZ,Layer[s]...
          'CSV' file - in the model's folder and named after the model thus:
          ModelName.skp >>> ModelNameDCs.csv
          If a new model is unsaved the current directory receives the new file.
          All Layers used in the DC are listed by name and visible ones marked
          thus >>LayerName<<
          Edit sep="," if something other than separating comma is desired e.g. ';'
          Make sep="\t" if a TSV file is desired and change ext="csv" to ext="tsv".
          It uses the current Model Units.
          Version:
          1.0 20111104 First issue.
          I was unable to generate the report. My model is in decimal> millimeters.
          The dynamic component is in cm. Can you tell me what the problem is.
          (This returns ruby console)
          TIG.exportDCs2csv
          Error: #<ArgumentError: C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TIG-exportDCs2csv.rb:48:in to_l': Cannot convert "23.425196850393703" to Length> C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TIG-exportDCs2csv.rb:48 C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TIG-exportDCs2csv.rb:48:in exportDCs2csv'
          C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TIG-exportDCs2csv.rb:45:in each' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TIG-exportDCs2csv.rb:45:in exportDCs2csv'
          (eval):48
          thanks
            Do you have ',' set as your decimal-separator, instead of '.' ?
            This might cause issues ??
            • nanolinN Offline
              nanolin
              I did 2 tests
              1. drawing from scratch, I think the componet, add option LenX leny, lenz, the report is generated normally.
              2. If this same component attributes modify a component value (eg 10 cm to 20 cm lenz), then display the error of failing to convert ...
              thanks
              pd. I have a component I created and I'm doubling, changing their values ​​to create furniture.
              This report would be a solution to export cuts grain orientation panel
              • nanolinN Offline
                nanolin
                With separator "," error occurs.
                With separator "." export the file, but does not make mm
                As coidgo would have to call from the menu?
                It would be so?
                require 'sketchup.rb'
                UI.menu("PlugIns").add_item("Tig Export") {
                exportDCs2csv
                  The units are probably arriving in SketchUp base units == inches.
                  So either multiply your columns in Excel by 25.4 to make mm OR when you a 'length' in inches do something like
                  sprintf("%.1f", length.to_mm)
                  so 1.0" >> 25.4 ?
                  • nanolinN Offline
                    nanolin
                    so 1.0" >> 25.4 ?
                    Thanks for your help.
                    the ComponentReporter + + plugins I reported in mm but axes x, y, z
                    You could modify this plugin to me that report LenX leny, lenz,(dynamic attributes)+ material, definition, of what is selected?
                    in one csv.
                    Thanks again, my knowledge of programming are very beginner
                      This original http://sketchucation.com/forums/viewtopic.php?p=373590#p373590
                      does some DC attribute data things...
                      This is a NEWER version...
                      (c) TIG 2013
                      Script:
                      TIG-exportDCs2csv[2].rb
                      Type into the Ruby Console:
                      TIG.exportDCs2csv2
                      OR use
                      Plugins menu > TIG.exportDCs2csv2
                      It Exports all Selected DCs' data into a file, as:
                      Name,LenX,LenY,LenZ,Material,Layer
                      It uses 'mm' for the XYZ units.
                      It is a 'CSV' [COMMA separated variable] file - made in the model's folder and named after the model thus:
                      ModelName.skp >> ModelNameDCs.csv
                      If a new model is unsaved the current directory receives this new file.
                      Edit sep="," if something other than separating comma is desired.
                      Make sep="\t" if a 'TSV' [TAB separated variable] file is desired and change ext="csv" to ext="tsv".
                      Put into the Plugins folder and restart SketchUp...
                      • nanolinN Offline
                        nanolin
                        (c) TIG 2013
                        Script:
                        TIG.exportDCs2csv2
                        OR use
                        Tig
                        thank you very much, works perfect.
                        Just an observation. If doubled within skp component and modify its dimensions (eg. LenX) reports all copies with the same value
                        Deputy model
                        Sin título.skp
                        • nanolinN Offline
                          nanolin
                          (c) TIG 2013
                          Script:
                          TIG.exportDCs2csv2
                          OR use
                          ud can have the report grouped plugin components, adding the name of the group in a new column?
                          thanks post your feedback
                            StygianStorm
                            Hi TIG - Love the plugin! I just recently stumbled on this page and it has been super useful tracking my work! I was wondering if you had the time to help me make a slight tweak? Basically, I want to tidy up the parentage report to display nested components in a more intuitive way similar to the sketchup outliner?. Hopefully the attached image makes sense: It shows only the counts of of instances, and also puts the them to the right of its parent component. This way, I can visually track the hierarchy.
