    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 1.8m Views 329 Watching
    • EdsonE Offline
      Edson
      I solved that little problem: there was something at the tip of the straight line that preveted SB from recognizing it as a line. fine.
      HOWEVER, having gone through the steps, as soon as I hit enter SU crashes every time. and I am not trying any complex operation, just to bend a simple box.
      http://www.mahfuz.arq.br
        Edson,
        Have you successfully run SB before? Have you tried closing and restarting SketchUp/opening the model after fixing your line problem?
          @edson said:
          I solved that little problem: there was something at the tip of the straight line that prevented SB from recognizing it as a line. Fine.
          The line on the red axis must be a single axial line with nothing touching it - as just have discovered.
          What size are these things, if they are very small [or enormously gigantic] SUp/OpenGL can't cope.
          I think the Entity info says ~382 cm ? Which I would expect to be absolutely fine, BUT have you tried scaling x10 ?
          I'm on PC and have no problems with a similar sized thing ~1m high/3m long...Capture.PNG
          • EdsonE Offline
            Edson
            @dave r said:
            Edson,
            dave,
            I had never tried it before. yes, i tried restarting SU several times. it keeps crashing.
            TIG,
            I tried SB on a clean 7.1 install, that is, with no other plugins than the ones that ship with SU. it worked fine which leads me to believe thet either there is a conflict with some of the 200+ plugins I have installed on SU8 or some incompatibity with SU8 for mac itself. but my successful attempt with 7.1 was not without hitches: see what happened to one of the ends of the box that was bent.
              I suppose there could be a conflict. I imagine you know what to do to sort it out so I won't go into that.
              That end isn't bent. the edge/s is/are just softened. Unsoften them and it'll look right. The plugin frequently does that. I don't know if there's a script fix but it isn't that hard to rectify manually.
                If you run it with the Ruby Console open are there any error messages at all ?
                • EdsonE Offline
                  Edson
                  how does one do that? I selected the geometry and ran the slider from one side to the other but nothing happened.
                  • EdsonE Offline
                    Edson
                    no messages at all (see below). the odd thing is that the problem occurs only when the group is exactly above the straight line. if I move the group ahead the problem does not occur.
                    group to be bent exactly above the straight line
                    group no longer aligned with the straight line
                      I select the softened edges (View>Hidden Geometry) and then set the slider to 20 where it normally is by default. In the lower of your screen shots, there's a softened edge at the bottom to take care of.
                      • H Offline
                        howardhong
                        i have same problem
                        i guess its about the default setting values of edge
                          @howardhong said:
                          i have same problem
                          What do you mean by "default setting values of edge"?
                          • H Offline
                            howardhong
                            dave, i said "i guess..".
                            when im using erase tool, i saw a sudden pop up window in the center of screen.
                            i didnt give any attension, and closed that window.
                            after that happened, i got same problem.
                            so i said "i guess..".
                              The only possible edge setting would have to do with Smooth/Soften but it won't open when you are using the Eraser tool. What did the pop up box say?
                              • H Offline
                                howardhong
                                i cant remember it exactly,
                                theres three scrool down menu and one of it said "sketchup model" or somewhat...
                                  I guess, if I were you, I would wait until it shows up again and note what it says. Then report back. If you can make a screen shot showing it, that would be very useful.
                                  • EdsonE Offline
                                    Edson
                                    dave,
                                    I followed your advice and it worked. thanks. never had this problem before.
                                      BlueFalcon
                                      I selected my group and clicked the shape bender icon, i click on the straight line than the curved line, and it gives an error telling me to select the group before clicking the shape bender icon
                                      wath is the problem? i did everything like you did in the video and it wont work
                                      also, how can i make those really soft curved lines?
                                      I'am not new to sketchup or somthing, but i never had problems using plugins.
                                        It would be a big help if you either post the SKP file or at least a screen shot.
                                        • EdsonE Offline
                                          Edson
                                          just to let you know that the crashing SU8 when running Shape Bender was due to the fact that I was running an outdated version of HOlePunchTool (1.6). as soon as I updated it the crashes stopped.
                                            Edson,
                                            Glad that is sorted out. Now you can bend and punch. πŸ˜‰
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 63
                                            • 64
                                            • 36 / 64
