    [Plugin] ComponentReporter++ v1.2
    71 Posts 22 Posters 73.9k Views 22 Watching
    • irwanwrI Offline
      irwanwr
      thank you very much TIG.
      for Extrusion Tool Set, i've learnt and succeed using the EEbyRail 😄
      it works great as if a wizard made it 😛
      thank you
      • U Offline
        unearthed
        Hi TIG, thanks for the great plugin, now I can count my plants easily and sum plant areas easily.
        But would it be possible to add the ability to get length of curves (arcs and splines) and lines from components?
        Often I have many hedges in my designs, and if I could get their length, I could send this out with the report to Excel and then divide hedge length by plants per metre. I accept I will probably have to have a curve length for the hedge in a separate component but that's fine, although maybe it could just be as a nested instance.
        Growplan - People ∩ Plants ∩ Place
        windows 7 64b, 4GB RAM, SU 8.0.16846
        Gimp, QGIS, Vectorworks 12, Bricscad 11
          This tool was really written as a demonstration of how you can extract information from the model into CSV files etc.
          As you probably already know selected lines/curves report their total length in the Entity Info dialog.
          It's easy enough to sum the lengths of edges and report it out.
          If you give a 'little more flesh to your bones' I can perhaps guide you on how to do this...
          • U Offline
            unearthed
            Well here's a very typical hedge arrangement, although 100's of metres in many pieces is also quite common.
            I've also put the hedge centrelines as a nested component within each component, although if there's a way of avoiding that I'm all ears.
            Would it be easier to export the values of dimensions to the .csv?
            hedge.lengths.skp
              IF you want to use the nested component containing the linear info then you can readily add extra code into another column in the CSV. OR make a separate CSV report on linear info.
              Here's how to do it separately.
              The tool runs***, its code finds all components in the model with instances having a name containing 'hedge' and thereby their nested component giving the linear info drawn as a line or curve.
              It takes all edges in this nested component and totals their length.
              It writes a CSV listing the instance-name [e.g. 'c.hedge'], instance's-layer, definition-name, linear total [in meters]
              Sorted in order, with a header line and a total of the minear-meterage.
              Copy/paste this whole set of code into a new file [Notepad.exe] that you make in the Plugins folder named ' TIG-hedgelengths.rb'
              require 'sketchup.rb'
              module TIG
               unless file_loaded?(File.basename(__FILE__))
                 UI.menu("Plugins").add_item("Hedges Length CSV"){self.hedgelengths()}
               file_loaded(File.basename(__FILE__))
               def self.hedgelengths()
                model=Sketchup.active_model
                if model.path.empty?
                  dir=Dir.pwd
              	tit="Untitled"
                else
                  dir=File.dirname(model.path)
              	tit=model.title
                rows=[]
                model.definitions.each{|d|
                  next if d.group? or d.image?
              	d.instances.each{|i|
              	  txt=""
              	  if i.name=~/[Hh]edge/
              		txt << i.name+","
              		txt << i.layer.name+","
              		txt << d.name+","
              		lin=0
              		d.entities.each{|c|
              		  if c.class==Sketchup;;ComponentInstance
              		    c.definition.entities.each{|e|
              			  if e.class==Sketchup;;Edge
              			    lin+=e.length
              		txt << sprintf("%.3f", lin.to_m) ### 3d.p.
              	  rows << txt
                rows.dup.each{|e| rows.delete(e) if e.empty? }
                rows.sort!
                ## add total
                rows=["INST-NAME,INST-LAYER,DEFN,LIN.METERS"]+rows
                tot=rows.length.to_s
                rows << "\n,,TOTAL,=SUM(D2;D#{tot})"
                csv=File.join(dir, tit+"_HedgesLength.csv").tr("\\","/")
                begin
                   file=File.open(csv,"w")
                rescue### trap if open
                   UI.messagebox("Report;\n\n  "+csv+"\n\nCannot be written - it's probably already open.\nClose it and try making the Report again...\n\nExiting...")
              	 return nil
                rows.each{|row| file.puts(row) }
                file.close
                UI.messagebox("Report;\n"+csv+"\nWritten.")