                            If you have the time, I'd really appreciate the help given that I am not versed in ruby.
                            Thank you very much!
                            http://www.heyhero.com/crimg.jpg
                            • nghminh81N Offline
                              nghminh81
                              Hi TIG, Thank you so much for your powerful script. I'm using it to do my construction schedules. It helps me a lot. Could you please add a modification that allow me to get volume numbers for components? (my components are solid ready). I don't have much Ruby knowledge and was failed to do it my self.
                                Edit the file with Notepad++...
                                Around line #149 you can see the 'area' code.
                                You need to add some similar 'volume' code near that, like this:
                                volume=0.0
                                volume=c.volume if c.volume > 0
                                # it's always in cu" - to make into something else use a conversion factor like this for cu metres;
                                volume=volume*0.000016387064
                                # convert it into a string
                                volume=volume.to_s.tr(",",".")### trap for comma as decimal point...
                                # edit line ~ # 166 [remember that it will have shifted down after you entered the new volume code !]
                                ilist.push([dname,iname,lname,cname,id,x,y,z,pname,area,areas].flatten!)
                                # to include volume...
                                ilist.push([dname,iname,lname,cname,id,x,y,z,pname,area,areas,volume].flatten!)
                                # edits the lines making the header text ~ # 178
                                file.puts("DEFN-NAME,PARENT[NAME<TYPE>],INST-NAME,LAYER,MATERIAL,ID,X,Y,Z,AREA,SUB-MAT-AREAS\n\n")if miner
                                file.puts("DEFN-NAME,INST-NAME,LAYER,MATERIAL,ID,X,Y,Z,AREA,SUB-MAT-AREAS\n\n")if not miner
                                # to read...
                                file.puts("DEFN-NAME,PARENT[NAME<TYPE>],INST-NAME,LAYER,MATERIAL,ID,X,Y,Z,AREA,SUB-MAT-AREAS,VOLUME\n\n")if miner
                                file.puts("DEFN-NAME,INST-NAME,LAYER,MATERIAL,ID,X,Y,Z,AREA,SUB-MAT-AREAS,VOLUME\n\n")if not miner
                                # now edit the code around lines ~ #
                                ilist.each{|c|
                                    xx=""; c[10..-1].each{|x|;xx=","+x.to_s}
                                    if miner
                                      file.puts(c[0]+","+c[8]+","+c[1]+","+c[2]+","+c[3]+","+c[4]+","+c[5]+","+c[6]+","+c[7]+","+c[9]+xx)
                                    else
                                      file.puts(c[0]+","+c[1]+","+c[2]+","+c[3]+","+c[4]+","+c[5]+","+c[6]+","+c[7]+","+c[9]+xx)
                                    end#if
                                # to read with the extra volume element ... +","+c[-1] ...
                                # -1 says last element in array which we know in the newly added 'volume' string.
                                ilist.each{|c|
                                    if miner
                                      file.puts(c[0]+","+c[8]+","+c[1]+","+c[2]+","+c[3]+","+c[4]+","+c[5]+","+c[6]+","+c[7]+","+c[9]+","+c[-1]+xx)
                                    else
                                      file.puts(c[0]+","+c[1]+","+c[2]+","+c[3]+","+c[4]+","+c[5]+","+c[6]+","+c[7]+","+c[9]+","+c[-1]+xx)
                                    end#if
                                Hope that helps...
                                  nghminh81
                                  Thanks TIG so much for spending time with my case. Your help make it works perfectly. I've learned many many of Ruby language with your code.
                                  • V Offline
                                    vmsremy66
                                    Hello TIG
                                    thank you for your time with this plugin.
                                    do you think it is possible to list dynamic components and their LenX, LenY, LenZ that are inside another dynamic component?
                                    • V Offline
                                      vmsremy66
                                      sorry....
                                        This is somewhat more complex...
                                        Why not post a similar request in the DC forum ?
                                          maxim_
                                          Hi TIG, thanks for the plugin!
                                          Whether it is possible to copy the report in a clipboard? But only "Instances+Report"!
                                          It is sometimes better than the CSV file.
                                          • oceanembersO Offline
                                            oceanembers
                                            Hi Tig, I'm trying to get this to work, reporting the components only if the dynamic attribute "report" is true. After a little experimentation, I think I should be changing line 135 to read
                                            	    inlist.push(c) if ((c.typename=="ComponentInstance") && (c.attribute_dictionaries['report'] == 'TRUE'))
                                            But that creates no results (I do have a DC in my model with the attribute 'report' set to 'TRUE')
                                            Could you point out where I'm going wrong?
                                            • 2 / 4
