    [Plugin] Shape Bender Beta
    1.3k Posts 331 Posters 2.4m Views 329 Watching
    • EdsonE
      Edson
      @tig said:
      If you run it with the Ruby Console open are there any error messages at all ?
      no messages at all (see below). the odd thing is that the problem occurs only when the group is exactly above the straight line. if I move the group ahead the problem does not occur.
      group to be bent exactly above the straight line
      group no longer aligned with the straight line
      http://www.mahfuz.arq.br
        @edson said:
        @dave r said:
        I suppose there could be a conflict. I imagine you know what to do to sort it out so I won't go into that.
        That end isn't bent. the edge/s is/are just softened. Unsoften them and it'll look right. The plugin frequently does that. I don't know if there's a script fix but it isn't that hard to rectify manually.
        how does one do that? I selected the geometry and ran the slider from one side to the other but nothing happened.
        I select the softened edges (View>Hidden Geometry) and then set the slider to 20 where it normally is by default. In the lower of your screen shots, there's a softened edge at the bottom to take care of.
        • H
          howardhong
          i have same problem
          i guess its about the default setting values of edge
            @howardhong said:
            i have same problem
            What do you mean by "default setting values of edge"?
            • H
              howardhong
              dave, i said "i guess..".
              when im using erase tool, i saw a sudden pop up window in the center of screen.
              i didnt give any attension, and closed that window.
              after that happened, i got same problem.
              so i said "i guess..".
                The only possible edge setting would have to do with Smooth/Soften but it won't open when you are using the Eraser tool. What did the pop up box say?
                • H
                  howardhong
                  i cant remember it exactly,
                  theres three scrool down menu and one of it said "sketchup model" or somewhat...
                    I guess, if I were you, I would wait until it shows up again and note what it says. Then report back. If you can make a screen shot showing it, that would be very useful.
                    • EdsonE
                      Edson
                      dave,
                      I followed your advice and it worked. thanks. never had this problem before.
                      • B
                        BlueFalcon
                        I selected my group and clicked the shape bender icon, i click on the straight line than the curved line, and it gives an error telling me to select the group before clicking the shape bender icon
                        wath is the problem? i did everything like you did in the video and it wont work
                        also, how can i make those really soft curved lines?
                        I'am not new to sketchup or somthing, but i never had problems using plugins.
                          It would be a big help if you either post the SKP file or at least a screen shot.
                          • EdsonE
                            Edson
                            just to let you know that the crashing SU8 when running Shape Bender was due to the fact that I was running an outdated version of HOlePunchTool (1.6). as soon as I updated it the crashes stopped.
                              Edson,
                              Glad that is sorted out. Now you can bend and punch. πŸ˜‰
                                Edson
                                v1.7 of HolePunch was done around late January and it was to fix a reported conflict with the unusual way ShapeBender made groups, "It appears that the way ShapeBender copies/adds component-instances/definitions and also uses 'make_unique' etc fell foul of the HolePunch definitions-observers: a definition could occasionally get two of the same HolePunch observers added which really messed everything up big time!" πŸ˜’
                                See http://forums.sketchucation.com/viewtopic.php?p=302853#p302853 [and presumably Solid Tools was doing something similar ?]
                                All fixed now anyway [btw v2.0 is the current version]...
                                • EdsonE
                                  Edson
                                  @tig said:
                                  Edson
                                  I am sorry I missed that. as I said somewhere else, it is quite hard to follow all the threads about the plugins one has installed. in my case, I have 315 items in my plugins folder...
                                  • Chris FullmerC
                                    @tig said:
                                    Edson
                                    Oh my, I missed all of this also TIG. Hopefully its all sorted now. I'll have to make sure to adjust the way shape bender does that if I ever get around to re-writing it.
                                    • B
                                      BlueFalcon
                                      Here is a picture of my problem:
                                      http://portablenetworkgraph.deviantart.com/art/shape-bender-202454409
                                      • GaieusG
                                        BlueFalcon,
                                        In those pictures I cannot see the axes. Don't forget that ShapeBender works only along the red axis.
                                          Assuming that the straight line is drawn along the red-axis...
                                          How big is the group ?
                                          If bending it would make facets <1mm then it might fail...
                                          • B
                                            BlueFalcon
                                            I have done the same procces along the red axis with lines all higher than 1 meter, and the same happens.
                                            • 34
                                            • 35
                                            • 36
                                            • 37
                                            • 38
                                            • 63
                                            • 64
                                            • 36 / 64