                UI.openURL("file;///"+csv)
              ***Usage: either type TIG.hedgelengths in the Ruby Console... OR more easily use the Plugins menu item...
              • U Offline
                unearthed
                Thanks TIG, that's simply amazing Elegant and simple.
                Now thanks to your plugins I've got the basis for a complete plant counter (areas, individual plants and hedges and shelterbelts - Sketchup has just become a LOT more useful), thanks again.
                output from TIG-hedge.lengths.rb
                  samyell77
                  Hi Tig,
                  Great plugin - thanks. Ive used this on several jobs now and wonder if you can help me to make a few tweaks. I've been trying to use this to count components in a selection. I know that the plugin exports 3 csv documents and was wondering if you can help me to tailor the script to get the count Im after - Im afraid Im a total noob to Ruby but am more than happy to have a play with it if you can offer a little advice.
                  Id like to be able to generate a count for eithera whole model or for a selection within the model. I know that the script already generates a count for a selection but I'd like to be able to summarize items with the same name -giving me a total number.
                  I also wonder if its possible to only display the component name and the count and none of the other information (guid, description, material etc). Im trying to reduce the amount of work I need to do to tidy up the csv files that are generated.
                  Ive been playing with this whenever I get some spare time but would love a little advice.
                  Any help much appreciated.
                  Sam
                  SU Pro 2016
                  Dell Precision M4800
                  PC Windows 10
                  Intel Core i7-4900MQ @ 2.80ghz
                  Nvidia Quadro K2100M
                  16gb RAM
                    Here's v1.2 made MAC compatible... http://sketchucation.com/forums/viewtopic.php?p=147658#p147658
                      sidpickle
                      Thanks TIG seems to work OK. I'll have a play with it.
                      Ted Robbens
                      • Q Offline
                        quarch
                        Unfortunately I am having errors in counts for nested components...
                        example...
                        3 component 1 in model
                        1 component 2 inside component 1...
                        Report returns 3 counts of 1 and 1 count of 2 in stead of 3 counts of 1 and 3 counts of 2
                        Counts in instances report are correct.
                          example...
                          There ARE 3 instances of compo1.
                          There IS 1 instance of compo2.
                          You might 'see' 3 of compo2, but these are actually three representations on the same object.
                          The different reporting formats are a way of covering various bases...
                          If you want it to somehow report things differently, then rework the code as you wish...
                          It is 'open source' after all... 😒
                          • O Offline
                            Omarian
                            TIG,
                            This is similar to a problem I am having. I want to call up the running length of walls at base (where Y axis would be zero, and which would exclude door openings)or ceiling (which would give total lengths for molding etc). Is it possible to convert the above reporting script into a DCfunction in much the same way as you had created the DCvolume function? You may need specific functions that would take only the sum of lengths of the edges of the outer or inner faces of the wall at the base(ie excluding doors) and at the ceiling (which would include door openings).
                              It wouldn't be so easy...
                              BUT you can write any custom function you like to add to a DC...
                              So let's say you want the perimeter of all faces that have a normal==Z_AXIS.reverse [facing down - i,e, the bottom of a ceiling slab] inside a DC you do something like:
                              require('sketchup')
                              require('dynamiccomponents.rb')
                              if defined?($dc_observers)
                                # Open Dynamic Component Functions (V1) class, only if DC extension is active
                              class DCFunctionsV1
                               protected
                               # return the perimeter (in inches) of face.normal==Z_AXIS.reverse
                               if not DCFunctionsV1.method_defined?(;perimeter)
                                def perimeter(a) # Usage as DC function; =perimeter()
                              	se = @source_entity
                              	if se.is_a?(Sketchup;;Group)
                              		allfaces = se.entities.grep(Sketchup;;Face)
                              	else #component-instance
                              		allfaces = se.definition.entities.grep(Sketchup;;Face)
                              	faces=[]
                              	allfaces.each{|face| faces << face if face.normal==Z_AXIS.reverse }
                              	tr = se.transformation
                              	xs = tr.xscale #***
                              	ys = tr.yscale #***
                              	peri = 0.0
                              	faces.each{|face|
                              		tlen = 0.0
                              		face.outer_loop.edges.each{|e|
                              			elen = e.length # this is an unscaled length
                              			slen = elen*(1) #*** adjust for any X/Y scaling in (1) if needed ?
                              			tlen += slen
                              		peri += tlen
                                  return peri
                              end#class
                              end#if
                              This takes no notice of any scaling applied to the DC object, reporting the original perimeter...
                              • O Offline
                                Omarian
                                Thanks a million, it worked like a charm.
                                • bagateloB Offline
                                  bagatelo
                                  @TIG
                                  I only need The only modification I would like this plugin would measure diagonal objects properly, instead of bounding box ... and to work with groups also...
                                  Please take a look to another request made by me:
                                  404 Not Found
                                  (sketchucation.com)
                                  • nanolinN Offline
                                    nanolin
                                    @tig said:
                                    Here's a version that might do what you want or be adapted easily...[attachment=0:28vg1yda]<!-- ia0 -->TIG-exportDCs2csv.rb<!-- ia0 -->/attachment:28vg1yda TIG 2011
                                    Script:
                                    Type:
                                    TIG.exportDCs2csv
                                    in the Ruby Console to run it.
                                    Exports all DCs is the model with a Name,LenX,LenY,LenZ,Layer[s]...
                                    'CSV' file - in the model's folder and named after the model thus:
                                    ModelName.skp >>> ModelNameDCs.csv
                                    If a new model is unsaved the current directory receives the new file.
                                    All Layers used in the DC are listed by name and visible ones marked
                                    thus >>LayerName<<
                                    Edit sep="," if something other than separating comma is desired e.g. ';'
                                    Make sep="\t" if a TSV file is desired and change ext="csv" to ext="tsv".
                                    It uses the current Model Units.
                                    Version:
                                    1.0 20111104 First issue.
                                    I was unable to generate the report. My model is in decimal> millimeters.
                                    The dynamic component is in cm. Can you tell me what the problem is.
                                    (This returns ruby console)
                                    TIG.exportDCs2csv
                                    Error: #<ArgumentError: C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TIG-exportDCs2csv.rb:48:in to_l': Cannot convert "23.425196850393703" to Length> C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TIG-exportDCs2csv.rb:48 C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TIG-exportDCs2csv.rb:48:in exportDCs2csv'
                                    C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TIG-exportDCs2csv.rb:45:in each' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TIG-exportDCs2csv.rb:45:in exportDCs2csv'
                                    (eval):48
                                    thanks
                                      Do you have ',' set as your decimal-separator, instead of '.' ?
                                      This might cause issues ??
                                      • nanolinN Offline
                                        nanolin
                                        I did 2 tests
                                        1. drawing from scratch, I think the componet, add option LenX leny, lenz, the report is generated normally.
                                        2. If this same component attributes modify a component value (eg 10 cm to 20 cm lenz), then display the error of failing to convert ...
                                        thanks
                                        pd. I have a component I created and I'm doubling, changing their values ​​to create furniture.
                                        This report would be a solution to export cuts grain orientation panel
                                        • nanolinN Offline
                                          nanolin
                                          With separator "," error occurs.
                                          With separator "." export the file, but does not make mm
                                          As coidgo would have to call from the menu?
                                          It would be so?
                                          UI.menu("PlugIns").add_item("Tig Export") {
                                          exportDCs2csv
                                            The units are probably arriving in SketchUp base units == inches.
                                            So either multiply your columns in Excel by 25.4 to make mm OR when you a 'length' in inches do something like
                                            sprintf("%.1f", length.to_mm)
                                            so 1.0" >> 25.4 ?
                                            • 2 / 4
